Old 08-06-2009, 08:41 PM   #19
mojoyaris
Ecurie Snoopy Lives
mojoyaris's Avatar
Drives: Jojo
The engine is setup to run lean. I think it's the ECU doing it's bit.
after running the car hard, it just runs out of fuel. Kinda like vapour lock.
The car comes back to life. It's like the ECU and the fuel pump is not able to keep up with the flow that is needed when running at VVTI all the time.
Sponsors and Organizations:
Toyota Rally Canada
Yokohama Tire Canada
Western Canada Rally Association
Ecurie (Team) Snoopy Canada, racing since 1966
mojoyaris is offline   Reply With Quote
Old 08-07-2009, 03:10 PM   #20
jkuchta
Drives: 2007 Yaris hatch (red)
Try water-wetter....I have it in mine, and I've done trackdays WFO in 2nd-4th gears with no problems...I've never seen water temps go above 190 in the track, even after a 25 min. session at the streets of willow spent almost entirely above 5,000rpm.
jkuchta is offline   Reply With Quote
Old 08-07-2009, 05:30 PM   #21
CpKi1g3
High speeds are fun...
CpKi1g3's Avatar
Drives: 07' Polar White sedan Base
Send a message via MSN to CpKi1g3 Send a message via Yahoo to CpKi1g3
Originally Posted by mojoyaris View Post
Been away for awhile.
The car runs between 4500 rpm and 6700 rpm constantly at the track.
With the stock thermostat it over heats after a 15 minute hard run on the track and since the car runs lean, it seems to not get enough fuel.
I installed the TRD thermostat and better radiator cap for pressure and although it doesn't overheat, it will cut out when running the car hard, turning the car hard etc.
Basically if I run it 8/10's to 9/10 speed this way it will cut off the fuel or there is fuel starvation.
When I let off the throttle and drive it slowly, it will go back to normal and I can run again, but not for long. I basically have to give it a cool down lap before running hard, but this can be a problem when I'm timing a lap or something.
On day to day driving there is no problem. Only when driving at a Solo 1, time attack or track day. Especially on smaller tighter courses where I'm doing hard 2 to 3rd gear shifts.
I've got a few months to figure this out before I decide to enter the car in the Targa or not.
I'm thinking about getting bigger fuel pump. redo the air fuel management mapping
and bigger/better injectors.
just take off the thermostat my friend did it on his supra and ran much cooler.
CpKi1g3 is offline   Reply With Quote
Old 08-16-2009, 01:17 PM   #22
mojoyaris
Ecurie Snoopy Lives
mojoyaris's Avatar
Drives: Jojo
Overheating is not the issue anymore. Not with the TRD thermostat.
It's the fuel cutout. This should be fixed later on.
Thanks everyone for their input.
Toyota Rally Canada
Fuel Efficiency and the Yaris BailOut Fuel Economy Forum 327 01-02-2026 11:44 PM
Last Fuel Bar andaconda Fuel Economy Forum 37 04-29-2009 02:35 PM
Low fuel light falkor_99 General Yaris / Vitz Discussion 35 08-24-2007 03:20 PM
