Old 09-29-2009, 11:05 AM   #19
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
Anywhere from 1 to 2 degrees of negative camber up front should give a nice street set-up. You can purchase non-adjustable camber bolts from rockauto.com very cheap. I'm not sure how much, if any adjustment you can make without the use of camber bolts. While 0 degrees toe-in is preferred for performance, a very slight toe-in (1/16") will make the car track much better at highway speeds.
Old 09-29-2009, 12:28 PM   #20
ddongbap
Toe out helps with speeds, not in. It seems like thats what you meant tho.
Old 09-29-2009, 01:13 PM   #21
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
we need a real 1 incher on the rear...
Its a Chao!!!
Old 09-29-2009, 01:21 PM   #22
stock set up should produce -1 degree if adjusted for that.
Old 09-29-2009, 01:28 PM   #23
TheRealEnth
Beast
im talking bout an inch swaybar
Its a Chao!!!
Old 09-29-2009, 01:30 PM   #24
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Thanks but no thanks...
Old 09-29-2009, 04:41 PM   #25
DOMAV
Drives: Yaris 09 T-spirit 1.33
why do you change the camber bolts? what do they have different from stock?
DOMAV is offline   Reply With Quote
Old 09-29-2009, 08:12 PM   #26
TheRealEnth
Beast
you can easily get more +/- camber with new ones
Its a Chao!!!
Old 09-29-2009, 08:40 PM   #27
Tamago
Tamago's Avatar
Drives: UZJ100
no you're wrong
toe in = high speed stability.
Old 09-29-2009, 08:55 PM   #28
ozmdd
ozmdd's Avatar
Tamago is correct, toe out improves turn-in, not tracking straight. Toe-in basically points the wheels towards each other, so the car is "trying" to steer to the center, toe-out has both wheels pulling away from each other, or constantly "fighting" each other. Whichever way you favor, the car will move more quickly in that direction.
Old 09-29-2009, 09:02 PM   #29
ozmdd
ozmdd's Avatar
Camber bolts, particularly the nice ones like Garm sells - have an eccentric lobe on the shank (like a camshaft) where it fits through the strut bracket. By adjusting the position of the lobe, you tilt the bottom of the strut "in" or "out" from vertical, and the hub/wheel goes with it. Viola! - camber!
The stock bolt you replace is exactly that; a regular bolt that doesn't have adjustability.
I hope that helps.
Old 09-30-2009, 12:08 AM   #30
ddongbap
no you're wrong
I am corrected.
Old 09-30-2009, 01:26 AM   #31
DOMAV
Hi all thanks for all the help, so first a get the yaris aligned, then i do the rear sway bar! what will the front upper strut do? will it help?
as far as the alignment what is the factory setup? i think the garage guy will know but better if i know so i'll tell him thanks all for the help
Old 09-30-2009, 07:01 AM   #32
Tamago
Tamago's Avatar
Drives: UZJ100
you don't want the factory setup. you want -1.5 degrees camber up front, 0 toe.
the rear you can't mess with without shims.
go read the "ultimate suspension guide" before you throw money away on a front upper strut bar.
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 99 01-25-2026 12:51 PM
24mm sway in front and 23mm in the rear fuji Performance Modifications 28 11-13-2012 05:02 AM
Positives and negatives to hub spacers? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 11-11-2009 07:37 AM
In regards to understeer....... anonymous user Wheels, Tires and Suspension Forum sponsored by The Tire Rack 56 05-31-2009 10:38 AM
Taking to next level and eliminate understeer regal Wheels, Tires and Suspension Forum sponsored by The Tire Rack 23 05-25-2009 07:19 PM
