Old 09-10-2009, 03:53 PM   #19
The Spectacle
The Spectacle's Avatar
Drives: 08 BSP LB
Cool. I wouldn't expect a bolt on kit for the Yaris to go for less than 5k. Even then, it'd probably be less than complete. DIY? A little less but a ton more headache. You better know what you're doing before you get into a project like this.
The Spectacle is offline   Reply With Quote
Old 09-10-2009, 04:08 PM   #20
chongopants
Drives: 2007 Yaris Hatchback
Send a message via AIM to chongopants Send a message via MSN to chongopants
Yeah I hear you, I have the proper support. Thats why I am not jumping into it either. Its costly and bad if not done right. So for now I am working on suspension and lightening. I have already take seat out and some other stuff, and I am trying to see what the next thing I should do is.... I was thinking pullies or sway bar/springs first.
chongopants is offline   Reply With Quote
Old 09-10-2009, 06:07 PM   #21
The Spectacle
Drives: 08 BSP LB
If your ultimate goal is to go FI, I'd say leave everything under the hood stock. Once you go boost, whatever you do for N/A will be for naught.
Old 09-10-2009, 06:13 PM   #22
chongopants
Yeah so just wait til I can do FI, so I dont waste cash? But I am trying to weight which I would rather do, FI is $$$ and lotsa work... otherwise I could do a little at the time....
Old 09-10-2009, 11:30 PM   #23
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
You can't properly boost the Yaris (or any car for that matter) for $500. Please don't attempt to.
You again huh....
www.homemadeturbo.com Lot's of cars have been junkyard boosted for less :)
Old 09-11-2009, 08:39 AM   #24
jt258
jt258's Avatar
Drives: 10' corolla ce
TRUST ME CHONGO IF YOU COULD HAVE FOUND TWO TURBOS LIKE I DID THE FIRST TIME IT WOULD NOT BE HARD TO START PIECEING TOGETHER YOUR OWN TURBO KIT I JUST HAVE A FEW PIECES FOR NOW BUT ITS SLOWLY COMMING TOGETHER. I HAVE KNOW DOUBT IN MY MIND THAT YOU WILL START GETTING YOUR TOGETHER REAL SOON.
jt258 is offline   Reply With Quote
Old 09-11-2009, 11:21 AM   #25
chongopants
Yeah I am really debating whether or not its worth the time and money at this point. But I am keeping my mind open...
Old 09-11-2009, 11:26 AM   #26
chongopants
Could someone PM me with a list of what all I will need to get? This will be my first turbo... other than the obvious... what do I need? Like replacement oil pan? or do you drill/tap your own?
Old 09-11-2009, 02:07 PM   #27
jt258
jt258's Avatar
GO TO 365 MOTORWERKS GET AN OIL FILTER SANDWICH BLOCK AND THAT SHOULD KEEP YOU FROM OIL PAN.
Old 09-11-2009, 02:14 PM   #28
jt258
jt258's Avatar
WE WILL PUT OUR HEADS TOGETHER ON HOW TO PUT THE TURBO KIT TOGETHER FOR YOU MAN. IT JUST DEPENDS ON WHAT YOU WANT AND HOW YOU WANT IT.
Old 09-11-2009, 02:20 PM   #29
As an oil return line from the turbo? I don't think so.
Old 09-11-2009, 03:30 PM   #30
advocate
Drives: car
jt258: your interest in FI with regards to the Yaris is noted and appreciated but I do have a small request: Can you not use capslock in your posts? I feel like someone is yelling in a very quiet room when I read everything in all caps.
Old 09-11-2009, 03:49 PM   #31
jt258
jt258's Avatar
Sorry about that im having an off day today.
Old 09-11-2009, 03:57 PM   #32
jt258
jt258's Avatar
well cali did you drill and tap your oil pan or did you buy another one?
Old 09-11-2009, 04:45 PM   #33
Nexus1155
Drives: Audi
the oil sandwich plate is great for a feed as well as a pressure sensor, but i dont think so for a return. But where would you tap in also for coolant?
Old 09-11-2009, 05:36 PM   #34
The Spectacle
Drives: 08 BSP LB
Originally Posted by Nexus1155 View Post
You again huh....
Go ahead and do it then. Let us know how it goes. I'll just leave it at that.
You can tap your own. Buying an aftermarket one isn't necessary unless you got money to blow.
Old 09-11-2009, 05:54 PM   #35
jt258
jt258's Avatar
well im just curious to know because i will be the first one to tell you that dont know everything, but i know a few things about turbo cars.
Old 09-11-2009, 05:57 PM   #36
jt258
jt258's Avatar
those few things dont include how to route oil and coolant lines for a turbocharged engine.
Turbo kit Brainstorming Gideon Forced Induction Forum 16 04-19-2009 12:54 AM
Turbo Kit - trade for stock parts! crankyelbow Items for Sale by private party 62 02-03-2009 12:30 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 15 06-09-2007 01:24 AM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 02:10 PM
