Old 03-23-2009, 12:44 PM   #1
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
toyota canada does not recognize 5w-20...i think this is only usa.
Old 03-23-2009, 01:56 PM   #2
SpaceShot
SpaceShot's Avatar
Drives: 2008 Yaris 5 speed HB
I use the Mobil 1 0W20 in the winter and 0W30 the rest of the year.
No ill effects after 22K miles in 2008 LB with manual trans.
In a '76 Civic I did put a rod through the aluminum block, but that was due to a defective head gasket from the factory. If you are changing your oil and filter at every 5K (or earlier) you should be fine with the Mobil 1.
Skipping an oil change, or failing to notice steady engine leaks will be much more dangerous to your engine than altering which brand or viscosity you do happen to put in.
SpaceShot is offline   Reply With Quote
Old 03-23-2009, 08:26 PM   #3
marcus
toyota
marcus's Avatar
psssssst daf... shes not a woman...
Old 03-24-2009, 12:20 AM   #4
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
Use it with confidence. Your body panels will be falling apart long before your engine shows significant wear.
firemachine69 is offline   Reply With Quote
Old 05-14-2009, 01:22 PM   #5
daf62757
Nothing beats a Toyota!
daf62757's Avatar
Just to follow up...I recently did an oil change and switched to Pennzoil Platinum 5w20. I then went on a 2k mile road trip to Louisiana and I was impressed. The engine sounded much smoother and the mileage was OK...(75MPH, AC on, with an average 37MPH). Not enough imperical evidence, I know....but just on the Wheel Interface Mechanism (the human behind the wheel) I am satisfied! The PP was very cheap, I bought it at Advanced Auto for 29.99 for 5 qts and a Mobil 1 oil filter. I also changed my wife's Rav4 at the same and have 2 qts to spare!
Big Dave
Indianapolis, IN
Old 05-14-2009, 02:03 PM   #6
1stToyota
1stToyota's Avatar
Originally Posted by daf62757 View Post
Just to follow up...I recently did an oil change and switched to Pennzoil Platinum 5w20. I then went on a 2k mile road trip to Louisiana and I was impressed. The engine sounded much smoother and the mileage was OK...(75MPH, AC on, with an average 37MPH). Not enough impreical evidence, I know....but just on the Wheel Interface Mechanism (the human behind the wheel) I am satisfied! The PP was very cheap, I bought it at Advanced Auto for 29.99 for 5 qts and a Mobil 1 oil filter. I also changed my wife's Rav4 at the same and have 2 qts to spare!
I'm getting a UOA at my next PP 5w-30 OCI. I ran Eneos and Amsoil, and the engine with PP seems to be very smooth and quiet; the best so far. Paid $3.99 per qt at O'Reilly, 3 cases before their sale ended.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 05-14-2009, 09:00 PM   #7
GeneW
Drives: 2008 Yaris
I know this issue has been talked about extensively, but I am wondering if anyone has used 0w20 for a while and what has been there experience with it? I see contradicting info on using 0w20 and I am curious if someone has actually been using it, what is their experience with it, and have they experienced any engine damage as a result.
I use Valvoline Synpower, 5W-30. To each their own...
Gene
Old 05-14-2009, 09:15 PM   #8
DerFlosser
DerFlosser's Avatar
0-20 is to little protection for a timing chain...especially as the guides wear and the temperature rises. 5-30 is a perfect oil for this motor.
DerFlosser is offline   Reply With Quote
Old 05-15-2009, 09:45 AM   #9
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
NEWEST dealer letter from toyota explains their plan to use 0W20 in ALL their cars begining with some 2010 models. the letter explained in detail toyota's plan to increase maintence interval mileage and their request for dealers to expand/add 0w20 oil tanks.
Old 05-15-2009, 02:01 PM   #10
1stToyota
1stToyota's Avatar
Because they're pressured to show better fuel economy ratings and project that their cars need less service now, or because it'll make the engines last longer by switching viscosity and changing it less often?
2008 Scion xD
Old 06-03-2009, 09:55 PM   #11
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
As usual I agree with 360cubes. However, since the Amsoil 0W-20 does not carry ILSAC GF-4 and 0W-20 is not approved by Toyota for these engines people should understand they may have a battle for warranty coverage if the dealer decides to push it.
The burden is on the dealer to prove your oil choice caused the problem, but this can make life pretty uncomfortable in the meantime. Also Amsoil is only going to cover a problem if the oil is the oil they recommend for your vehicle and it causes the problem (it isn't and it won't). Currently Amsoil's website recommends all 30 wt products.
Having said that it makes no sense to me why 0W-20 oils are not approved by Toyota. Most quality 0W-20's should provide the same protection as there 5W counterparts with even better cold start performance.
For those of you using the Amsoil 0W-20 it is an exceptional product and among my favorite oils regardless of viscosity. I have used it in a police cruiser out to 15,500 mi PLUS OVER 300 hrs of IDLE TIME with excellent oil analysis results. For those of you who are out of warranty or willing to fight Toyota if need be and want to greatly extend oil change intervals I would highly recommend the Amsoil 0W-20.
I will be using Schaeffer's Supreme 7000 5W-20 for the first and subsequent oil changes in my Yaris, as it is ILSAC GF-4 (carries the starburst), is approved 5W-20 and is very reasonably priced for a cake walk 5 k mi/6 mo oci.
As some have mentioned Pennzoil also offers up an excellent product at a very reasonable price with there Platinum line. Mobil 1, Synpower-all these products are overkill for 5k oci's-and that's ok in my book.
R2D2 is offline   Reply With Quote
Old 06-03-2009, 10:15 PM   #12
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
i vote the next person who starts a "0w" thread gets a 3 day ban
Originally Posted by xnamerxx
you nailed it sir.
