View Poll Results: Which wheel? Please help!
1st 8 23.53%
2nd 12 35.29%
3rd 11 32.35%
4th 3 8.82%
Voters: 34. You may not vote on this poll
Old 06-07-2009, 12:08 AM   #19
Jeemee
XBL: Jeemee Ghost
Jeemee's Avatar
Drives: 2008 Yaris LB
Quality wheel gets a plus on the MB. Looks good too IMO.
_________________________________________________
Nitto Axle-Back--Tanabe DF210s--UR 23mm Rear Sway Bar--Penguin Garage 10mm Hub Spacers
Jeemee is offline   Reply With Quote
Old 06-07-2009, 08:41 AM   #20
kimona
kimona's Avatar
Drives: 2014 White VITZ
One MB mesh wheel they have that I really like is this one but is available in 16", but not 17" for some reason. If I go 16", this is a strong possibility too. I also like that it doesn't have the busy looking rivets.
It's only $90 too.
Let me know guys if you'd go with this one over the other 4.
Thanks.
I like it very much, but what are the 16" specs?
Old 06-07-2009, 10:34 AM   #21
Kal-El
Kal-El's Avatar
16X7 / 38 offset
http://www.discounttiredirect.com/di...w=7&vid=010325
I really love this wheel but I need to be talked into 16's instead of 17"s.
What do guys think?
Old 06-07-2009, 11:23 AM   #22
Tamago
Tamago's Avatar
Drives: UZJ100
i think we should campaign to talk you into 15's ;)
Old 06-07-2009, 01:14 PM   #23
Kal-El
Kal-El's Avatar
what are your reasons for wanting 17s? im running 15s and they are perfect for me I see no reasons to go bigger than that 16s borderline , but thats my opinion and ultimately its up to you
I think you should edit your profile where you state your future plans as getting a set of 17's.
I am certainly considering the 16's. The way I see it, if I'm going to spend good money on replacing my stock's, then why go the same size which look small?
Plus, those of you so against 17's, take another look at Kaotic's car (mine is a Flint Mica S sedan too) and tell me you don't think this looks good or isn't necessary.
Old 06-07-2009, 02:15 PM   #24
kimona
kimona's Avatar
16's work very well on the Yaris. With 16x7, ET38, run 195/50/16.
Old 06-07-2009, 02:22 PM   #25
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
re: wheel size - It's all a matter of taste. I'm running 18's and have no complaints whatsoever. It's nice to get feedback from others, but at the end of the day it's YOUR money and YOUR car and YOUR style. Go with whatever pleases you and don't listen to the naysayers.
Old 06-07-2009, 02:54 PM   #26
Black Yaris
der Zeck
Black Yaris's Avatar
It's only $90 too.
Thanks.
Best option IMO, 16 FTW on the Yaris.... you get a larger size to fill the wheel wells nicely with plenty of options for rubber... I would go 205/50R16's
Old 06-07-2009, 02:58 PM   #27
kngrsll
Apexing Egg!!
kngrsll's Avatar
none...
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 06-07-2009, 03:00 PM   #28
kngrsll
Apexing Egg!!
kngrsll's Avatar
http://www.good-win-racing.com/Mazda...t/61-0299.html
Old 06-07-2009, 03:06 PM   #29
kimona
kimona's Avatar
I like 205/50's as well, but with ET38, 195/50's work best.
Old 06-07-2009, 04:03 PM   #30
Black Yaris
der Zeck
all depends upon if he is lowered or not... 205/50R16's work awesome on the wife's unlowered Yaris with +38
Old 06-07-2009, 04:03 PM   #31
Pitt Yaris
Drives: Flint Mica Sedan
I'd say get 15's or 16's. 17's are too rough of a ride.
Old 06-07-2009, 04:59 PM   #32
Kal-El
Kal-El's Avatar
Well, I really think I'll go with 16's. The benefits are cheaper tires, more rubber for rim protection, smoother ride, ect.
I didn't want to spend the money for lowering the car either and it does seem like it is needed if you go with 17 inchers. So those of you with 16's, they look good on stock suspension? And good pics?
Discount Tire Direct shows tire options for the 16's I posted (to fit Yaris) as:
195/55/16
205/50/16 (much more options)
Old 06-07-2009, 04:59 PM   #33
Tamago
Tamago's Avatar
Drives: UZJ100
bigger wheels with proper sized tires doesn't make the car look lower lol
Old 06-07-2009, 05:07 PM   #34
kimona
kimona's Avatar
OEM tyre size is 195/50/16. This works very well. You can go with 195/55/16 if you like. 205/50/16 is a common replacement size tyre, but I don't recommend it on ET38, even on stock suspension, and especially if you're lowered or plan to lower.
Old 06-07-2009, 05:26 PM   #35
Kal-El
Kal-El's Avatar
I'm no expert on offsets. Could you explain a offset of 38? What is the offset on the stock 15" steels? And why do you not recommend the 205/50/16's for this offset? Sorry if these questions seem dumb. Wait, the stocks would have 0 offset, right?
So +38 extends the wheel out 38mm right?
Old 06-07-2009, 05:38 PM   #36
kimona
kimona's Avatar
See here for OEM wheel specs, including offsets:
http://www.yarisworld.com/forums/showthread.php?t=5021
With ET38, your wheel/tyre set-up is moved outward. If you run 205's, you will probably poke out (up front) just a tad. How much you poke will depend on a few factors, including tyre brand (not all 205mm tyres are created equally). If you aren't lowered and don't plan to lower, and you don't mind the poked-out look up front, then run 205's. If you want to keep the set-up flush or just slightly tucked up front, then run 195's. If you're lowered or plan to lower, then definitely don't run 205mm rubber because you'll more than likely have rubbing issues up front.
Whats wrong with Rota's? mastaofdisasta Wheels, Tires and Suspension Forum sponsored by The Tire Rack 172 05-22-2009 11:13 AM
Feedback on these wheels BulletProofAuto Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 06-04-2007 08:09 PM
Buddy Club Wheels BulletProofAuto Sponsors Classifieds Area 8 10-19-2006 06:55 PM
