Old 07-02-2009, 06:46 AM   #19
Bob Dog
DARK PHASE OF THE MOON
Bob Dog's Avatar
Drives: 07 liftback
Originally Posted by camelll View Post
If you think the sway bar made a difference you should get the shocks, struts and springs. You will go from to
TRD shocks, struts and springs with a TRD Sway bar is the same set up I run and the change is amazing. Your handling gos from econbox (good econbox) to mild sports car. Don't blow your money on an exhaust system until after you've done the suspension!!!!
Bob Dog is offline   Reply With Quote
Old 07-02-2009, 07:32 AM   #20
auxmike
auxmike's Avatar
Originally Posted by Bob Dog View Post
TRD shocks. struts and springs with a TRD Sway bar is the same set up I run and the change is amazing. Your handling gos from econbox (good econbox) to mild sports car. Don't blow your money on exhaust ansystem until after you've done the suspension!!!!
Ok then, get the suspension! The masses have spoken.
I DO love that sway bar though....
Old 07-02-2009, 10:15 AM   #21
Klink10
Klink10's Avatar
After the suspension upgrade, start thinking about weight reduction. Always a cheap mod. I like mine without the rear 60/40 and the light weight battery. Just a thought.
Old 07-02-2009, 05:22 PM   #22
Cutie Pie #2
Drives: 2014 Honda CR-V LX
I ended getting Tokico blues shocks and struts from Micro Image, and talked to my local toyota shop (not dealership) Weikle's specialty for Toyota's a shop in PA if any one is interested a very good place to take Toyota's. They are installing them for $75. I didn't get springs because roads around here are really bad, maybe later. BTW would springs make any difference? just wondering.Thanks everyone for your input.
Cutie Pie #2 is offline   Reply With Quote
Old 07-02-2009, 08:17 PM   #23
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
Springs will make a difference and reduce the roll in the car...
I have H&R lowering springs on mine, nothing else for suspension setup, and i could feel a difference right away from stock springs....on the freeway i had minimal roll changing lanes quickly in n out...very cool to lower. Go with H&R lowering springs for the Yaris, they are a bit expensive but they dont sag like other springs....I had mine on for more than a year now, and they are still strong :)
Good luck~
Old 07-08-2009, 09:57 AM   #24
Cutie Pie #2
Good luck~
Do I need to get lowering springs for Tokico blue stocks and struts that are on their way to me.
Old 07-08-2009, 11:53 PM   #25
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
So what's the difference between the KYB's and Blues?
Old 07-13-2009, 02:55 PM   #26
Cutie Pie #2
Well I got my shocks and struts on today, and well it was a little more than orginally said, it was $180 all together instead of the $75. Besides that the car rides soo much better, I thinK. Here's some pictures of the blues:
Oh and then being so happy about my car, I got a speeding ticket, 67 in a 55 so I'm mad about that because I have a PA CDL, I was in MD, so I all I have to do is pay the fine ($90).
Old 07-13-2009, 03:05 PM   #27
scape
scape's Avatar
Drives: 2007 Yaris Hatchback
I was thinking about going with the H&R springs, I think they keep the back up a bit higher like in stock form, just lower. that appeals to me ;d
how stiff would you say they are?
Old 07-13-2009, 03:13 PM   #28
Cutie Pie #2
Much stiffer than stock ones, ride is more sporty.
Old 07-13-2009, 04:07 PM   #29
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
Cutie Pie - You dont need to get lowering springs with the Tokico shocks/struts, but mounting the lowering springs w/ those shocks helps stiffen up the car a bit more when switching lanes rigorously on the highway :)
Scape - So far the pics that Kaotic and others have taken of my car, it kind does look like that rear H&R springs to make the back end look look a bit high than other springs, but overall from a side view they dont, imo~
They are very strong (just ask contraband, he's seen them since i got them installed). I have had them on since, spring 2008 :)...my friend, she says she can feel every crack my car goes over on the freeway...lol
http://www.yarisworld.com/forums/sho...=17449&page=12
Blue hatchback...theres some more from a 2008 meet if you search it...
Old 07-13-2009, 04:24 PM   #30
Cutie Pie #2
[QUOTE=Kioshi;351555]Cutie Pie - You dont need to get lowering springs with the Tokico shocks/struts, but mounting the lowering springs w/ those shocks helps stiffen up the car a bit more when switching lanes rigorously on the highway :)
I decided to just to do the shocks and struts, I didn't want to lower car any (I like the height of the car ) car rides fine.
Old 07-13-2009, 06:31 PM   #31
auxmike
auxmike's Avatar
Can the stock springs handle the stiffer shocks? Are there stock height springs that are firmer?
Those shocks match the car quite well, BTW!
Old 07-29-2009, 05:02 PM   #32
Cutie Pie #2
Just went ahead and ordered the TRD muffler from sparks, I will post pics when it gets on. That's it I'm done with mods for now. And going to try installing it myself, any suggestions on installing muffler would be nice!
Old 07-30-2009, 07:46 AM   #33
MUSKOKA800
MUSKOKA800's Avatar
Yeh the TRD are just rebadged KYB's , i have the part number's written down ,in my work shop , will find them and post up here if you want .
Or you could go with Tokico Blues as per Garm.
TRD Sportivo Dampers are indeed KYB bodies but with TRD valving spec's.
Far from the stock performance of the OEM replacement KYB GR-2's which share the same outer body.
Old 07-30-2009, 08:39 AM   #34
if you ever make it out to a meet, i want a ride in your car
Old 08-04-2009, 01:27 PM   #35
Cutie Pie #2
New TRD muffler is installed!! I installed it myself, it took me about 30 mins.
So, I got all the mods, I want to do for now. I really happy with the Tokico Blues, they're great, along with the TRD muffler.
My latest mod and last mod for awile due to stupid economy and hour cuts.... YarisSedan Cosmetic Modifications (Exterior/Interior) 8 11-18-2009 05:19 PM
manual transmission: to mod or not to mod? tomato General Yaris / Vitz Discussion 34 03-08-2009 10:40 AM
Final Got My 2ND Mod For My Yaris! pp.sweet DIY / Maintenance / Service 10 09-24-2007 02:52 PM
ait resistor mod pigpenracing Performance Modifications 24 08-25-2007 11:14 AM
Toyota Yaris S Mod jamal1984 Performance Modifications 10 01-07-2007 02:48 PM
