Old 09-07-2009, 04:30 PM   #1
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
confirming that the LB and sedan use exactly the same bulb (H4) and that the bulb provides both lo and hi beam lighting.
I'm going to play with my extra set of headlights this week and see about that projector fitment. Seems to me an H4 opening is the same no matter what housing it's in.
PeterPoop, closeup pics of the opening in the headlight housing for the H4? Does Brian have pics of this?
Sorry no pics of just the hole of the housing for the H4 bulb. Only the pictures of me holding up the projector threads trying to get it into the hole.
I would think the hole in the housing would be the same, but for some reason, mine isn't. Unless my headlights are a lemon set, I assume the Liftback's headlight housing hole are a tad bit smaller than the sedan.
Hopefully you can confirm one or the other when you mess around with your headlight housings.
Don't forget that I didn't have enough thread on the projector after putting it in the h4 hole to fit the two rings, lock washer, and h4 ring. I didn't use the lock washer ( not enough threading for it ).
Old 09-07-2009, 04:47 PM   #2
DandiDani
DandiDani's Avatar
i want to do this to my headlights now too.it looks great
Old 09-07-2009, 06:37 PM   #3
PETERPOOP
PETERPOOP's Avatar
done.
Old 09-07-2009, 06:45 PM   #4
DandiDani
DandiDani's Avatar
Old 09-07-2009, 08:08 PM   #5
ok I gotta bring them home to bake them. I've been afraid to try this mod, honestly but you guys give us scaredy-cats some hope.
Old 09-07-2009, 08:23 PM   #6
PETERPOOP
PETERPOOP's Avatar
I've been afraid to bake them too. I only decided to leave it in for four minutes @ 215 and that was still too long. All ovens are different. I suggest preheating for 10 min at 220, and then turning off your oven and putting in your headlights for 4 min and then try and pry them open from there. It's good if you have someone helping you. One to pry the clips while the other guy holds it and is opening it slowly as he prys each clip.
Old 09-13-2009, 09:08 AM   #7
808_Yaris
Where is Oahu?
808_Yaris's Avatar
Drives: 5-door meteorite metallic
bump for some helpful information!
808_Yaris Air Runner Thread:http://www.yarisworld.com/forums/sho...655#post329655
808_Yaris Air Runner Video:http://www.youtube.com/watch?v=fUkqox5d5No
808_Yaris Retrofit Projector Pictures:http://www.yarisworld.com/forums/showthread.php?t=22461
808_Yaris is offline   Reply With Quote
Old 01-09-2010, 04:01 PM   #8
Yarrris-Wench
Keep To The Code
Yarrris-Wench's Avatar
Drives: Red 2009 Toyo Yaris- Isabella
Send a message via AIM to Yarrris-Wench
Wow that looks amazing. I don't think it'd look right on my car tho :-S
Completed Mods:
Cruise Control, License Plate Mount, Fog Lights, Exhaust
Next Mods:
Tail Lights, HIDs, Tint, Rear Speaker Box & Amp(Boom Boom :P)
Yarrris-Wench is offline   Reply With Quote
Old 03-08-2010, 12:36 PM   #9
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
wheres the night shots...
Old 03-08-2010, 01:23 PM   #10
PETERPOOP
PETERPOOP's Avatar
CUTOFF....
Old 03-08-2010, 02:41 PM   #11
nice how-to
but no need to fully remove your front bumper....just unclip the top
i had both of my headlights out yesterday w/o taking the front bumper fully off...
Old 03-24-2010, 02:17 PM   #12
zachryboles
Chunk love Yarii
Drives: 2008 Silver 3DR Yaris Liftback
which kit used from microimage.... im wanting to do this mod in the next week or 2.
oh and what paint should i use?
zachryboles is offline   Reply With Quote
Old 03-24-2010, 03:00 PM   #13
PETERPOOP
PETERPOOP's Avatar
http://shop.microimageonline.com/Pro...-H4-prj-h4.htm
Old 03-25-2010, 11:08 AM   #14
zachryboles
Chunk love Yarii
bump for paint type
Old 03-25-2010, 09:47 PM   #15
Brian
Brian's Avatar
Originally Posted by zachryboles View Post
bump for paint type
I used SEM satin black.
Old 03-25-2010, 03:07 PM   #16
PETERPOOP
PETERPOOP's Avatar
I think I just used the plastic paint i had laying around. You might want to ask "Brian" what paint he used. he did the first retrofit DIY for the sedan. sorry
Old 03-26-2010, 09:54 AM   #17
zachryboles
Chunk love Yarii
think this would work?
http://www.krylon.com/products/fusion_for_plastic/
or maybe the rustolium brand....
Old 03-26-2010, 10:18 PM   #18
Brian
Brian's Avatar
it will work fine. the more fade resistant the paint is, the better.
DIY - Liftback Intermittent Wipers via Stalk Replacement (v2.0) CTScott DIY / Maintenance / Service 142 06-25-2024 02:47 AM
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 goku87 DIY / Maintenance / Service 127 02-19-2023 08:01 PM
DIY Projector/HID (sedan) Brian DIY / Maintenance / Service 145 02-05-2012 05:13 AM
Florida Yaris Roll Call: Part 3- Post Hacking! Sabretooth Southeast 81 05-22-2009 11:39 AM
DIY KEYLESS ENTRY on Power Liftback? TC-LIFTBACK DIY / Maintenance / Service 0 08-23-2006 10:57 AM
