Old 09-30-2009, 04:03 PM   #19
birdman
Thanks for all your insights. I seem to remember an article that placed the resister in the wiring coming off of the head light assemblies under the hood (bonnet). Not having to tear apart the dash would be a real plus. But if tearing the dash apart to do it is what I have to do then so be it. I'm after an inconspicuous fix.
Old 09-30-2009, 04:51 PM   #20
A resistor can be added in series with the circuit to avoid having to disassemble the cluster. You could potentially cut into where the signal routes through Connector BA1 under the hood, but it would be easier to add the resistor at the connector entering the cluster. You would cut the gray wire in position 14 and add a resistor between the cut wire. I would start at about 1K Ohms and go up from there to find a desirable brightness.
Old 09-30-2009, 06:16 PM   #21
birdman
Thanks for the info but I'll need a bit more clarification to understand the lingo. What is a cluster? Where under the hood is position I4 and what does that diagram mean? I don't see anything with a BA1 on the diagram. I don't even know where this electrical block is located. Has anyone done a step by step pictorial on this yet?
Old 09-30-2009, 06:35 PM   #22
birdman
Bright blue indicator light
I posted this already in another section. Being new I'm still trying to find my way around. After long night drives I find the high beam indicator light a bit too bright and I want to reduce it a bit. I drive in remote areas where there is lots of game that I want to avoid hitting so I need the brights on. Has anyone submitted a step by step pictorial on how to add a resister? One member said there was a way to do it under the hood (bonnet) instead of disassembling the dash. The suggestion I got was very thoughtful but way over my head. I'm not afraid to do it myself but I'll have to be led through this one in layman terminology. Thanks.:eyebulge
Old 09-30-2009, 07:08 PM   #23
BA1 is a terminal block within the fuse box under the hood. The place where the resistor would need to be added is on a connector that is under the fuse box, so it would be easier to pop off the trim around the cluster (also known as the combination meter, speedometer, etc.) and make the connection where the wire enters one of the two connectors (connector D2 pictured above) going into it.
Here's a picture of connector D2. Wire 14 is the gray wire third from the left on the bottom row:
Here is the annoying indicator before modification:
And, here it is after adding a 2K resistor inline with the gray wire:
Both pictures were snapped with the same camera settings. You can see how the before picture has a glowing halo around the indicator and the second is illuminated, but no where near as much as the before pic.
Old 09-30-2009, 07:09 PM   #24
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
instead of starting a new thread, you should PM tk-421 and ask him to move the other thread here.
the suggestions you got from CTScott are the best I believe you are going to get.
If you would like me to elaborate on the cluster method (the cluster is the circuit board where the speedometer and indicator lights are) then I will post again later.
Old 09-30-2009, 07:13 PM   #25
severous01
turn your brightness knob down. it'll dim all lights on dash
Old 09-30-2009, 07:23 PM   #26
The indicators don't dim, just the speedometer and fuel gauge dim.
Old 09-30-2009, 08:02 PM   #27
birdman
I'm new at computers and don't have a clue what a PM tk-421 is. CTScott is very smart. I just read his tire pressure warning light shut off switch install. Actually this post is the new improved version of the other. I will send him a message. Thank you. Yarisworld rocks!
Old 09-30-2009, 08:05 PM   #28
Look at the last post of the other one. I did a quick test with pics for you.
Old 09-30-2009, 08:10 PM   #29
birdman
Thanks Alex. I want to avoid the circuit board approach if possible. Way beyond my comfort zone. I may end up applying a black dot on the plastic shield if it comes to it.
Old 09-30-2009, 08:11 PM   #30
birdman
CTScott you rock!
Old 09-30-2009, 08:16 PM   #31
birdman
Marcus, At the end of the day I might just do it. Thanks man.
Old 09-30-2009, 08:29 PM   #32
birdman
CTScott you are too much man. You must possess an extra chromosome or something. When you spliced the gray wire was the gauge assembly still in the car? If not How do you remove it? Do you have a photo of the 2k resister in place? Does it need soldering? Does it matter which end of the resister is closest to the D2 connecter?
Old 09-30-2009, 08:54 PM   #33
I tested it out on Crashy (my ebay purchased totaled Yaris), who has no headlights, so i actually jumped power to the indicator to make it light and then added the resistor inline with the jumper. I also have her dash completely removed, so I have easy access to all wiring.
But, to do this on an intact car, you pop the cluster trim, disconnect the connector, and then cut the resistor into the wiring harness. You'll cut the wire (about 2" from the connector to give yourself room to work), strip both ends, attach one end of the resistor to each (resistors aren't polarized, so it doesn't matter which end goes to which), and then either heat shrink it or tape it up.
Old 09-30-2009, 09:18 PM   #34
bronsin
bronsin's Avatar
Hmmm very interesting and Ive learned something here. Still wouldnt it make a lot more sense to put a piece of colored tape over the high beam indicator rather than take everything apart and all?
Old 09-30-2009, 09:43 PM   #35
birdman
Thanks CT. I have one more question regarding this fix. Can you get crimp-on resisters or must they be soldered?
Old 09-30-2009, 10:02 PM   #36
birdman
There is yet another question. What gauge wire will the resister be spliced into?
F/S Blue Stitched Leather Shift Boot. 1NZYaris1 Items for Sale by private party 9 05-06-2009 11:59 PM
Bayou Blue paint code andru47 General Yaris / Vitz Discussion 7 01-03-2009 04:19 PM
Blue Film over gauges Jeff1 DIY / Maintenance / Service 10 10-21-2008 03:01 PM
Black or Blue CrashRescueFF New YARIS Purchase Forum 18 07-24-2007 07:21 PM
Nautical Blue Metallic YotaYarisUSA General Yaris / Vitz Discussion 0 04-02-2006 07:09 PM
