Old 10-11-2009, 02:01 AM   #19
darkmoon87
darkmoon87's Avatar
Drives: 08 Yaris
i got used to starting without shuddering while giving the least amount of gas pedal action, but holy fuck...when I am in reverse gear it shudders like mad unless I give it a lot. lol...
RIP Yaris, I will miss your superb handling a lot.
darkmoon87's picture thread
http://www.yarisworld.com/forums/showthread.php?t=10013
darkmoon87 is offline   Reply With Quote
Old 10-11-2009, 02:12 AM   #20
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
Especially if you got (had) all 3 NST Underdrive pullies
I took mine out and it shudders less in reverse when i forget to gas more..
Old 10-12-2009, 02:58 PM   #21
SaerinRhoe
'09 Yaris
Drives: '09 Yaris
My liftback w/ manual just started this in the last month and it's very intermittent. The first time I noticed it was when it was raining so I thought that had something to do with it but I've noticed it when the engine/transmission is cold or warm and when the weather is wet or dry.
S.R.
2009 Yaris 3-Door Liftback MT Black Sand Pearl
SaerinRhoe is offline   Reply With Quote
Old 10-12-2009, 03:23 PM   #22
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
I agree with the previous posts that this seems to be related to clutch-engagement timing and rpm's rather than a design or clutch flaw. I've had no problems in either gear in 16,000 miles.
Old 10-12-2009, 04:03 PM   #23
tomato
tomato's Avatar
I don't get the shudder but Yaris's 1st and reverse are horrible IMO, 1st especially is really touchy. OK, maybe not horrible but not the greatest.
To engage smoothly in 1st, I find that I need to give it a little more gas than I would in another car.
Old 10-13-2009, 03:45 AM   #24
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
main cause DBW , not enough power to get the thing rolling. just give a tad more gas and the shudders disappears
For the reverse shudder, I learned slowly let out the clutch, and gas a bit more at the same time. That helps for a smooth reverse. Yeah it seems like you will be clutch burning, but very little to even make an impact....
+1 for both. Also I find that if I start in 2nd and give it a little more gas the engagement has to be alot slower, which makes it much smoother (unless you're starting uphill).
It also helps to make sure the car is at a dead stop before throwing it in reverse. Puts less resistance on the clutch and avoids the embarrassing scraping sound
Old 10-13-2009, 04:16 AM   #25
ddongbap
Doesn't make sense though. The revs jump to the same point on the RPM gauge. Still shudders when its cold, and stops when its warm.
Old 10-13-2009, 04:35 AM   #26
SilverBack
Joey
SilverBack's Avatar
Like I said, drop the clutch much more slowly
I'm sure alot of other manual cars have the same issue, just like the sluggishness before the engine warms up
Old 10-13-2009, 01:03 PM   #27
kargoboy
kargoboy's Avatar
Drives: '07 Yaris Sedan/'03 Protege
That is a different problem, lots of cars experience a bit more of a clutch chatter when cold. The 2003 Protege which I also own is notorious for it.
The OP never said it only happened when it was cold, at least not that I saw.
That leads me to believe it's driver error, not a component flaw.
kargoboy is offline   Reply With Quote
Old 10-14-2009, 01:28 PM   #28
AZflagstaff
Drives: 2010 Yaris 5dr LB Manual
I noticed the same thing in my 2008 5speed Sedan, more so in reverse. I had to let off the clutch very slowly and really give it some gas to reverse w/o the car shaking and jerking. So really, I had to reverse with some speed, which isn't always possible when backing up. I just traded the sedan in for a 2010 5dr 5speed and starting off in 1st and reverse is much more smooth, as is shifting in general. I don't know if it's something Toyota improved since 08 & 09 but I am pleasantly surprised.
AZflagstaff is offline   Reply With Quote
Old 10-14-2009, 02:17 PM   #29
frownonfun
frownonfun's Avatar
yeah i wouldn't think it's a clutch flaw as i have the TRD clutch and i still have the shudder in 1st and reverse.
to avoid the shudder i just gun it in 1st gear and try not to even use reverse if possible. like others have said, it does seem that 1st shudders a bit less when the car has had time to warm up but doesn't help the shudder in reverse.
I crush you like tiny clown car, because you are clown, yes?
Old 10-15-2009, 12:56 AM   #30
advocate
Drives: car
Happens in first but not in reverse. I usually just throw the clutch back towards the floor, jam the gas, and release much faster
problem solved
Old 10-15-2009, 01:58 AM   #31
Bob Dog
DARK PHASE OF THE MOON
Bob Dog's Avatar
Drives: 07 liftback
If you are used to driving a 5 speed, it goes away just as quickly as you can learn to properly feather the Yaris' clutch
Bob Dog is offline   Reply With Quote
Old 10-15-2009, 09:56 AM   #32
ddongbap
True that.
Thats assuming hes a bad driver, which you couldn't possibly know for fact.
Old 10-15-2009, 10:23 AM   #33
scape
scape's Avatar
Drives: 2007 Yaris Hatchback
my car is a pain to put in reverse, very unforgiving compared to any other gear; even at complete standstill it sometimes won't drop into gear properly, or worse if I'm rolling even an inch you hear it scratch and chatter as it engages. once it is engaged, it's fine and dandy and feels solid.
in the morning, my first gear is very loosey goosey and does not grab well, but what I think the OP is experiencing is that the clutch not being fully engaged into position, and what's happening is probably slipping as you rev out expecting it to catch. I ride first gear partially engaged for a second or two, which seems to help (and I don't rev out hard unless I know it's fully engaged, and you'll know because if it isn't it will chatter and shudder like that or you'll have seemingly less pickup and smell hell for the next few minutes).
Old 10-15-2009, 11:13 AM   #34
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
I just hate the Yaris' clutch. Way too light and just horrible. You definately need to rev it more in first gear than any other car i've driven. I can't tell you how many times I've stalled it... grrr.
Colin Chapman disciple
Old 10-15-2009, 11:50 AM   #35
AmyV
she was an American girl
AmyV's Avatar
Drives: 2008 Yaris HB, 67 Fairlane 500
Send a message via Yahoo to AmyV
See, I never have a problem with stalling or anything. I am kinda known for flying in my Yaris... even from a dead stop. I get a shudder, feels like tire shudder or maybe even a rev limiter kicking in, but I'm not high enough to have that!!! I usually let my foot off the gas for a quick second and everything 'catches up' and evens out. I've had the car for more than 34k miles. Did it from day 1, still does it now. Don't know if that is the same problem that any of you guys have been having.
Overall, doesn't bother me too much though.
And I guess I am a lucky one... no probs in reverse.
AmyV is offline   Reply With Quote
Old 10-15-2009, 12:01 PM   #36
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
try putting it in 1st gear first, then going to reverse.
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 05:20 PM
1st Gear Revs... Masteraal General Yaris / Vitz Discussion 9 09-30-2007 10:22 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 11:34 AM
clicking into first gear tekmoe General Yaris / Vitz Discussion 9 11-01-2006 02:44 AM
