#1 |
Chillin' out by the Bay
Drives: 2007 Yaris Liftback Join Date: Nov 2006
Yep! I used a terry cloth towel - old school style - and MAN did my car come alive! The trick is to drink beverages while you do it. Heh...
Gettin' all the way down. Meteorite '07 HB STILL completely stock; but.... checkin' out da other ones to see what's what. |
Yeah, but I also found that my beverage of choice eventually makes all the scratches disappear!
#3 |
Hahahhaahaaaa...yeah.
#4 |
![]() ![]() Drives: 2007 Yaris Sedan Join Date: Oct 2008
How much pressure are you supposed to apply when you're using Scratch-X?
I tried some on the trunk a couple months ago, and you could barely even tell it had been polished. I applied it by hand, without pressing very hard. Do you have to work it in before it hazes up? My Yaris is dark blue and all the little scratches are very visible. |
#5 |
You gotta use elbow grease and a terry towel. It takes pressure and rubbing vigorously (which is why I recommend the beverages to stay hydrated).
#6 |
All I would do is take a Meg's yellow pad, (any pad will do) squirt about a 1" circle of Scratch-X, then make a swirl pattern on a 1 foot by 1 foot square. I would apply about a medium pressure and hard pressure on extremely visible scratches. I believe that the directions on the S-X says to let the area dry and then buff off with a terry towel.
About 6 months ago I was researching this. I read that S-X uses a special abrasive that evens out fine to light scratches. The trick to the abrasive is that as you rub it into the paint it slowly dissolves, which is why it is safe for any paint. There is almost no way to buff a "blur" into your clear coat using normal muscle power. Last edited by Slick; 04-24-2009 at 12:19 PM. |
#7 |
School'er of hard knocks
Drives: Silver Yaris 4dr. HB Join Date: Oct 2008
NO. Scratch-X is a hand buffing abrasive. You will end up with a VERY uneven surface.
Get the entire car professionally buffed if it's that bad. |
#8 |
firemachine69
This is from Meg's forum Admin "The trick is to work the product in until it just begins to disappear and to apply more than one application. You see, the ScratchX, like all Meguiar's Paint Cleaners, contain a diminishing abrasive, as you work ScratchX in, the microscopic diminishing abrasives gently abrade the surface removing small particles of paint. But as you work it in, these diminishing abrasives breakdown. Thus, they quit abrading the finish and actually polish the finish to a clear, high gloss. This diminishing action turned polishing action is a benefit to you because it enable you to work out defects without leaving scratches behind." I know for a fact from experience there is no way S-X by itself will damage your clear coat. I did an entire truck, no problems, only satisfaction. |
#9 |
I agree with Slick. The citation from Megs is correct.
I've used this product on my cars as well as others with no ill effects. I also have a DA and a rotary with Megs professional products; but, for spot work by hand or when I don't feel like pulling out the hardware, Scratch-X is why Meg's designed the product. I have been able to remove swirls in isolated areas - from someone brushing up against the car - with Scratch-X perfectly. I've gotten the best results with a terry cloth towel which cuts down on the number of passes.
#10 |
my car from the lot with a deep gouge on one of the side mirrors :( luckily the dealer changed it, lol what they did was take a mirror of one of the cars in the lot and put it on mine, so i guess either there is a car at there lot still with a damaged mirror or someone didnt notice it when they bought there car lol... sorry if anyone here got it
![]() ![]() The difference between fiction and reality? Fiction has to make sense. --Tom Clancy |
#11 |
![]() ![]() ![]() ![]() ![]() Drives: Decepticon - Ravage Join Date: Nov 2008
entire car, i wouldnt do, but this stuff is great for surface scratches, i found a pretty big one today, but less than a minute work and its gone. Really helps that color is meteor metallic, but even deep scratches i got to only slightly visible.
#12 |
i got my first major scratch this past winter. i came home and my hood was still hot from driving it around and a stray cat came over and climbed on top of my hood for warmth because it was cold and it was falling off and one nailed clawed a nice scratch on my hood, scratch X did nothing so i got touch up paint, did a crappy job but the scratch isn't there anymore....
i kno what had happened because there was dirty paw prints all over my hood lol |
| ImportRacer88's Photo Scavenger Hunt | ImportRacer88 | General Yaris / Vitz Discussion | 8 | 02-28-2012 05:19 AM |
| TomTom Custom Yaris car symbol. | andru47 | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 04-25-2009 02:47 PM |
| Zefoxe - Photo Scavenger Hunt | Zefoxe | Photo-Video-Media Gallery | 0 | 03-02-2009 11:23 PM |
