Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Hawaii
Old 05-01-2009, 11:07 PM   #19
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
Originally Posted by gwasabi View Post
No I dont have my hachi anymore, I sold it hahahaha
BTW Peter, I got the ok from the girlfriend to go ahead and start building a turbo kit, I know your so excited your popping one right now!
Also Taka just ordered his yaris and Haku gettin his after summer. YOU GUYS GOT ALOT OF CATCHING UP TO DO!
I am excited for you!
Good to hear those guys ordered their yaris. My friend who lives down the street from me just ordered a 09 S model, 5 speed, power package, in Silver. He's going to mod his car too!
Yaris cruises at the end of the year!
Old 05-07-2009, 05:16 AM   #20
Hosh's One
Drives: 3 Door Hatchback 5 speed "S"
Where do I begin with mods!?...there's too many things to think about, so little knowledge, so little money, so many threads to read....
Hosh's One is offline   Reply With Quote
Old 05-07-2009, 05:22 AM   #21
Taiyaki
アキバ製
Taiyaki's Avatar
^im totally with this guy, little knowledge, and very little money! haha
Old 05-07-2009, 05:24 AM   #22
Taiyaki
アキバ製
Taiyaki's Avatar
I think I saw it driving by Kahala, it was a Sliver S. Thats only the second S i have seen so far, that and a blue one.
Old 05-07-2009, 04:29 PM   #23
gwasabi
Drives: 07 Blazing Blue LB
Hosh, This is the must get mods I recommend for the biggest difference you can FEEL.
1.Corolla TB
2.Intake
3.AxleBack exhaust (Not a custom 2 or 2.5 inch. You will lose back pressure and wont feel anything)
4.Short Shifter
Those are the cheap mods I recommend for the best Bang. You will FEEL the difference not just think it lol
Most Satisfying Crew
Serious Business...
MunkyWurks Garage - 8088488794
gwasabi is offline   Reply With Quote
Old 05-07-2009, 05:31 PM   #24
fuji
fuji's Avatar
Drives: Polar White Yaris HB
Another mod which will make a dramatic difference are rims....
I am using Enkei RPF1. They only weight9.5lb eash which is WAY lighter than the stock 16lb steel rims. Many light aftermarket are around 12-13.5.
With the lighter and wider rims you get better......
Acceleration
Braking
Cornering
Suspension response
Another super easy mod is upgrading your grounding system to a large 0 guage wire connecting the negative terminal to the body. This helped my throtle response and made shifting smoother(auto trans).
fuji is offline   Reply With Quote
Old 05-07-2009, 05:50 PM   #25
PETERPOOP
PETERPOOP's Avatar
even though my wheels are only 10 pounds (16x7), the weight of the rim and new tire are together heavier than my stock steelies were with their tires. I felt the difference immediately. oh wells. if they ever made a drag strip here, i'll put my stockies in the back and some slicks up front.
Old 05-07-2009, 05:57 PM   #26
gwasabi
Uhm....No you wont because if you do that you'll lose traction in the back and you'll spin out on a drag strip.....
Serious Business...
Old 05-07-2009, 06:01 PM   #27
PETERPOOP
PETERPOOP's Avatar
then i'd need some new wheels designated for the strip. maybe in the next 10 years when they build the track
Old 05-07-2009, 06:03 PM   #28
gwasabi
I would just use slicks all around lol. Anyway I thought they were building the KRP?
Serious Business...
Old 05-07-2009, 06:04 PM   #29
gwasabi
also like to mention that the yaris is REALLY fun for Tray sliding hahaha
Serious Business...
Old 05-07-2009, 06:07 PM   #30
PETERPOOP
PETERPOOP's Avatar
putting trays under the rear tires?
pfft who knows when the krp is done. is that just a race track, or is it a 1/4 mile strip?
Old 05-07-2009, 06:41 PM   #31
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
slicks up front and stock rims in rear is a perfect set up my crx is in the 9's and wont spin out cause you can even go down to a 5 inch skinny rim in the rear and not worry about spin out but if you do use the stocks for drag racing please adjust the rear damper to max stiffness so this provides better traction for the front tire and reduce the squat effect which will cause the front to vibrate like crazy and end result is broken axle. trust me ive done it launching a 12000rpm on stock axles with out adjusting the rear dampners. if you run all slicks all around you would actually be slower because the slicks on the rear will create a drag. slicks are not neccessary as you dont have enough power to pull em i would run good tires like bf goodrich tractions i use to run those in the street class on my 9 sec crx and they hold up to 500hp just run them like 10psi lower on the front and burn out
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 05-07-2009, 06:42 PM   #32
battleversiontc
the track they building wont be done for a while its the last to be built um but its a 1/8 mile track
Old 05-07-2009, 07:00 PM   #33
battleversiontc
sorry i just wanted to make it clear due that i do travel with my hatch and crx to mainland and stuff for nhra, nopi, street heaters races around the usa and have my license to pilot below 10's which im already in the 9's on my crx now
Old 05-07-2009, 07:04 PM   #34
battleversiontc
and also slicks if you can sit there and smoke them there not effective because by the time you line up there not as hot and sticky not unless you burn out the burn out in vht then yeah you be good. thats why cherry street tires are awesome for drags. i actually run better on street tires then i do on slicks even tho traction on the bottom is kinda shitty. thats why people grab dot slicks the street kind cause they give you both a slick and a road tire and i would like to add i run a real skinny rim and tire on mine i think the width is no bigger then 4 in
Old 05-07-2009, 07:10 PM   #35
gwasabi
Lol ^ there you go. Like I said I don't know shit about cars gotta listen to someone who knows.
I would figure you don't need slicks on our cars too little power. I would have to agree with you on running good tires but Peter seemed like he really wanted to use slicks.
Hmmm I just thought he'd spin out with stock tiresin the rear cause our rear is actually lighter than the front and you can feel it in the hatchback. Like when I go over bumps and stuff there is like Almost NO weight in the rear so I thought it'd be a bad idea but again, I never drag race, More into grip lol
Serious Business...
Old 05-07-2009, 08:10 PM   #36
PETERPOOP
PETERPOOP's Avatar
that says it all
you are seriously retarded. did you get this from my one statement of saying i'd run slicks in the front and stocks in the back? yah, i REALLY really wanted to use slicks so bad. oh boy i do....
pulled and rolled BrazdonW Cosmetic Modifications (Exterior/Interior) 30 05-06-2009 11:23 PM
