#19 |
What I thought I'd do was
Drives: 09 Yaris Sedan Join Date: Aug 2009
I figured it out for the sedan.
Open the trunk and remove the 2 rubber plug things that hold the cloth cover to the inside of the trunk lid. Pull down on that slightly so that you can see the 2 wires that go to the bulbs for the lag lights. Twist, but not too hard, and it should move about 1/4" or so. If it seems to be taking a lot of force twist it the other way. Once it moves the 1/4" or so it should just fall free, then you can disconnect the bulb housing deal from the wire and pull the bulb from the housing. It took considerable force to get the bulbs out for mine. Then you can put the new bulbs in and you are good to go! I'll take pictures of mine tonight when it gets dark :) |
#20 |
![]() ![]() Drives: new vitz Join Date: Apr 2010
hi. if you can explained me how to remove the dome lights?
#21 |
![]() ![]() Drives: YRX Join Date: Mar 2010
Great thread, thanks for the info & those led bulbs really make a big difference!!!!!
#22 |
Hi, I explained everything in post #9: http://www.yarisworld.com/forums/sho...49&postcount=9
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 12:59 PM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 01:50 AM |
| Led taillight bulbs | casterqc | Cosmetic Modifications (Exterior/Interior) | 27 | 09-15-2007 01:48 AM |
| Side Turn Signal Lights | bigsky2 | Cosmetic Modifications (Exterior/Interior) | 15 | 08-24-2006 06:06 PM |
