Old 09-05-2006, 07:10 PM   #19
thewifesyaris
thewifesyaris's Avatar
Drives: 2007 and 2008 MM Yari LBs
hoop
explain...?
Two Yari on home!
thewifesyaris is offline   Reply With Quote
Old 09-05-2006, 07:22 PM   #20
Spades
The Hated One
Spades's Avatar
Drives: 07 White Manual Sedan
well...nice to see another car forum with a bunch of jerks on it.
thank you for your well thought replies...now...the question...do i care...the answer is no...i do not care what any of you think.
so, thank you for all the helpfull suggestions...I will be going lower profile when i have the money, untill then they will stay on there...so, unless you all have the money to give me to buy differant tires (as I said, the tires on there were free) please to not try to bully me into buying something I do not have the money for right now.
P.S. Lock to lock no rub, there is actually 1" of clearance. there is 2" fender to tire, and the only thing that rubs is the rear mudshields in the back if you take a speed bump fast.
Old 09-05-2006, 07:51 PM   #21
SimmZ
Drives: 2k3 Cavalier & 2k2 Echo
SPADES, you absolutely not understand the what the problem is! It have nothing to do with the wheel clearance, it's the lastest of the concerns! It's related with the VSS (vehicule speed sensor) who provide the most importants measurements to your ECU (Engine Controller Unit). If your ECU is not receiving the right datas from the sensor about the driving speed and conditions, it will fuck up all the settings of the engine (air/fuel mixture, ect). It is really major! If you don't trust us, just call your dealer right fuc*** now.
If you don't have the money to put the right tires on your car, just keep the stocks on! You don't have to break something major on your car because you don't have the money to buy right tires... it doesn't make sense!
2003 Chevy Cavalier Ecotec - His car!
2002 Toyota Echo Sedan - Her car... FOR SALE!
SimmZ is offline   Reply With Quote
Old 09-05-2006, 07:54 PM   #22
SimmZ
Originally Posted by Katana
Mine had stock 185/60R15.I put on 195/55/15.Is this right?
Perfect sir! No problem at all. I actually use 185-60-14 on the Echo instead of the stock 175-65-14.
Old 09-05-2006, 08:27 PM   #23
bigsky2
Cousin Vitz
bigsky2's Avatar
Drives: Yaris RS 5DR / Vitz RS wannabe
SimmZ speaks the truth.
Running different setups that are beyond 2-5% difference of original diameter is pretty bad for the vehicle.
We're not forcing or bullying you to get tires you can't afford, we're just advising you that you should hold off on installing your rims until you get the proper tires for them.
Not to offend you, but are you that hurting to get new rims on right away?
2007 Yaris RS Hatchback Black Sand Pearl 5DR MT
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930
bigsky2 is offline   Reply With Quote
Old 09-05-2006, 08:38 PM   #24
static808
Engineer/Artist/House-Dad
static808's Avatar
Drives: 2006 Toyota Sienna XLE
how dare these "jerks" try to help you keep your car running well. and if you didn't care, why'd you put a post up?? u should be thanking everyone here for providing such wonderful information to help keep our cars running smoothly. just my 2 cents...
--B
static808 is offline   Reply With Quote
Old 09-05-2006, 08:48 PM   #25
Hawaiian Bluzman
Chrome is GOOT!
Drives: Polar.WhiteYaris.2dr.liftback
Bunch of JERKS
Hey Man! We're trying to save you $$$..you might end up paying more...We don't want to see you lose your investment. This is what I read about Plus Sizing...
Plus Sizing
Plus sizing your wheel & tire combination was designed to enhance vehicle performance and looks by allowing fitment of larger diameter rims and lower profile tires. The theory is that while making these changes, you keep the overall tire diameter within 3% of the original equipment tires. This is important because larger variances can cause problems with transmission shift points which can decrease fuel mileage. It can also confuse braking system computers which can even lead to brake failure.
Here's the rule of thumb for "plus sizing":
Plus 1:
Increase section width by 10mm
Decrease aspect ratio by 10 points
Increase rim diameter by 1 inch
Plus 2:
Increase section width by 20mm
Decrease aspect ratio by 20 points
Increase rim diameter by 2 inches.
This is not exact, but it will usually get you in the right ballpark. We always recommend consulting with the people you are purchasing the wheels and tires from to ensure fitment.
And Hey! if your Car is OK and nothing happens more power to you!
Hawaiian Bluzman is offline   Reply With Quote
Old 09-05-2006, 08:51 PM   #26
casterqc
If you decide to post a picture of your car on a forum, you have to expect people to make comments about it...I mean not only good comments.
No one has been disrespecting you here, and trust me many would have in other forums. I agree with SimmZ, his suggestions are only for your own good. Instead of telling that all of us, but you alone, are "jerks" because you really want us to understand that you don't care about our comments and suggestions...you should try to do a little research on the importance of wheels and tires specs on a car.
My suggestion, if you don't have the money to buy a good set of tires...don't go buy 17inch wheels! Their's a difference between not having enough money and not knowing what to do with the money you have.
But as long as you're happy with what you have....it's fine with me and you can still be a friend
casterqc is offline   Reply With Quote
Old 09-05-2006, 11:40 PM   #27
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
All the postings on here is good advice even though it might not seem like it at times. People just need to be a little more helpful instead of being quick to say YOU ARE A F*&^ING MORON or something to that nature. No wonder you feel like you are being bullied at times. Some people just need to tune it down a notch.
Old 09-06-2006, 12:48 AM   #28
ChinoCharles
Drives: LB
Its tough love people... we all get flamed from time to time. Its part of the game. BUCK UP!
Old 09-06-2006, 10:37 AM   #29
sroberts
sroberts's Avatar
Wow, dont get your panties in a bunch. People are just trying to help. Maybe they could be a little less dramatic when they post but its just advice. Don't post if you don't want responses.
BTW, your statement makes you just as much of a jerk....
I am not allowed to put anything here because I do not have any ricey mods on my Yaris....
sroberts is offline   Reply With Quote
Old 09-06-2006, 12:37 PM   #30
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Originally Posted by Hawaiian Bluzman
Your Good! your only 1.26 bigger which way under 3%
Thank you both guys!
Old 09-06-2006, 05:21 PM   #31
dngz
dngz's Avatar
Drives: black yaris sedan
No wonder your wheels looked soo big!! Sell your 50's and get 40's!!!
dngz is offline   Reply With Quote
Old 09-07-2006, 01:28 PM   #32
SimmZ
Good idea!! If you don't have money, just sell your 225-50 and they some 205-40.
Old 09-07-2006, 04:20 PM   #33
YamilR
YamilR's Avatar
Drives: Absolutely Red Liftback
Send a message via Yahoo to YamilR
What size of tires do you guys recommend for this Enkei?
http://www.discounttire.com/dtcs/fin...bp=&vid=010325
YamilR is offline   Reply With Quote
Old 09-07-2006, 06:01 PM   #34
Hawaiian Bluzman
Chrome is GOOT!
205/40/17 will be your best fit.
My 17"s was 7-1/2"wide so I went with 215/40/17
Old 09-08-2006, 07:01 AM   #35
SimmZ
Just for your info, the tires size doesn't really matter with the wheels. It does matter with the car it's going on. Definitely 205/40/17 will be your best bet.
Enjoy!
Old 09-08-2006, 09:51 AM   #36
dngz
dngz's Avatar
40 profiles should be juuuuuust right!
17" rims PixieDawn Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 09-13-2006 08:07 PM
Lets talk rims....again (help!!) silverRS Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 06-30-2006 12:38 AM
RIMS ON THE YARIS Uglyboyed Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 06-26-2006 02:02 AM
17" rims + noticable power loss???? bladesmith6 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 06-22-2006 07:30 AM
rims for yaris thread wushumasterku Photo-Video-Media Gallery 0 06-11-2006 12:44 AM
