Old 05-22-2009, 11:20 PM   #19
Tamago
Tamago's Avatar
Drives: UZJ100
Why do some of you insist on using high octane? The Yaris was designed and calibrated to run on regular 87. Using premium may do the same type of long term harm as using regular in a car that requires premium.
And why waste the money?
you don't really understand petrol do you
Old 05-22-2009, 11:27 PM   #20
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
premium in any car wont hurt, using a too low octane rating will cause pinging.
Old 05-23-2009, 08:42 AM   #21
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Octane boosters containing MMT may cause your catalysts to fail prematurely, and can clog them up severely so the engine can't breathe. That reddish stuff you see on the plugs is manganese oxide, and it's a lot worse on the catalyst than on the plugs.
Old 05-23-2009, 09:06 AM   #22
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
Originally Posted by mikenacarato View Post
your wrong, why do you think we cant put race fuel in our cars for extended periods of time...it will burn them up because they will run too hot.
race fuel does not burn hotter
race fuel in a regular engine will make less hp and run cooler. the flash point is to high and the engine will not burn it efficiently
Old 05-23-2009, 10:13 AM   #23
1stToyota
1stToyota's Avatar
There are TSBs out there for using premium in cars that are tuned for 87 octane; Lincoln for example...causes excessive cranking times.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 05-23-2009, 01:28 PM   #24
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
always gotta through that domestic car knowledge in there.....
Old 05-23-2009, 01:51 PM   #25
mchllp925
Darrin
mchllp925's Avatar
Drives: 2008 yaris le h/b
My 2 Cents Worth
Just something I found on the net.
Whether you believe this or not, it may help with this debate on octane.
Octane levels rate the different types of gasoline available. The number signifies the burning properties the fuel will produce when it reaches your engine
. The standard octanes are 87, 89 and 91. The higher the octane rating the cleaner the fuel burns in your engine. Because of the clarity of the fuel, those with higher octane levels burn faster.
For cost effectiveness when gas prices are high, even if you normally use a higher octane, you can safely run your car on 87 octane and see no ill effects. In most cars performance won’t diminish. However, when used on a regular basis, over time there will be some amount of buildup in your fuel injectors. Because it is the lowest grade of fuel, manufacturers have designed all their vehicles to run on 87 octane. Auto makers will recommend that you use premium or supreme in some cars; but realistically the system is designed to run solely on 87 octane.
Both 89 and 91 octanes are faster, cleaner burning fuels that will help reduce and eliminate buildup on your fuel injection system. If you do a considerable amount of driving it would be wise to consider using these on a regular basis, because of the wear and tear to which your engine is exposed. High performance vehicles should be run on higher octane fuel to help keep the engine running in top condition. For example, you can safely run 87 octane in a Ford Escort for the life of the car and not really see any difference. However, if you usually drive a Chevy Corvette, 91 octane will be beneficial to you and the car. It’s safe to say that if you’ve spent that much money on a car you’re going to do everything you can to keep it in tip top shape.
What’s the safe grade for your car? If you do an average amount of driving; meaning you put the normal ten to fifteen thousand miles on your car each year, 87 octane will be fine. As a preventative measure, it’s a good idea to fill up with 89 or 91 octane once in a while. Once a month should be just fine and will accomplish a good cleaning of the fuel injectors in your vehicle. Any buildup will be removed and you may notice a change in performance and fuel economy as well. A good fuel injector cleaner or gas additive will do the same thing. Ask your local auto supply or mechanic to recommend one that suits your car and the performance you’ll want to get out of the treatment. If you choose the additive route, you’ll want to include it once a month as well just as you would a tank of high-octane gasoline.
For people who normally put substantial miles on their vehicle each year whether for work or otherwise, higher octanes will be beneficial to your vehicle. Just as oil changes extend the life of your motor, higher octane fuels help the engine to run smoother and reduce the wear and tear on the motor considerably in vehicles that are used a lot. Buildup from low octane reduces your fuel economy and makes the engine have to work that much harder to accommodate your driving needs.
The owner’s manual for your vehicle will provide the recommendations for your car. If there are any certain guidelines they provide you can follow those as well. Being that your car is the second biggest investment in your life, it’s best to listen to the manufacturer’s recommendations.
mchllp925 is offline   Reply With Quote
Old 05-24-2009, 01:28 AM   #26
Bob Dog
DARK PHASE OF THE MOON
Bob Dog's Avatar
Drives: 07 liftback
I've alomst 25,000 miles over the past two years with never anything but 87 octane. Likely you came across a gas station ( you said you were on a long drive) , other than one of your usual ones, that had contamination in the fuel.
Bob Dog is offline   Reply With Quote
Old 05-24-2009, 09:31 AM   #27
DerFlosser
DerFlosser's Avatar
These threads are getting old.....why would somebody buy an econoncar designed to run on 87 and put in 91 or 93? It's counter-productive and counterintuitive. The car is designed to run on economy fuel. Now...for the question at the top of the thread...likely a coincidence that you have a CEL after changing fuel grade(s).
DerFlosser is offline   Reply With Quote
Old 05-24-2009, 09:38 AM   #28
1stToyota
1stToyota's Avatar
He said premium in any car
2008 Scion xD
Old 05-24-2009, 09:42 AM   #29
1stToyota
1stToyota's Avatar
Yeah, I filled up 2 times in a row with mid-grade, funny, first time I've ever noticed a rough idle.
2008 Scion xD
Blitz Supercharger Sets CEL whooppee777 Forced Induction Forum 13 06-24-2009 02:47 PM
CEL Issue via MAF Sensor, Thoughts? The Architect Performance Modifications 8 03-29-2009 11:50 PM
FS: Sedan Nitto Mid-Pipe w/ CEL Fix Split Items for Sale by private party 37 12-18-2008 12:11 PM
CEL blinking during rev limit hit. ddongbap General Yaris / Vitz Discussion 2 10-01-2007 02:10 AM
Non cat exhaust CEL? CASTREX Performance Modifications 15 01-28-2007 01:22 PM
