Old 04-27-2009, 08:10 PM   #19
360cubes
Drives: 2000
Send a message via MSN to 360cubes
Originally Posted by Loren View Post
You do need to let the engine rev SOME to break in properly.
Well said!
I've test driven new cars as if I've owned them for ten years and was late for a track meet. Some higher RPM use will be fine. Drive around town in 3rd gear and use 4th at lower highway speeds (55mph) for a few miles. As it was mentioned, you're not only breaking in the engine but the transmission as well. You want to make sure everything works fluidly and is sound in case you had to press the pedal down to get away from someone (a rare emergency getaway, like SEMI losing brakes going downhill!). It won't hurt anything and be SURE to get your oil changed around 1000miles, this will help prolong engine life as the filter may not contain all the metal particles left behind accidentally from the manufacturing process.
360cubes is offline   Reply With Quote
Old 06-03-2009, 11:08 AM   #20
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
I agree with Loren, MadMax and 360cubes-you need to load the engine enough to seat the piston rings early on. I don't know why engine manufacturers insist on people babying engines for the first 1k. In my experience this is the wrong thing to do. I drove mine off the lot like it was stolen. Not being abusive, just generating enough pressure to force the rings out against the cylinder walls to get a good seat.
360cubes- excellent point on changing the factory oil at 1k. This has always been my practice as well. Oil analysis on factory fill can be pretty nasty but metals/silicon usually trend down fairly quickly after the initial oil change.
R2D2 is offline   Reply With Quote
Old 06-03-2009, 11:53 AM   #21
YarisSedan
Drives: 08 Yaris Sedan
The most of the breakin occurs in the first 100 miles already so theres not much more you can do. Just try to avoid constant speeds like long freeway driving. This may cause glazing on the cylinder walls. Otherwise just drive it like you normally would. A good mix of speeds is best. Occasional high revs but not redline is good.
Is subwoofer "break in" period a myth? pariahdecss In Car Entertainment + Electronics (audio / video / alarm) 5 03-29-2009 12:34 PM
Break-In Period. IsLNdbOi General Yaris / Vitz Discussion 7 10-26-2008 11:07 PM
Yaris break-in period kimona General Yaris / Vitz Discussion 16 06-21-2007 12:36 PM
Need Help Please!!(Break in period) Moore General Yaris / Vitz Discussion 10 06-03-2007 01:58 AM
WHat is Yaris Break In period and how? marcus General Yaris / Vitz Discussion 3 01-19-2007 02:24 PM
