Old 10-13-2009, 12:15 AM   #19
posaunemeister
Drives: 2008 Yaris S LB - MM
Originally Posted by Saskatchewan17 View Post
Very cool... but what are you really replacing? Putting straight pipe where straight pipe was in the MP section?
It's a slightly larger diameter, I believe.
posaunemeister is offline   Reply With Quote
Old 10-13-2009, 10:39 AM   #20
replaced the stock piping from the resonator to the axle which is 1.75" with 2.25" crush-bent piping
ideally this will yield about 2" diameter thru, which is how big the cat's and resonators piping is
Old 10-13-2009, 03:39 PM   #21
posaunemeister
Actually, the stock piping after the resonator is 1.5"!!! I measured the piping about 2 months ago after I hacked off my stock muffler. So, yeah, I can definitely see how your new mid-pipe can make a difference.
Old 10-13-2009, 05:33 PM   #22
Saskatchewan17
MS3 Driver
Saskatchewan17's Avatar
Drives: 2008 Mazdaspeed3
Wow ok. I see. That's teeeenny stock piping. I know that changing the CBE in an MS3 will only net you gains if you are pushing 300 whp. All the gains are in the Downpipe/Racepipe (hence deleting the cats). And stock piping is 2.5 inches, no severe bends in the CBE at all.
08TrueRedMazdaspeed3
-PERFORMANCE:
-CP-E SRI - PG TURBO INLET PIPE - GREDDY TYPE S - TRZ REAR MOTOR MOUNT-
-OTHER:
-STRIPES - EXHAUST RESOS DELETED - BLACKED OUT BADGES - TOWPLATE - HD LIP -
- PROSPORT BOOST GAUGE/VENTPOD - STREET UNIT SHIFTER BUSHINGS - TINTED REFLECTORS/SIDE MARKERS/3RD BRAKE LIGHT - SIDE MOLDINGS REMOVED -
Saskatchewan17 is offline   Reply With Quote
