Old 09-03-2006, 01:05 PM   #19
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Originally Posted by Violin
But yes, we should get together sometime - perhaps do a dual cruise control install.
Lets get something going!
Old 09-03-2006, 10:59 PM   #20
Boo
Boo's Avatar
Drives: PW Yaris LB AT
Much more noticeable sound.
I've done this with every car I've had since an 18 wheeler changed lanes into my Miata at 75 mph and didn't hear my little horn until he nearly ran me over.
Sounds like that is my next mod.
Boo is offline   Reply With Quote
Old 09-06-2006, 08:58 AM   #21
Lizardboy
Mmmmm, twisties!
Lizardboy's Avatar
Drives: 07 Red Yaris S & 95 Miata
Thanks guys! Awesome pics!
It sounds like I'll have to relocate from the factory location if I want to go with the 12" dual horns. I think it'll be worth it though.
Don Neudecker
Ad Compositor Extrodinaire
"The instructions are inside the box." - My I.T. Dept.
Lizardboy is offline   Reply With Quote
Old 09-07-2006, 09:16 AM   #22
Lizardboy
Mmmmm, twisties!
Lizardboy's Avatar
Originally Posted by SmellyTofu
Yes it's easy.. just a pain in the @$$ to do it. :)
It's hard to show it but here's my horns.. there's not a lot of clearance (maybe a finger thick) between the bellow part of the horn and the grill.
Interesting. Judging by the grill, both you and Violin have liftbacks, correct? I took a closer look at the area around my factory horn and it looks like there's at least 6 inches between the grill and radiator where the factory horn is mounted. I think there should be plenty of room for the larger air horns I want. I'll order them today. Thanks again guys!
Don Neudecker
Old 09-10-2006, 12:16 PM   #23
fred812
Authorized User
fred812's Avatar
Drives: 2007 5 spd Hatch White
PEP BOYS sells wolo, just under 30$ for the dual horns, I put them on every car I own, can be a bit of a bi*ch to wire the relay! pm if you need help done it 6 times at least. Beef up the wire and connectors they give you. You wont believe how damn loud they get! Fiat spyder has the same european sounding toot. It has saved me from many a close call with just a quick toot to let them know im there.
fred812 is offline   Reply With Quote
Old 09-16-2006, 07:07 AM   #24
Lizardboy
Mmmmm, twisties!
Lizardboy's Avatar
Well, I finally received my horns. I've learned that there is yet another difference between the LB and sedanS. You can't get the front of the car off without undoing a bunch of bolts under the car, a couple of which are quite difficult to reach. I decided to rig the horn in the engine bay, but besides it being muffled, the Wolo, dual horns blew the 10amp horn fuse. Any ideas? I'm going to try to get the front end completely off and find somewhere to mount the horns behind the grill area but why are the horns blowing the fuse?
Don Neudecker
Old 09-16-2006, 08:03 AM   #25
tomjasz
tomjasz's Avatar
Drives: 07 Black Yaris LB, 05 Camry LE
Have you considered "FIAMM Freeway Blaster" ? Much louder!
tomjasz is offline   Reply With Quote
Old 09-16-2006, 08:10 AM   #26
tomjasz
tomjasz's Avatar
Freeway Blaster
Extra Loud for Passing Safety Approved to EEC Regulation 28
The Freeway Blaster Horn is designed for addition to, or replacing, the original equipment horn(s) to alert drivers in noisy and high speed traffic. Versatility and rugged construction are major selling points of this horn. Features steel housing and plastic projector. Copper wire coil motor. Available with universal mounting bracket or right angle bracket. Corrosion resistant finish. Each horn is tested to assure maximum performance. High or low not (one or two terminals). Can be mounted singly or as duals. Available in unit, bulk or point of sale containers. Made in the U.S.A
Terminals
two
Dimensions (L X W X D)
9 1/4 X 6 5/8 X 3 1/2
Frequency (Hz)
405
Min dB. Rating @ 4"
130
Current Draw (AMPS)
5
Bracket
Universal
Power Source
12V
Old 09-16-2006, 09:48 AM   #27
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
I had to remove a number of bolts to remove my bumper too. I put the front on ramps to make it easier to get at. It took maybe 5 minutes. If you need instructions, download the service manual.
As far as the fuse - do the horns indicate the current draw on them or the packaging? Try contacting wolo?
Old 09-16-2006, 01:01 PM   #28
Lizardboy
Mmmmm, twisties!
Lizardboy's Avatar
I've got ramps, I just received the horns late yesterday and got a little over anxious.
I can't find the current draw anywhere, I'll contact Wolo.
I know I've seen it before but where is the link to the manual?
Thanks for the help.
Don Neudecker
Old 09-18-2006, 05:05 PM   #29
Lizardboy
Mmmmm, twisties!
Lizardboy's Avatar
Well, I got a reply from Wolo today, the manufacturer. They said 10 amps is too small, they said to use a 12-15 amp fuse. Does anyone think that might cause a problem?
Don Neudecker
Old 09-18-2006, 05:32 PM   #30
Violin
Violin's Avatar
Here's the manual: http://www.yarisworld.com/forums/showthread.php?t=1768 You want "Exterior Trim".
As far as putting a larger fuse in your horn circuit. Sure - that might cause a problem. I don't know what guage wire you have throughout or what the relay is rated for - so you could end up with a carbeque. It definately warrants some investigation.
Old 09-23-2006, 09:42 PM   #31
Lizardboy
Mmmmm, twisties!
Lizardboy's Avatar
Thanks bro! I got the two horns installed just to the passenger side of the radiator, behind the grill. I mounted the compressor inside the engine compartment just behind the horns for easy access when I need to oil it. They are MUCH louder and deeper than the factory horn. I planned on taking some pics before putting the bumper back on but I was in so much of a hurry to catch the USC football game I forgot! Sorry!
Thanks for the help though!
Don Neudecker
Old 09-23-2006, 10:57 PM   #32
jeff_o
Drives: 07 Yaris
Send a message via ICQ to jeff_o Send a message via MSN to jeff_o Send a message via Yahoo to jeff_o
violin, i'm from NJ as well... would that be legal to change horns to louder and powerful ones? I bet you know if you live in suburbs NJ it is a big big deal to everyone to honk your horn :D
jeff_o is offline   Reply With Quote
Old 09-24-2006, 11:00 AM   #33
Violin
Violin's Avatar
I have no idea. I guess there may be a law on maximum db. The only law I know is against non-emergeny use of the horn.
Old 09-24-2006, 11:01 AM   #34
Violin
Violin's Avatar
BTW - I work near you in East Hanover.
Do you drive a sedan or liftback?
Old 09-24-2006, 10:40 PM   #35
jeff_o
Drives: 07 Yaris
wow you're really near. I still don't have a yaris, but i'm planning to get a Sedan :) btw... I notice no one here has a yaris S... isn't the S a nice deal?
Old 09-25-2006, 12:21 AM   #36
ItsMyDaily
The LittleBastard
ItsMyDaily's Avatar
what toyota brand horns are those?
Yaris Mods:
20% Tints
Ground wires
2007 Toyota Yaris Liftback - Current
2004 Honda S2000 - Sold
1986 Toyota Corolla SR5 - Sold
DIY: Groundwire Kit
ItsMyDaily is offline   Reply With Quote
Cold Air Intake yariman Performance Modifications 21 10-03-2010 07:20 PM
1.3 Ltr Yaris Air Filter mods aucorium Performance Modifications 9 08-18-2006 08:32 AM
Air selection intake broken? David81 General Yaris / Vitz Discussion 16 06-29-2006 02:51 PM
Cold Air hirosho General Yaris / Vitz Discussion 10 05-22-2006 10:59 PM
Cold Air Intake ? pegcityrs Performance Modifications 47 04-17-2006 07:43 AM
