Old 05-12-2009, 12:11 PM   #19
pics of the rear upper mount inside the car?
what wheels/tires are you running? any chance theyre hitting the fender? how fast are you hitting bumps when it makes the noise?
Old 05-12-2009, 12:13 PM   #20
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
that sounds like the problem right there......
MicroImageonline forums - Shroomster
Xda Forums - Shroomster
Androidforums - Shroomster
I'm noticing a pattern......
Old 05-12-2009, 02:48 PM   #21
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Something like this happened to me after installing the Tein Basic coilovers....
It turned out that I missed instaling a spacer on the upper rear mounts. So the shocks were not tight against the upper mount and mada a clunk noise over minor bumps.
2" drop is not that much... you can get 2.5" down with the teins...
I would review the installation manual and make sure you got all the parts installed properly. Just because a shop did the job doesn't mean they can not do it wrong.
Old 05-12-2009, 05:03 PM   #22
fuji
fuji's Avatar
Drives: Polar White Yaris HB
Thanks so much Castrex! Was the sound they made pretty loud? I will check on this when I get home from work.
fuji is offline   Reply With Quote
Old 05-12-2009, 09:25 PM   #23
CASTREX
CASTREX's Avatar
Yes it was loud.... like the one you describe.
It was a long time ago... and the thread I made when I installed them got lost during the hack.
I was looking for some pics but couldn't find any...
I know for sure that I had to uninstall the rears to fix the problem and it was not clearly visible with the shocks mounted on.
In my case I believe we missed the dust cover. The installation manual was not very clear about it. You were supossed to hacked the OE plastic dust cover and remove the metal top of the cover. This piece worked as a spacer. With out it the shocks were loose and hit the body of the car when driving over bumps.
I attached a copy of the installation manual for the Tein Basics from the tein web site.
Hope you can figure this out.
Old 05-13-2009, 06:25 PM   #24
maddo1983
Drives: MITSUISHI EVO 5
Thumbs down clunk sound!!! with my tein mono flex shocks
does anyone know what the problem might be with my shocks,i tink it could be the upper mount thats at fault for ths??i checked everything else and its perfect but the mount seems to have play in it a little to much im wondering should i just replace the mounts would this solve the problem?,the sound is really bad wen im goin over bumps,does anyone else have this same problem and know what it might be please?/
maddo1983 is offline   Reply With Quote
Old 05-13-2009, 06:58 PM   #25
fuji
fuji's Avatar
Damn!!!! IT WAS the dust covers!!! No more sound now that I fixed it. So much for trusting a shop to install your shocks for you!!!!!
Old 05-13-2009, 06:58 PM   #26
fuji
fuji's Avatar
To get to the dust covers, I had to cut them out of the plastic boot of the original shocks!
Old 05-13-2009, 07:00 PM   #27
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
let's see some pics fuji, or you making me wait for the meet to see my yaris's cousin in person? :P
Old 05-13-2009, 11:30 PM   #28
PETERPOOP
PETERPOOP's Avatar
alright no pics. awesome
Old 05-14-2009, 06:56 PM   #29
CASTREX
CASTREX's Avatar
Yeap, you need to hack the OE plastic dust covers to take the metal spacer out.
I'm glad I could help you!
Now enjoy the smooth ride of the Teins...
Old 05-28-2009, 02:16 AM   #30
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
do you have some sort of pic of this ? im installing super streets on saturday in mine.
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
Old 05-28-2009, 12:14 PM   #31
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
Sounds like your struts are bottoming out. Dampening isn't set right?
Anybody please, are the Tein Basics equipped with adjustable dampening?
Wanted: Forced Induction
Old 05-29-2009, 03:03 AM   #32
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
hey bro , no the basics have a set damping , cant adjust , you will need the super compacts from japan like i got , the got 16 way damping / rebound adjustment
JDMtuner
www.jdmtuner.co.za
Old 05-29-2009, 10:21 AM   #33
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
^^ok thanks!
Old 02-04-2013, 03:13 AM   #34
yariseggvvti
Drives: Yaris Hatchieback
just got my Tein Basis install this past weekend. I got in to the mission in 8 hours. The rear is like a project. I have to custom cut dust cover and cut the rubber in middle to make a hole install that spacer. Turn around the spring seat top on the bottom and bottom goes to top. Now my vehicle can handle the turn but my tires are not.
yariseggvvti is offline   Reply With Quote
Old 02-04-2013, 04:03 AM   #35
david_mackk
Drives: Yaris 5dr LB
^ Almost 4 years. Good job.
david_mackk is offline   Reply With Quote
Old 02-04-2013, 12:01 PM   #36
The rears should be extremely easy, with no modifications necessary.
Maybe you could post some pictures.
Yaris TS lowered on Tein Basics Coilovers CASTREX Yaris TS Talk 9 08-17-2009 01:34 AM
Tein SS coilovers? Thirty-Nine Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 09-07-2007 04:50 PM
Tein Basic Damper Coliey's Vs. Tein S. Tech Springs ToTo Wheels, Tires and Suspension Forum sponsored by The Tire Rack 35 05-07-2007 06:08 PM
TEIN - Basic Coilovers *Now Available* EnduroMTS Sponsors Classifieds Area 4 10-13-2006 03:43 PM
TEIN Basic coilovers C2AUTOSPL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 06-26-2006 02:57 AM
