Old 10-06-2006, 10:39 AM   #19
ItsMyDaily
The LittleBastard
ItsMyDaily's Avatar
Originally Posted by ttufrosty
I am going to put in a grounding Kit into both my Yaris(manual) and my wifes Scion Xb, really think it will help out her Xb more than my Yaris. Hers is an auto, and from what I see it going to help out her car quite a bit.
Couple questions though..will the groundkit affect my warranty? does it help to attach the wire to more places than suggested in the DIY posted in this forum?
If a dealer tells you they won't service under warrenty because you have the grounding kit then make sure you kick the guy in the nutz!!!! No way it will void warrenty. I looked and saw that they didn't get to extensive with this car as far as making it well grounded. I think ththe yaris will benefit from it grealty. You can add as many wires as you feel you need. The more the better actually, but after some point more may be to much.
the points I'd focus on getting grounded would be.....
1. engine head
2. intake manifold(I'd point to throttle body)
3. tranny
5. alternator
6. engine block
that's what most kits will tell you to mount to, i'd also include...
7. starter
8. head lamps
Yaris Mods:
20% Tints
Ground wires
2007 Toyota Yaris Liftback - Current
2004 Honda S2000 - Sold
1986 Toyota Corolla SR5 - Sold
DIY: Groundwire Kit
ItsMyDaily is offline   Reply With Quote
Old 10-06-2006, 01:10 PM   #20
jeff_o
Drives: 07 Yaris
Send a message via ICQ to jeff_o Send a message via MSN to jeff_o Send a message via Yahoo to jeff_o
so that's how it should work... it's just like making multiple wire connections from different areas of engine bay to battery's negative. sort of like stabling static signals in the engine bay... did i say it right?
also positive to alternator? are car alternator's powered by 12V?
i wonder why doesn't the toyota release cars with grounding kits OEM? If it is just as simple as doubling grounded wires why the heck don't they do it>?
jeff_o is offline   Reply With Quote
Old 10-06-2006, 01:54 PM   #21
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
to save $$
will work for parts
Old 10-06-2006, 02:45 PM   #22
ItsMyDaily
The LittleBastard
ItsMyDaily's Avatar
Originally Posted by vodkalush
to save $$
that and because they also want to be able to sell teir trd ground kits
Yaris Mods:
20% Tints
Ground wires
DIY: Groundwire Kit
Old 10-06-2006, 03:10 PM   #23
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
I wish Import Tuner had put that article online. Maybe I can scan it and post it and claim liberal use of the Fair Use Doctrine.
Old 10-06-2006, 04:11 PM   #24
ttufrosty
Sorry to sort of hijack this topic, but when making the points do you wire them from point to point or wire all back to the negaitve terminal.
ttufrosty is offline   Reply With Quote
Old 10-06-2006, 05:47 PM   #25
ItsMyDaily
The LittleBastard
ItsMyDaily's Avatar
I've seen it done two ways.
1. You wire everything back to the negative terminal.
2. You wire one after the other (sort of like one long ground wire that connects to different components as it goes along.)hmmm so what i mean is if you were to connect one from the battery to the head then you would connect the second wire from the head(same point you connect the first) and go on to your next location. and so on, and so on.
hope that makes sense?
Best way is to wire to negative terminal of battery.
Yaris Mods:
20% Tints
Ground wires
DIY: Groundwire Kit
Old 10-07-2006, 09:39 AM   #26
Violin
Violin's Avatar
I don't know how much use this is but...
Old 10-07-2006, 11:00 AM   #27
ItsMyDaily
The LittleBastard
ItsMyDaily's Avatar
nice find. interesting article.
Yaris Mods:
20% Tints
Ground wires
DIY: Groundwire Kit
Old 10-07-2006, 11:21 AM   #28
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
hey guys, during the next week or so, ill be buying a grounding kit of ebay.
Though, this one has 6 wires excluding the wire that connects to the negative part of the bat. Just Wondering do i need 8 wires when i think about it, i think i need about 4 or 5?....
Old 10-07-2006, 12:02 PM   #29
ItsMyDaily
The LittleBastard
ItsMyDaily's Avatar
depends on how many points you feel you want to ground. I think 8 is enough. You can't go wrong with even having to many grounds.
Yaris Mods:
20% Tints
Ground wires
DIY: Groundwire Kit
Old 10-07-2006, 05:01 PM   #30
Kitt
Kitt's Avatar
So this ground kit can be DIY? i just need to buy the wires and know where to plug them?
Old 10-07-2006, 07:10 PM   #31
vodkalush
I drive a yarrrris
vodkalush's Avatar
its must def a DIY and depending on what gage wire you get and how many points can range from $20-$80 (I got 6 gage wire, corrosive resistant ends, heat shrink, crimpers for $42)
will work for parts
Old 10-07-2006, 07:20 PM   #32
Kitt
Kitt's Avatar
Oh i see and how do u connect them to the ignition coils? im planning to do that to mine, it's the same engine anyways... do u have some pics about it?
PS you can also connect a cable direct from the battery to a relay switch that can be activated by the car stereo remote cable or any other remote signal cable, the idea of the remote is to avoid overcharging the stereo remote plug...
Old 10-07-2006, 08:24 PM   #33
Idjiit
5 Stars, Bitches
Drives: Prius, Silver Yaris Liftback
Learn how to launch properly and hit your shift points correctly.
Idjiit is offline   Reply With Quote
Old 10-08-2006, 01:20 PM   #34
jeff_o
Drives: 07 Yaris
i don't think you have to connect it to the ignition coil... just the negative terminal will do... correct me if i'm wrong though.
also, is there a hard rule which components/parts of the engine bay that you should ground? or just ground whatever you feel grounding?
Old 10-08-2006, 01:28 PM   #35
ItsMyDaily
The LittleBastard
ItsMyDaily's Avatar
^ no you can ground whatever you feel you want to. it's only suggested that you ground certain points(engine head, intake mani, tranny, eyc.) for best benefits. Other then the suggested areas it really doesn't matter what you ground.
Yaris Mods:
20% Tints
Ground wires
DIY: Groundwire Kit
Old 10-08-2006, 04:25 PM   #36
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Correct!
There are 3-4 important points that you have to connect.
stick vs. auto acceleration abcando General Yaris / Vitz Discussion 36 04-08-2009 08:06 AM
