Old 09-10-2009, 01:57 AM   #19
Yeah, I like my TRD shocks/S.Tech springs combo. But like I've said, I can really use a rear sway bar.
Old 09-10-2009, 08:10 AM   #20
MUSKOKA800
MUSKOKA800's Avatar
you can rent them for free from your local auto parts store.
True, but my local stores tool was damaged and with no replacement on the horizon.
So for a measly $30.00 I have the tool inhand and can do the job at my leisure, not just when it's available (often booked out). Plus now I have it to share with other local enthusiasts.
Old 09-10-2009, 08:44 AM   #21
Tamago
Tamago's Avatar
Drives: UZJ100
yes, it's useful if you're working on cars other than yarii, but it's completely unnecessary when installing lowering springs
Old 09-10-2009, 08:44 AM   #22
scape
scape's Avatar
Drives: 2007 Yaris Hatchback
is there any benefit to upgrading the shocks without getting new springs? I'm not sure I want to lower my car, I practically bottom out in and around town; and sometimes go off road; but want a bit of finer touch on the handling
Old 09-10-2009, 08:47 AM   #23
Tamago
Tamago's Avatar
Drives: UZJ100
absolutely, upgrading struts/shocks with stock springs will handle BETTER than a yaris on lowering springs and stock struts/shocks :)
Old 09-10-2009, 10:27 AM   #24
Lafiro
Drives: 06 Yaris Sedan
Alright, so I am a victim of stock shocks/struts ( Which are dead now ), but I have TRD springs installed.
So what should I do for a good ride, quality? Change my springs? Or keep them and get the Tokico Blues?
Old 09-10-2009, 10:37 AM   #25
Tamago
Tamago's Avatar
Drives: UZJ100
if you like the drop, keep the springs you have. definitely get some up-rated shocks/struts
kyb GR2's are another good-yet-cheap alternative to stock struts.
around $220 + shipping from tirerack
Old 09-11-2009, 12:20 PM   #26
Lafiro
I like the drop, a LOT.
I like the handling, I just don't like how rough they are. I was wondering if I changed them to NF210's, and some Tokico shocks, maybe it would be better, or thats just a bad combination. If so, I will just go ahead and purchase the Tokico's and keep the TRD's I have now.
Its that the streets here in NYC, SUCK. So many bumps, and potholes. Unfixed for years in lots of locations that people drive through everyday unfortunately.
I would just want the car to remain on the floor, and not allow the tires to bounce off the floor causing jolts to go through the car, and slight loss of traction while in turns(highway speed), especially on wet floors.
Old 09-11-2009, 03:56 PM   #27
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Don't waste your money with NF210s, they are about the same rate and height as TRD springs. You will but them on and feel no difference.
You can get KYB GR2s if you want a stock replacement, or get the Tokico Blues if you want something a bit stiffer.
Old 09-11-2009, 05:21 PM   #28
RacerFreakXXX
JDM Fred
Drives: 06 Mazda Miata
detroiter do you have any pics of your car with the springs and struts? I'd love to see what it looks like.
RacerFreakXXX is offline   Reply With Quote
Old 09-11-2009, 05:41 PM   #29
kngrsll
Apexing Egg!!
kngrsll's Avatar
it will look the same with struts... the ride height wont change.
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 09-11-2009, 06:24 PM   #30
frownonfun
frownonfun's Avatar
can you stop saying compressors are completely unnecessary. they are a safe way to get the stock spring off the stock strut. not sure how that is unnecessary. were u able to do it without hurting yourself? maybe. but that doesn't make it safe.
Old 09-12-2009, 02:20 AM   #31
detroiter
detroiter's Avatar
I'll take a couple for you tomorrow morning. Supposed to be a nice sunny day so shouldn't be a problem :)
Old 09-12-2009, 06:42 AM   #32
Tamago
Tamago's Avatar
Drives: UZJ100
i've done at least 40 spring installs without a spring compressor and NEVER been injured.
my technique is simple, safe, and saves time over monkeying around with compressors.
by the way i own a spring compressor set, and do use it when necessary, but it's simply not needed on a car as light as the yaris.
Old 09-12-2009, 07:10 AM   #33
kngrsll
Apexing Egg!!
kngrsll's Avatar
I have gotten away with it too. I have had some hairy moments with out one (ie strut ended up about 30 feet away lol) but in general, you dont need one.
Old 09-12-2009, 01:39 PM   #34
detroiter
detroiter's Avatar
RacerFreak....Here's those pics I promised you I'd take this morning.
Aoe TigerTec Springs, Tokico Blue shocks/struts, Ultra Racing 23mm Sway bar
Like I said, it's a very tasteful drop. It's not a 4x4 and it's not slammed either.
I'm very pleased with the springs and matched up with the Tokicos and UR sway bar,
it's a killer combination. I really do suggest you just getting the shocks so you can
do it right the first time and make it that much better as well.
Old 09-12-2009, 06:30 PM   #35
RacerFreakXXX
JDM Fred
your car looks great thank you. I'm kinda debating about getting rid of the springs now and getting bc coils... but I have to really think about it.
Old 09-12-2009, 11:53 PM   #36
detroiter
detroiter's Avatar
In all honesty, like a few other stated as well, you more than likely will just set the coilovers on a setting and never change them again. It's a lot of money to spend on something you might only mess with very sparingly. Before spending alot of money on coilovers, I HIGHLY suggest you spend the $300, which is nothing compared to a decent set of coilovers, see how you like the setup (of which I'm sure you would love it!) before spending that kind of amount.
Finishing my suspension ChinoCharles Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-15-2011 09:26 PM
Anyone have air bags or air suspension? ToTo Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 06-08-2011 10:38 PM
My suspension setup: Breakfast Blend for the angry panda Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 57 07-26-2010 03:56 PM
Any Yaris hatch rear suspension tweeks? woof Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 12-05-2009 06:04 PM
Torque Settings, front suspension Nimble Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 02-21-2007 01:00 PM
