Old 09-14-2006, 10:54 PM   #1
johnnyfive
johnnyfive's Avatar
fairly easy to change out head unit, the hardist part is the wiring
just carefully match up all the wires on the harnes packaging, and in your aftermarket headunit manual.
Old 10-12-2006, 06:58 AM   #2
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
Warning - SAT6 SPACER/BRACKETS WILL NOT FIT INTO YOUR REAR LIFTBACK SPACE.
Thankyou :) How do i know? Cuz i tried.
Old 10-12-2006, 02:51 PM   #3
bigsky2
Cousin Vitz
bigsky2's Avatar
Drives: Yaris RS 5DR / Vitz RS wannabe
The Sat6 is primarily for 6.5" speakers aren't they?
Well you hav spacer templates, so go make some!
2007 Yaris RS Hatchback Black Sand Pearl 5DR MT
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930
bigsky2 is offline   Reply With Quote
Old 10-13-2006, 12:32 AM   #4
hasher22
Look mum no stars!!
hasher22's Avatar
I printed out the template, and thats about it. I really cant be foooked makin some.
So i just drilled holes in the Sat6 and walla perfect fit. LOL HA!
Old 11-06-2006, 10:44 AM   #5
atebit
Drives: 07 Yaris Sedan
The much sought-after 07 Sedan "standard" radio bezel part number
The toyta part number for the 07 Sedan "standard" radio bezel (in case you want to swap our the #$%^& integrated radio with aftermarket) is 55405-52640. List price is $75 US.
I had to drive to the parts counter to find this out. Now that you have the part number, maybe you can order one on-line and/or find it cheaper...
atebit is offline   Reply With Quote
Old 06-18-2007, 05:11 PM   #6
adamschneider
adamschneider's Avatar
Drives: Bayou Blue 2dr, AT
[deleted by author]
adamschneider is offline   Reply With Quote
Old 08-12-2007, 10:53 PM   #7
YARmatey31
YARmatey31's Avatar
Does anybody have a link to a specific website that I can buy a wiring harness and/or mounting kit for an 07 Sedan? I've look but can't seem to find a legit dealer... any help would be great!
YARmatey31 is offline   Reply With Quote
Old 09-20-2007, 07:51 PM   #8
pp.sweet
pp.sweet's Avatar
Drives: Red Yaris HatchBack
http://www.crutchfield.com..my best guess
Don't hate. congratulate!!
wELCOME TO oUR wORLD..
pp.sweet is offline   Reply With Quote
Old 10-21-2008, 04:16 AM   #9
IsLNdbOi
IsLNdbOi's Avatar
FYI to owners of the new '09 LBs in the US. Dash kits for the '07 and '08 LBs should be compatible with the '09 LBs. The harness adapters that worked with the '07s and '08s should work as well.
Old 10-21-2008, 04:46 AM   #10
1NZYaris1
1NZYaris1's Avatar
Speaker spacer's if anyone wants to make some
Old 12-23-2008, 12:28 AM   #11
skigil
skigil's Avatar
Drives: 2008 Yaris Hatchback
....but seriously, I couldn't have done it without the templates. They are a good start.
skigil is offline   Reply With Quote
Old 12-23-2008, 12:27 AM   #12
skigil
skigil's Avatar
I have an '08 LB and I put 6x9's in the back. I ended up making my own spacers out of wood. They are in the car nice and tight and I have no vibrations or any noise coming from them.
Note to all, start with the template above, or throw it out and use a drill and some beer. It all comes out well in the end.
Old 02-22-2009, 08:46 PM   #13
lunjiaow
lunjiaow's Avatar
Anyone know if its possible to fit 6.5inch speakers in rear of the liftback?
lunjiaow is offline   Reply With Quote
Old 02-23-2009, 04:51 PM   #14
Alien Mantis
Secret Agent
Alien Mantis's Avatar
6.5" speakers fit fine in the rear of the 3-door LB.
I went with Pioneer TS-G1642R in the front and rear of my `08 Hatch.
They were cheap, ( $38 a pair from BestBuy ), and work well with the low power output of the factory head unit.
I just gutted out the crappy factory speakers, and installed the new Pioneers inside the gutted plastic housing. I had to use a Dremel tool on the front ones to get a nice flush fit, but the back ones fit perfectly.
Old 02-23-2009, 04:54 PM   #15
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
so 6 1/2's fit in the door with no problems?
Old 02-23-2009, 05:56 PM   #16
Alien Mantis
Secret Agent
Not exactly.
The lip/flange of the new speakers did not sit flush on the factory gutted plastic speaker ring.
Different speakers might have a slightly different flange, but these Pioneers did not fit perfectly.
I used a Dremel tool and ground off a little of the edge of the factory plastic ring. Took about 10 mins. After that, the new speaker fit flush all the way around.
Sorry, but I did not take a photo of the process.
Old 02-27-2009, 06:31 AM   #17
lunjiaow
lunjiaow's Avatar
Cool thanks alien mantis. I got 6.5's Alpine Splits in the front. Was thinking of putting 6.5s in the rear. Will fit the speakers in when i get the chance to.
Old 03-13-2009, 10:28 PM   #18
blackgenius007
Drives: Yaris Sedan
Hi mates, I just bought a pair of SAT6 and I found it totally not fit into my 6.5" speaker. I have measured the SAT6 spacer's diameter, it was only 5"+, <6" in diameter... OMG
Can any one please show the photos of SAT6 with 6.5" speaker which has attached to your car?
Thanks and cheers..
blackgenius007 is offline   Reply With Quote
aftermarket stereo kit? xCookiE General Yaris / Vitz Discussion 4 02-16-2006 10:33 PM
