Old 10-20-2009, 09:51 PM   #19
basslover911
Drives: Future Yaris!
So Im still left with the question... would it be beneficial at all to build little sealed boxes for the rear speakers?
basslover911 is offline   Reply With Quote
Old 10-20-2009, 09:56 PM   #20
RUFFSTUFF
Drives: 2009 TOYOTA YARIS SEDAN
Nope.
RUFFSTUFF is offline   Reply With Quote
Old 10-21-2009, 02:06 AM   #21
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I'd agree with that last post.
Personally, I enjoy the bigger woofers. I get to settle for dual ID 15"s sealed.
Taln, I really do want to hear the enclosure you're rocking! You know, I've got a couple classical pipe organ pieces that have some magnificent LOW bass passages...
― Thomas Paine
Old 10-21-2009, 03:26 AM   #22
advocate
Drives: car
My vote is to get high quality speakers with maybe 1 amp to power them and to just crank the bass setting on your head unit.
You're not likely to get vibration-inducing level bass out of speakers but you can get very adequate bass and even more if you change the equalizer settings during playback.
You're going to have to decide what's best for you: 1) solid speakers w/ amp 2) give up and save your money 3) quick release amp / sub setup
Personally? I started out with a huge audio system and loved it but ended up tearing it out because I started getting into performance. If I were you I'd just save the money and if you haven't already, install high quality aftermarket speakers to replace the Toyota OEM ones. I bought 4x blaupunkt speakers with my audio system and they sound great. Got a hell of a price on em too.
Old 10-21-2009, 07:46 AM   #23
Musmat
Drives: balck car
I have component speakers in the front. So 6.5 mid drivers in the door and tweeters up on the door sails. And then 6x9 coaxials in the back. I have the speakers wired thorugh a 4 channel amp to give them more power and then front set on HP and rear set to LP so you get more mids and sometimes lows so you get actually pretty good base. Its enough to rattle my rear view mirror down and have to adjust occasionally. Without dynomat though in the doors it does rattle the doors significally. I cant have any bottle water in the holder. Its not earth shaking but is not too bad.
Diet Menus - Walk In Clinic
Musmat is offline   Reply With Quote
Old 10-21-2009, 08:10 AM   #24
TKO
Drives: 4 door hatch
You'd be surprised on how the small bazooka tubes sound. And they hardly take up any space.
TKO is offline   Reply With Quote
Old 10-21-2009, 10:11 AM   #25
Sabretooth
37HSSV
Sabretooth's Avatar
Drives: '11 Mazdaspeed 3
to add a point, you dont have to keep the subs in the car for autocross, if its a big bulky box that isnt fixed to the car, you can always remove it. wires left behind would weigh a lot less than leaving it in, or building fixed boxes behind speakers, or whatever. Just do it right the first time, allow it to be removed. Then you found your happy medium between both worlds..
Just dont complain about having to remove it.
Old 10-21-2009, 11:54 AM   #26
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Maybe.... it depends on the Qts/Qes/Qms & Vas of the speaker... By putting the speakers in sealed boxes you will get more volume (and less rattles), but at the same time, you may lose volume in the lower frequencies depending on the specs of the driver & the size of the box. The ultimate would be if you could make ported boxes for those speakers inside the doors. It would be a VERY tricky install though.
If you have an automatic, I'd say build some fiberglass kidpods, throw something like a Tangband neo 6.5" sub in each one, run those pods sealed, and get a 80x2rms amp to power them. then run your normal doors speakers off a 50x2 rms amp and call it good.
Old 10-28-2009, 11:39 AM   #27
anton
Drives: '08 Yaris sedan
If space and weight is really an issue, i'd recommend that you do a proper infinite baffle install on your rear dash with a pair of eights a single ten or even reuse the factory 6x9 cutouts for a pair of tang band or CDT 6x9 subs (parts express)
anton is offline   Reply With Quote
Old 10-28-2009, 02:09 PM   #28
hatchbackkid82
Drives: .
But a damn good substitute
Originally Posted by RUFFSTUFF View Post
Nope... just a substitute.
Old 10-31-2009, 04:38 PM   #29
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
not a bad idea... would have to spend some time stiffening up the rear deck.
I didn't know CDT made dedicated midbass drivers in the 6x9 size... not many companies do that.
Running Firewall Power Wires for subwoofer MacMaster761 In Car Entertainment + Electronics (audio / video / alarm) 17 03-06-2010 03:04 PM
Yaris Subwoofer shtou In Car Entertainment + Electronics (audio / video / alarm) 2 12-18-2009 12:04 PM
Bass inside the car, not outside. skigil In Car Entertainment + Electronics (audio / video / alarm) 28 10-30-2009 03:03 PM
Kenwood KSC-SW1 Powered Subwoofer seriousfun In Car Entertainment + Electronics (audio / video / alarm) 11 04-02-2007 02:44 PM
Your Ultimate Playlist eflb55 In Car Entertainment + Electronics (audio / video / alarm) 8 12-18-2006 09:43 PM
