Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Hawaii
Old 05-22-2009, 05:24 PM   #1
^ woo hoo!
And the reason why i bash on the blitz supercharger is because
1: its ugly. not my taste
2: it's overpriced for the amount of power your getting
3: peterpoop has it
Still not reason to call it crap, which it is not. It serves a particular purpose in the market, and it does it well.
Old 05-22-2009, 05:26 PM   #2
My Top Four: boost, air/fuel, oil pressure and water temp. then oil temp, then volts (I like to see electrical problems from the cabin when they do happen).
Old 05-22-2009, 05:27 PM   #3
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
so thats my missing link the volts lol nah i run one too
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 05-22-2009, 05:34 PM   #4
battleversiontc
and i swear that the sc peter is running can make more power then what hes making right now on it prolly tuning and fuel issue but ive seen the dynos for the xb's with the power enterprise one makin like 170 and i wouldnt run with out a management system its just dont do it
Old 05-22-2009, 10:09 PM   #5
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
definately can. it just comes with a conservative tune. however, what you mentioned is my near future plans too. larger injectors/throttle body and meth injection....then tune.
thomas: what's with all the bashing on me? I was the first boosted yaris in hawaii, EVER. You like that? Let me know when your boyfriend gives you permission to get more stuff for your car. I like it when other hawaii people do stuff to their car; unlike you.
Old 05-23-2009, 05:11 AM   #6
fuji
fuji's Avatar
Drives: Polar White Yaris HB
I was planning on going pretty mild. Just a bit more kick. Thanks to Gwasabi for the list of parts and to Cali Yaris for the recommended gauges. I would be more than happy with about 130 hp. Just want to keep it simple and drivable.
fuji is offline   Reply With Quote
Old 05-22-2009, 06:13 PM   #7
but you'll race at 20 psi on a base map. Ok, you gotta admit that is at least a LITTLE funny...
Old 05-22-2009, 06:35 PM   #8
battleversiontc
i have 3 maps tuned for this t3 60-1 turbo i have one for 12 psi ,15psi, 20psi i can go further on this turbo i really dont care if i blow it up that would actually be a bonus for me cause then i can drop my spare in and tune back from the last highest setting i had in and tune backwards i dont run t28 or t25 like everyone else for me its either go big or go home. plus to i rather push the limits of this motor since no one else wants to step up to the plate
Old 05-22-2009, 06:27 PM   #9
gwasabi
Drives: 07 Blazing Blue LB
I'm pretty sure the blitz charger can but I still dont like it. alright I'll take it back. It's not crap, just the one peter has is crap lol blitz is a good company i agree though. I rather have the power enterprise one....it looks nicer and peter doesn't have it....
Most Satisfying Crew
Serious Business...
MunkyWurks Garage - 8088488794
gwasabi is offline   Reply With Quote
Old 05-22-2009, 06:49 PM   #10
Go for it, I'm glad someone is doing it!
Old 05-23-2009, 05:21 AM   #11
battleversiontc
you can do 130hp with n/a its not really worth the money to invest into a a turbo setup that will make you 130hp cause its just not worth the time and alot of time buying parts of a used car can be either good or not cause you have to consider milage and shaft play on the turbo and if you have to rebuild so the turbos fresh the cost of that to. but a 6psi setting will prolly do you 150hp or so a 4 psi turbo set up not worth it. if you stick to a gt20 with some tc injectors you can run no management and run you at 130hp prolly at 6 psi. if anything else let me know ive built everything from 1.5l to 2.4l turbos so i can pretty much figure a set up
Old 05-23-2009, 12:56 PM   #12
anonymous user
rarer than JDM -1 of 1!
anonymous user's Avatar
Drives: 07yaris
Did i miss a post, or are you FI guys not really worried about EGT?
It's not what you drive, or how much $$ you throw at the car. Mod the ballast on the front left first!
anonymous user is offline   Reply With Quote
Old 05-23-2009, 01:12 PM   #13
fuji
fuji's Avatar
Sorry, what is EGT?
Old 05-23-2009, 01:26 PM   #14
fuji
fuji's Avatar
Battleversion TC,
What would be awesome is if you could give a quick tutorial on how to approach 130hp naturally aspirated.
Of course the obvious ones are.....
Intake
Free flowing exhaust(I have the same muffler as Peterpoop!)
1ZZ throttle body - I will install it this weekend - god I hope it works!
NST Pulleys
Any other suggestions? Does it involve internal engine mods???
Old 05-23-2009, 03:23 PM   #15
gwasabi
Originally Posted by fuji View Post
Battleversion TC,
Intake
NST Pulleys
you can pop on stage 1 clutch, lightened flywheel, headers, maybe new beefed up internals will help. change out the tb and injectors, new fuel map, do little tuning here and there.
hell if your into something different you can get ITB to make your engine bay look like you have a 300 hp lol
Serious Business...
Old 05-23-2009, 03:43 PM   #16
battleversiontc
exhaust gas temp they arent neccessary because you wont be holding boost for long periods of time cause stock pistons will melt at 1500 degrees youll never get that high
Sorry, what is EGT?
Old 05-23-2009, 01:48 PM   #17
PETERPOOP
PETERPOOP's Avatar
130 N/A!? i know cali yaris and others have gotten around 115whp on a dynojet being NA; it COULD be done. I know it was close when richard was developing his intake manifold. Other than that, noone has come to 130whp.
For the record, I did 133whp on a dynojet on my first pull. After that, my AFR readings made the dyno guys crap their pants. however, that is fixed and soon I'll be adding 1zz injectors with the 1zz TB and probably head back to the dyno before the tune/meth injection. I believe i'll hit 140whp with the addition of just the 1zz injectors and TB on top of what i already have. shoots
ps: thomas, I take it back, you don't have a boyfriend, she's a girl. And I do like you, I really do! :)
Old 05-23-2009, 03:41 PM   #18
battleversiontc
ok heres the two list one will be for boosted and one will be for na
N/A Setup: intake, headers, exhaust, leave stock cat, pulleys, vvti controller, stage 1 clutch, lightened flywheel, intake manifold, throttle body you hit 130 easy cali did 107 with i/h/e pulleys richard did 120 with manifold xd throttle body and no exhaust. if your auto and not manual run a trans cooler and some synthetic trans fluid will act as a lightened flywheel and clutch assembly without 91 octane can run whatevers 87 89 91
VS
Turbo set up: turbo manifold, turbo, piping, injectors, bigger throttle body, high flow cat or delete cat for ultra free flow, exhaust, flywheel, stage 2 clutch, gauges, management or just leave stock tune, bov, boost controller this will prolly put you over 130hp gaurenteed at 6psi with 91 octane gotta run 91
so long story short it isnt worth all that money to run a turbo at 4psi turbos have a certain or minimum level they need to be run at if not then your not really gaining anything thats why most turbo kits are pre set to 6 psi some are higher but you get my point
