Old 10-04-2009, 12:59 PM   #1
Originally Posted by JBIZZ View Post
The stock belt it garbage & should be replaced on all Yarii
Almost 100,000 km/60,000 miles on mine. No issues.
Old 10-04-2009, 05:22 PM   #2
Lafiro
Drives: 06 Yaris Sedan
What kind of belt are you buying that it happens all the time? Got to stay away from that kind then?????
Someone please let me know where to go to buy a belt, sincethe stealership wants $50+tax or so.
Old 10-07-2009, 04:56 PM   #3
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
I got mine from the dealer. I think the dealer belts are crap. Maybe I will try the Goodyear one's.
Anyone know which Goodyear part is for the Yaris?
[Edit] I think 4040465 is the Yaris part # for 2007 - 2009.
devinlamothe is offline   Reply With Quote
Old 10-04-2009, 05:25 PM   #4
Lafiro
Also, not to bother much, but my engine is shaking and vibrating more then usuall? In the last month especially the sqeaking plus the extra vibration/shaking/noise has become worse.
Is this ALL because of my belt?
I drive in the city a lot, highway a lot, with traffic usually. Winters suck lots of salt. And the belt looks brown. Other then that, I take care of the car as much as I can.
Old 10-04-2009, 06:31 PM   #5
RedRide
RedRide's Avatar
I have not used one but most people say the GoodYear "Gatorback belts" are very good, much better than OEM. They say it will cure all squeaking/squealing for good.
http://www.goodyearep.com/ProductsDetail.aspx?id=3128
Old 10-06-2009, 03:38 PM   #6
Lafiro
Edit. The sqeaking is still there. This did not fix anything. And now there is slipping when turning on the car. Ugh
Old 10-07-2009, 10:54 PM   #7
Lafiro
I set the alt. back to where it was, and today I turn on the car and I hear the worst sound ever, the sound I hear from OLD belts on buses, thats how loud it was.
Is this because it stretched a bit, and needs to be further tensioned?
This really sucks. And the nouse is still there, almost like its something to do with the streering?
Old 10-07-2009, 11:01 PM   #8
When you steer at low speed the power steering motor draws a lot of current, so there is more demand on the alt.
You need to tension the belt, not just position the alt where it was.
Old 10-07-2009, 11:13 PM   #9
Lafiro
I will do that in the morning. Thanks.
But no one has been able to help me solve a year old problem thats getting worse.
Maybe it is the belt? At lower rpm's and with the car in drive, I hear sqeaking. Especially worse when I put the car in reverse going into my driveway, or pulling into a drive through. It applifies with the steering wheel being turned, but like I said only with the car in drive or reverse, once the car is warmed up/just coming to a stop after running for a bit.
Toyota can't "duplicate" the sound, I just say they are lazy, and no one here has had this issue supposedly, so I am out in the cold :(
I really hope tensioning the belt tomorrow really helps with this, and that it isnt something worse, because I couldn't understand what else could be sqeaking like that in the car(engine bay).
The attached files are pretty much what it does, you can tell when I switch from neutral to a gear, the engine gets louder, and you can hear that annoying noise.
Old 10-08-2009, 08:07 AM   #10
They really sound like belt squeal to me.
Old 10-08-2009, 10:04 AM   #11
devinlamothe
Lafiro this is EXACTLY the same issue that has been happening to me as well. The dealership said the same, they 'can't duplicate' the issue. Buggers. I've tried tensioning the belt a few times but the noise seems to come back after a few weeks (maybe it just keeps coming loose? No idea).
Anyways, I've learned to live with it, but I am going to try the Goodyear belt to see if that fixes it. I found a place nearby that sells them for $19.99 so I will pick one up maybe tonight and see.
Old 10-08-2009, 10:22 AM   #12
In the TSB's there was one for 07's which updated the tension spec for the belt:
"Some 2007 model year Yaris vehicles may exhibit a squealing noise coming from the engine compartment during vehicle operation. The generator drive belt tension specification has been updated to correct this condition. Please use the following repair procedure to address customer concerns"
From the TSB:
Name:  Belt Tension.jpg
Old 10-08-2009, 02:26 AM   #13
RedRide
RedRide's Avatar
The zip file seems to be corrupted.
Old 10-08-2009, 11:28 AM   #14
Lafiro
Oh, nice, .41 to .45in of deflection with 22pounds of force, OK, I will attempt to get this corrected soon then.
Also, I can't upload music files, so if anyone wants to hear a few seconds of it, just PM me your email.
Thanks for the responses.
Old 10-08-2009, 11:44 AM   #15
How do you judge how much force you are actually pushing on something with your finger?
I guess maybe you could hook a fish scale in there, and use that as a gauge.
Old 10-08-2009, 12:39 PM   #16
Lafiro
You are not suppose to lol.
I don't know, but atleast I retensioned it a bit more. It flexes a bit with some force, and it seems fine.
Car is quiet, for now.
Old 10-08-2009, 12:46 PM   #17
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
u guys are fast....i just got my belt today heh(busy), from pepboys for 11 bucks....it's DayCo brand.........anyone have experience with them? it's made in Canada.................is that better heh.
dang....where can i find a pipe.....
Yawesh is offline   Reply With Quote
Old 10-08-2009, 01:24 PM   #18
Home Depot - A 24" piece of 1" galvanized or black iron pipe is the second best tool to a BIG hammer.
yaris timing belt phenoyz General Yaris / Vitz Discussion 16 02-24-2015 01:05 AM
Accessory Belt change. When?? mhkritzinger DIY / Maintenance / Service 12 10-23-2009 02:58 PM
The Accessory belt? N9QGS DIY / Maintenance / Service 4 02-12-2009 11:05 PM
