Old 10-06-2009, 01:02 PM   #2
camelll
Drives: 07 sedan
Try reading a little farther down too!
"Legal Issues
Adding an intake system to your vehicle may make it illegal for road use. Because you are altering the engines emissions system the government wants to make sure that it does not create more pollutants than it should. California has the strictest laws pertaining to this so the better manufacturers will get a CARB # for the intake system. CARB means California Air Resource Board. Once an intake has been approved by CARB the intake system will require a sticker to be placed on a visible location on the intake system. It will have some numbers on the sticker called an “Executive Order Number”. This can be shown to smog technicians or police or CHP / State Troopers. Since California has the strictest emissions policy the intake will then be 50 state legal.
This is the Air Resource Lookup webpage for aftermarket parts:
http://www.arb.ca.gov/msprog/aftermk...es/amquery.php
Why Spend $200 vs. $40 for an intake?
Here is the reason why. The $200 intake system was probably designed and created by the company selling it. This means they Dyno tested different lengths and designs to try to gain the most horsepower for each vehicle. They then applied for a CARB number for this intake. When ordering your intake make sure it’s 50 state CARB legal.
The $40 intake system is just some company in the US importing over a generic design or copied intake system from China. These will not have a CARB number and the filters will usually fall apart within 6 months.
You might want to buy a cheap intake because you don’t car about CARB and you probably won’t get caught. If you do get caught, here is the scenario.
Police officer pulls you over. Asks you to pop your hood. They check out the intake and ask for the CARB number. There is none. So what happens? He gives you a fix it ticket to be signed off by the State Ref only. This ticket is charged by the city from $10-$100.
You then have to put on your stock air box (if you still have it), and then make an appointment with the State Referee. This cost $75 for them to inspect your car. If you have any other modifications they’ll find them, anything wrong they’ll find it and you’ll fail. These guys are strict.
Maybe you passed, maybe you didn’t? If you didn’t you have to go back to the State Ref until you do pass. If you did pass then they’ll sign off your ticket.
Now you have to go to court. You have to go show the judge that you got your ticket signed off. He’ll chuckle at the case, but you’ve already spent 2 days taking care of this ticket. So do some research before you buy and try to buy a 50 State CARB Legal intake for your car. Some good brands to look into are AEM, Injen, K&N, True Flow, and Weapon-R.
http://www.aempower.com
http://www.injen.com
http://www.knfilters.com
http://www.weapon-r.com
You can find intakes to purchase at our online store at
http://www.sroperformance.com/air-intakes-html.html
camelll is offline
MY new PRM Intake... marcus Performance Modifications 27 05-03-2009 11:04 PM
Bomz Ebay Intake - Partial Review Split Performance Modifications 11 11-19-2008 02:12 AM
