Old 07-31-2009, 03:51 PM   #19
There's no fuse in the other place that it would be for a certain config of sedan, so that must be it. Did you pull it and check it closely (ideally with an ohm meter)?
Old 07-31-2009, 03:53 PM   #20
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
No, But when a fuse goes out it brakes and that fuse its still new
Originally Posted by sw07gt
Old 07-31-2009, 03:55 PM   #21
Check the HAZ fuse as well - It is in the under hood fuse box on the driver's side.
Old 07-31-2009, 03:57 PM   #22
JumpmanYaris
USAF_SrA_E-4
Ohh Never tot of dat
Old 07-31-2009, 03:59 PM   #23
If you have brake lights, but not turn signal lights, the HAZ fuse would be the culprit.
Old 07-31-2009, 04:09 PM   #24
JumpmanYaris
USAF_SrA_E-4
Ahhh HAaaaa Found the f-er woohoooo i took another fuse same fuse put it in that same spot and voooillaaaa all working now what i need is to see where can i buy it
Old 07-31-2009, 04:13 PM   #25
I don't know about down your way, but up here I found an assortment pack of the fuses at Advance Auto Parts (for $7)
Old 07-31-2009, 04:16 PM   #26
JumpmanYaris
USAF_SrA_E-4
cool i will check there sincce i got something to return there anyways thanks a million dude
Old 07-31-2009, 06:18 PM   #27
JumpmanYaris
USAF_SrA_E-4
You know what I forgot the under the hood it actually has some spare fuses so i didnt have to buy any, Now in a difrent topic I started the car and the accelerator wasnt working at all it was wierd I shut it off and started it back up and still nothing I did it again and this time it work BUT now the Check E. Light its up I SWEAR ITS ALWAYS SOMETHING.
Old 07-31-2009, 10:17 PM   #28
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
did you reinstall all the fuses you pulled and make sure they are seated correctly?
Old 07-31-2009, 10:38 PM   #29
JumpmanYaris
USAF_SrA_E-4
I sure did the light is off now but that was wierd how it didnt let me accelerate the car so its all good to GO now and this Thread can be deleted
