Old 11-05-2009, 09:40 PM   #1
so what free swag are you going to send up with?
Old 11-10-2009, 11:52 AM   #2
yarr_is
Drives: yaris
I think they were able to keep the stuff they tested... Here's what i found about the RD
http://www.tanabe-usa.com/rnd/catego...is-5-Door.aspx
yarr_is is offline   Reply With Quote
Old 11-10-2009, 12:00 PM   #3
IsLNdbOi
IsLNdbOi's Avatar
I posted that link right above you in post #18.
http://www.tanabe-usa.com/rnd/post/T...r-Install.aspx
http://www.tanabe-usa.com/rnd/post/T...aust-Test.aspx
Yeah, they asked me which parts I preferred and said they would test those last so they could leave them on my car if they all fit properly. I told them I liked the NF210s, the Medalion Touring and the Strut Tower Bar so they tested those last and they did fit properly w/o any modification to the parts or car. So I got to keep the NF210s, the Medalion Touring and the Strut Tower Bar.
This is what they tested:
Suspension: Sustec Coilovers, DF210, NF210
Chassis: Sustec Strut Tower Bar
Exhaust: Medalion Concept G, Medalion Touring
Old 11-10-2009, 12:07 PM   #4
should have kept the coilovers...
Old 11-10-2009, 12:10 PM   #5
IsLNdbOi
IsLNdbOi's Avatar
I couldn't. They send the part back to Japan for further tuning and adjusting for a car if it doesn't fit properly or they think it's not polished enough.
If you look at the links I posted, when the coilovers were adjusted to their maximum height, the front of the Yaris was higher than the rear.
Old 11-10-2009, 12:10 PM   #6
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
so thats your car i seen in the email i got from them this morning reguarding new products. GOOD STUFF.....
Old 11-10-2009, 12:22 PM   #7
yarr_is
Drives: yaris
lol sorry... I didn't read from first post. How's the parts now? The medalion looks kind a weird depending how you look at it
Old 11-10-2009, 12:31 PM   #8
IsLNdbOi
IsLNdbOi's Avatar
I like them. Sure the Strut Tower Bar doesn't really do anything for our cars, but it looks cool. I like the drop the NF210s give. Not too low, but still noticeably lower than the stock springs. Ride comfort hasn't suffered either.
The Medalion Touring IMO looks much nicer than the stock, toothpick-sized exhaust that comes with our cars. It is a little louder than I thought it would be, but nothing unbearable. I wasn't a fan of the large, open can look of the Concept G (good thing they needed to make adjustments to it for our car).
Do these exhaust / muffler "upgrades" actually do anything for the car other than make it look and sound a little different? Do they add or lower HP? Do they affect fuel economy?
Old 11-10-2009, 12:53 PM   #9
yarr_is
Drives: yaris
They should give or add about certain HP ... maybe 3hp or more. I was reading the 350z exhaust and it gave about 9hp. It gives more airflow and less restrictive from the stock. As for saving gas... well that all depends on you and how you drive. I'm pretty sure the front tower bars are a big help. It keeps the suspension leveled and keeps it from going un-even on turns and what not.
But for sure the exhaust will not take off HP ... that would be silly and would be useless for them to make. It'll give more HP. Did they dyno the car? Also I read that the NF gives good drop and keeps the stock feeling... I believe it gives 5% stiffer than stock. Which it isn't that noticeable
Old 11-10-2009, 02:16 PM   #10
ROCKLAND TOYOTA
TRIM HUNTER
unless your changing the piping on the WHOLE exhaust system just a muffler won't be doing too much....
Old 11-10-2009, 02:43 PM   #11
yarr_is
Drives: yaris
Was it just axle back or the catback system ?
Old 11-10-2009, 03:08 PM   #12
axleback, you can see the mini-me stock piping after the axle
no one makes a "cat-back" system for our cars
i had to go custom to get the section from my resonator to my axleback replaced
Old 11-10-2009, 03:19 PM   #13
ROCKLAND TOYOTA
TRIM HUNTER
this link says different on the cat back system:
http://www.2kracing.com/Vehicle_Spec...k_Exhaust.html
Yaris vs MR2 Spyder regal Off-topic / Other Cars / Everything else Discussions 36 01-25-2026 12:56 PM
Yaris TS 1.8L History and Specs CASTREX Yaris TS Talk 52 10-27-2009 05:06 PM
WeSellCarParts.com // Tanabe! WeSellCarParts WeSellCarParts 61 01-17-2009 03:32 PM
