View Poll Results: Which HID kit would you be more intereste in?
HID with halogen high beam for about $80 6 9.52%
HID with true high/low beam for about $20 more 57 90.48%
Voters: 63. You may not vote on this poll
Old 08-08-2009, 03:40 PM   #19
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
would these have a glare shield that allows using with the reflector optic housing?
Check out my Build thread:
Old 08-08-2009, 03:49 PM   #20
kioshi, not sure what you mean, but if we were talking by PM, that's a losing battle for me - sorry!
ezhacker, dunno what you mean, these go anywhere an H4 bulb goes?
Old 08-08-2009, 09:08 PM   #21
xbalance
Drives: stock
i think for me will get another set HID....
as my old car i have use 55w ballast with 55w hid bulb ...the output light is very far...
like a beam of line....
xbalance is offline   Reply With Quote
Old 08-09-2009, 10:06 AM   #22
DerFlosser
DerFlosser's Avatar
Garm,
Would the use of this HID kit allow me to retain my DRL module (for fog lights) while, at the same time, allow the high beam indicator to work in the dash panel? My biggest hang-up so far in purchasing an HID kit is one that will allow me to retain stock features such as the two thing mentioned
DerFlosser is offline   Reply With Quote
Old 08-09-2009, 11:57 AM   #23
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
LOL....it was PM... nonetheless, if you can get these to your shop before the Saturday of the Marin Meet, i will buy them off of you at the meet....hard cold cash
Old 08-09-2009, 02:29 PM   #24
^ mmm, gold pieces?
derflosser, an HID kit just plugs in line where the headlight bulb goes. As far as I know (I'm not an electrical guru), this should have no effect at all on any other function (as long as it gives low and high beams).
I'm sure someone else can answer this better than I can.
Old 08-09-2009, 09:31 PM   #25
MGargano
Drives: 2009 Yaris Hatchback
^ mmm, gold pieces?
I installed the XenonVision bi-xenon kit in my '09 with HID fog lights and OEM fog stalk and have retained OEM control over the fog lights (including dash indicator), but lost the blue hi-beam indicator in the instrument cluster.
MGargano is offline   Reply With Quote
Old 08-10-2009, 10:36 AM   #26
DerFlosser
DerFlosser's Avatar
Yeah...that is what I was referring to. Does the Halogen Hi-Beam and xenon low beam configuration by Xenon-Vision retain the high Beam indicator in the dash? The only negative to this configuration that I know of is that the light cutoff is not as good as with the bi-xenon.
Old 08-10-2009, 12:50 PM   #27
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
^ mmm, gold pieces?
haha, we have 49 votes on these HID kits....WOW...
A few more days till they arrive at your doorstep right?
Old 08-10-2009, 12:54 PM   #28
kargoboy
kargoboy's Avatar
Drives: '07 Yaris Sedan/'03 Protege
Originally Posted by DerFlosser View Post
Garm,
The DRLs should not be affected.
Depending on the wiring setup I could see how this might happen, since all HID kits are not the same. However, it is also possible you've wired them wrong. H4 H/L (Xenon-Low/Halogen High) kits plug into your wiring harness
the same way the stock bulb would. One connection to control each bulb.
If it's wired correctly there should be no difference from stock.
However, some Bi-Xenon kits use a single bulb which moves from low to high position and it's possible that you could lose the high-beam indicator, depending on the wiring configuration.
IMHO, Bix-Xenons are complete overkill. I have been running HIDs for several years and they light the road so nicely that I only use the Highs to flash.
kargoboy is offline   Reply With Quote
Old 08-10-2009, 02:50 PM   #29
ezhacker1
ezhacker1's Avatar
are these projectors or reflectors? because of how light scatters badly on non-modified hid bulbs in the oem headlight housing.
Xenon-Vision HID Conversion Kit - $120 Shipped/$160 Shipped for Slim Ballast phu@xenon-vision Sponsors Classifieds Area 8 03-06-2009 02:33 PM
KLight HID Conversion Group Buy!! $165.00 shipped!! JRT lighting Sponsors Classifieds Area 4 11-20-2006 10:47 PM
