Old 08-09-2009, 09:48 PM   #19
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
Originally Posted by DerFlosser View Post
KW coilovers are the best street coilovers I have ever used. Super comfortable....
Where did you find em?
Originally Posted by sw07gt
Old 09-21-2009, 10:36 PM   #20
IsLNdbOi
IsLNdbOi's Avatar
So if we install springs with the stock shocks, do we need bump stops? Do all these new springs come with bump stops?
Old 09-21-2009, 11:58 PM   #21
Lafiro
Drives: 06 Yaris Sedan
Agreed.
If you use stock shocks with lowering springs, then yes you must cut the bump stops. Search you will find the answers to that with pictures.
If you get coil-overs, then its already set, and no modification other then probably height/stiffness need to be made.
Old 09-22-2009, 12:03 AM   #22
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
Coilovers are really about performance and adjustability, not comfort. I've never ridden in a C/O vehicle that was not stiff-as-hell, but that's the point; flat cornering=better control/grip. Its expensive, but people pay for it for a reason; it can't be matched by springs/struts. On the other hand, you can get a big handling improvement with quality springs, and your oem struts will last a few years, depending on the drop. You will still notice a decrease in ride comfort, and its greater with lower drops and stiffer springs, but every aftermarket spring is probably stiffer than stock. Same goes for struts/shocks: aftermarket versions will range in stiffness (why can't we get AGX's???) and will improve handling, but ride comfort will decrease.
If you mainly want the car to look cooler and handle a bit better but still be a daily driver street car in the real world, get some name-brand lowering springs. Cheap, easy, effective, REVERSIBLE (in case you hate them).
Old 09-22-2009, 12:51 AM   #23
FunctionSpec
Super Newbie
FunctionSpec's Avatar
Drives: 2007 Yaris Liftback White
Tein Basics are probably the most comfortable coilover setup for the Yaris, IMO. It's a mild setup as far as spring rate and shock dampening. It has enough stiffness to keep from bottoming out and rubbing with 4 people in the car even when riding about 2.25in lowered. Also provides a nice upgrade in handling performance. Had mine for about 40K miles and still running strong.
Only other coilovers I can compare to are BC Racing which are a lot stiffer then the Teins Basics and handle way better but they were not comfortable on the street for me.
Oh yeah another thing is that one persons view on comfort can very a lot compared to someone else's view on comfort. My comfort rating is set pretty high so I like things to be pretty comfortable, so when I say the Teins are comfortable, they really are, lol.
On getting a spring and shock combo, they vary as far as comfort and performance because different springs mated to different shocks would give different performance. But overall they should provide decent performance, comfort, and drop. But for you, I would just recommend a spring and shock combo over coilovers unless you get the Tein Basics. All other coilover brands are pretty much for flat-out performance and adjustability, better suited for track junkies.
Main difference is price. 500-600 for decent spring/shock combo. 800-1000 for decent coilovers and 1400+ for some badass ones, lol
FunctionSpec is offline   Reply With Quote
Old 09-22-2009, 02:07 AM   #24
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Springs don't usually come with bump stops AFAIK. You may want to invest in a new set since a few brands require you to cut the bump stops a bit. I had to cut them for my NF210s.
Old 09-22-2009, 02:09 AM   #25
IsLNdbOi
IsLNdbOi's Avatar
Where can we purchase extra bump stops? Are there any that are already modified for use w/ lowering springs and stock shocks?
Old 09-22-2009, 02:13 AM   #26
tk-421
tk-421's Avatar
Drives: 5D-07-LB
http://fatcatmotorsports.com/FCMstops_Yaris.htm
Old 09-24-2009, 12:24 AM   #27
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Coilovers FTW if you have the cash and don't mind adjusting them every time you get on/off the track.
Otherwise lowering springs are way cheaper and do offer some of the same benefits, but are mainly just to make the car look good.
Old 09-24-2009, 12:27 AM   #28
IsLNdbOi
IsLNdbOi's Avatar
I'm not mechanically inclined. What's involved in adjusting coilovers?
What about modified bump stops? Would I need those as well for coilovers?
Old 09-24-2009, 12:31 AM   #29
Tamago
Tamago's Avatar
Drives: UZJ100
adjusting the height = taking weight of the strut, turning the perch up or down (and counting the number of turns) and locking in place
adjusting strut bound/rebound should be able to be done from the top or bottom of the strut.
Old 09-24-2009, 12:31 AM   #30
Tamago
Tamago's Avatar
Drives: UZJ100
why would you adjust them up and down?
Old 09-24-2009, 12:35 AM   #31
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Here's something I dug up by searching the googlewebz:
http://au.toyotaownersclub.com/forum...dpost&p=297275
Lots more here: http://lmgtfy.com/?q=adjusting+coilovers
Old 09-24-2009, 12:38 AM   #32
IsLNdbOi
IsLNdbOi's Avatar
Wow, you need another alignment whenever you adjust the height of the front wheels? I don't have any of the gear to do this.
Maybe its the lowering springs for me then. Or I could just get the coilovers, leave them at one height and keep them just to say I have coilovers.
Old 09-24-2009, 12:40 AM   #33
tk-421
tk-421's Avatar
Drives: 5D-07-LB
... or get non-adjustable coilovers (cheaper and less hassle)
Old 09-24-2009, 12:43 AM   #34
Tamago
Tamago's Avatar
Drives: UZJ100
the point of coilovers is a corner balance (sometimes called corner weighting)
all other reasons are "just to say"
Old 09-24-2009, 12:45 AM   #35
IsLNdbOi
IsLNdbOi's Avatar
So coilovers + rear sway bar would improve the handling of my Yaris by a large margin?
Old 09-24-2009, 12:49 AM   #36
Tamago
Tamago's Avatar
Drives: UZJ100
good struts and springs are far better than "budget" coilovers like Tein, Megan, D2, Ksport.
what to look out for when installing lowering springs songa Performance Modifications 34 09-15-2012 03:29 AM
tanabe nf210 vs. TRD lowering springs?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 37 01-23-2012 11:00 PM
Lowering Springs - Questions ~ AGAIN ~ jaspie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 01-16-2007 12:23 AM
Will putting new lowering springs damage original shock absorbers in the long run? Joel Leong Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 06-07-2006 08:30 AM
