Old 11-03-2009, 03:23 PM   #19
burttany
Same problem
I have my amp under the passenger seat. I put thought I grounded it correctly because I was getting some sparks when it touched the bolt. But for some reason I turn my car on and its not working.
burttany is offline   Reply With Quote
Old 11-03-2009, 03:33 PM   #20
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
blow a fuse?
Old 11-03-2009, 04:14 PM   #21
RUFFSTUFF
Drives: 2009 TOYOTA YARIS SEDAN
It's not working because it knows you don't know what you're doing...
Good luck!
RUFFSTUFF is offline   Reply With Quote
Old 11-04-2009, 07:07 AM   #22
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Burt,
The proper suggestion would be to remove the negative battery connection before you do any work on the vehicle. The ground to the battery should be the last attached before you start.
― Thomas Paine
Old 11-04-2009, 11:18 AM   #23
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Burt,
i never understood this step... I've heard people say that you should never have a spark when connecting stuff.... cause if you are... there's something wrong, and you can damage equipment.
my issue with claims like this is that 12v will cause the current to arch the gap when you go to connect the last cable. doesn't mean there's anything wrong... just that there is a voltage difference.
yeah... i figure its safer to yank the fuse, or disconnect at the battery.... but that won't stop a spark... it'll just mean the spark will happen in a different place. the safety of it has to do with if you drop a screw driver and as it falls it lands on power and ground cables or terminals on the amp thus becoming a tool that starts welding.
think about it... as soon as the caps inside the amp discharge (into the air) they will instantly draw power the second the ground cable gets an milimeter away from the battery post... thus causing a spark. If the amps is only disconnected for 5 mins the caps might not discharge, and you might not get the spark. However, let them sit for an hour or longer and you will get that spark. Happens every time.
so... if you could explain why I should disconnect the cable at the battery other than to avoid the welder... please share.
Old 11-04-2009, 11:26 AM   #24
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
i think its better to get the spark at the battery than the component you are installing . the surge isnt as close to the fuse which would pop easy.. thats how i always think about it.
Old 11-04-2009, 05:23 PM   #25
RUFFSTUFF
Not pulling punches here... It is just plain stupid to perform any any electrical wiring with the battery connected. Takes 30 seconds to disconnect the negative cable... The spark here vs. the spark there concept is totally erroneous. The spark at the negative terminal that occurs when reconnecting the battery is not an issue... the spark occurs at a point where current normally flows, and is usually small unless you have a large load that is just waiting for the current path to be restored (NOT A GOOD IDEA). The spark that occurs when you're connecting a piece of equipment and you are too lazy or too stupid to disconnect the battery first, will usually put a large current where you don't want a large current (I.E. A SHORT) ---> fuses blow and or said equipment or something else stops working.
Old 11-04-2009, 09:59 PM   #26
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
I understand the safety issues... I'm arguing semantics here....
what type of load does say a 1,000w Class D amp or a 300watt A/B amp seriously have when it is not turned on... As in, the car is off, they key is not set to ACC, the radio is not turned on... but the battery is still connected.
I mean... shit... a bank of eight 2200uf caps doesn't really constitute a "load" when we are talking about kilowatt systems, 100+ amp fuses, and 4awg & 1/0awg cables.
I really have trouble believing that a short would EVER occur due to this, or that fuses would blow.
I honestly thing all the "car turned off, battery disconnected... yadda yadda yadda was introduced back in the day to prevent people who didn't know what they were doing from burning up cars and killing themselves.
Old 11-04-2009, 10:18 PM   #27
RUFFSTUFF
Under most circumstances working hot on stereo equipment is not necessary. To bypass the most standard of safety protocols just because you have trouble believing a basic principle, is quite laughable. It takes about 100mA of current to cause death under worst case conditions. Certainly 1A is enough to permanently fry you like bacon. Considering an average car battery can put out 600CCA, the math is not in your favor in the case of a short. Of course, since you're not so good with electrical theory and the possibility of shorts occurring while doing work on live wiring, chances are you also suck at math so I'm probably just wasting my time... No wait... I am certainly wasting my time... nuff said once again.
UNSUBSCRIBE
Old 11-05-2009, 06:25 AM   #28
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Hmmm...
The negativity flows here. Taln is a good standing member here, personal shots aren't needed. Fighting over the internet is sort of stupid anyway.
Let us just disconnect the battery's ground and we'll be all good. Electronics can be very delicate. Mr. Murphy says so.
Math or no math, it is better to do so.
― Thomas Paine
Old 11-05-2009, 04:48 PM   #29
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
I know working hot is not necessary... something was said, and I simply challenge somebody to teach me a little about the subject.
I understand that shorts as minimal as say 30milivolts can damage circuitry....
I also understand that you can die from as little as say 250mA of current (to the heart)...
I also know that it is safest to disconnect power when working... i'm not asking about that...
I also know that unless somebody is sitting in a pool of water that a 12V source doesn't have the force to pass even .25Ampere pass the skin. The skin being an amazing insulator.
From the best of my knowledge 42volts was the lowest voltage anybody has died from (yes i understand voltage doesn't kill, its amperage... but without the force/voltage behind amperage it doesn't matter).
A battery could have 2million amps of current potential... unless it has enough voltage to get that current to pass through the insulator (your skin)... it doesn't mean jack. That's why I can place my right hand on one bat terminal.. and my left on the other terminal and I don't turn into a crispy critter on the spot.
Now... back to the real question...What kind of load would can we expect a modest sized A/B amp to put on an electrical system when it is hooked up (and set to be turned off).
And...
Would that draw/load really be realistic to pop say a 50 or even a 25amp fuse.
I'm waiting for your math.
Old 11-05-2009, 04:54 PM   #30
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
To not address the question at hand because you are too lazy, or ignorant to answer the question (tho not willing to admit it), and would thus rather bash somebody for asking questions is also "quite laughable".
World is in a sad state when people are no longer allowed to ask questions.
Old 11-06-2009, 02:36 AM   #31
sqcomp
Roadrunner Jr.
sqcomp's Avatar
FLAME WAR
Let's get cheering sections going like they have at soccer matches
― Thomas Paine
Old 11-06-2009, 07:57 AM   #32
Slick
Slick's Avatar
Drives: '09 3-Dr
Taln Taln he's our man, if he can't do it, I'm sure someone else can!!!
Old 11-06-2009, 01:32 PM   #33
sqcomp
Roadrunner Jr.
sqcomp's Avatar
GOOOOOOOOOOOOOOOOOOOOOOO Taln!
...this is so juvenile...
― Thomas Paine
Old 11-06-2009, 06:31 PM   #34
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
I'm not that kid yelling "fight fight fight" ... *caugh* sqcomp & slick *cough*
But an honest & technical answer from anybody would still be nice.
Old 11-06-2009, 09:34 PM   #35
Slick
Slick's Avatar
Drives: '09 3-Dr
Sorry, I don't know the facts behind hooking up my wires aside from the basics. No problems yet. But I do not have enough info on this particular subject to present any sort of useful tech info :(
Old 11-20-2009, 03:13 PM   #36
Mobius1
Installer
Mobius1's Avatar
Drives: 2008 Yaris HB
Battle to the death!
Mobius1 is offline   Reply With Quote
2007 Toyota Yaris Hatchback - 5-Speed Manual truebreakerz Cars for Sale by private party 23 09-17-2009 09:29 PM
Retro fit Cruise Control into a 2009 Yaris hatchback 42ezra Performance Modifications 1 05-02-2009 11:04 PM
Put a yaris sedan front on a yaris hatchback?? pp.sweet Cosmetic Modifications (Exterior/Interior) 24 08-21-2007 10:17 PM
