Old 11-22-2009, 01:17 AM   #19
fuji
fuji's Avatar
Drives: Polar White Yaris HB
Interesting. The one I purchase from Garm worked flawlessly from the initial install. I did however use a cheap BOMZ intake which made fiting over the throttle body(which is larger) MUCH easier.
fuji is offline   Reply With Quote
Old 11-22-2009, 02:08 AM   #20
If you are not doing head work (bigger valves, porting, different cam) and improving intake manifold too ....how does this improve anything?
Example: you put an intake on the car and you dyno. More horsepower. More air going in requires more fuel = more power (even if it's a little bit).
This is true for a Yaris -- or your Boxster.
Old 11-22-2009, 10:50 PM   #21
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
I've been running this Throttle for more than a Year, no problems. I do recommend it. If you have any doubts get one!!!! LOL
I Drive a 129whp Yaris ;)
Old 11-20-2018, 02:32 PM   #22
DarkShadowFox
Originally Posted by kac View Post
Update: Installed 1ZZ throttle body today (from Garm, THANKS! great price, that guy is awesome)
Works Great! No check engine lights At All. Idle was high for a couple minutes when first started and has not been high at all since even at start up.
LOVING IT.. Only problem is I should have done it sooner! Great Mod!
(Also put on some Micro Image decals which look great, Thanks Garm!)
part #
Old 11-20-2018, 06:13 PM   #23
Freestylin
Freestylin's Avatar
Drives: 09 Blizzard Pearl RS LB
Originally Posted by DarkShadowFox View Post
part #
22030-0D030
“On a given day, a given circumstance, you think you have a limit. And you then go for this limit and you touch this limit, and you think, 'Okay, this is the limit'. And so you touch this limit, something happens and you suddenly can go a little bit further. With your mind power, your determination, your instinct, and the experience as well, you can fly very high.” ― Ayrton Senna
Freestylin is offline   Reply With Quote
Installed the 1zz throttle body - AlexNet0 DIY / Maintenance / Service 135 08-01-2014 07:57 AM
FS: 1ZZ throttle body and Fujita intake mrbond Items for Sale by private party 25 09-08-2009 10:21 PM
Intake to match the 1ZZ throttle body fuji DIY / Maintenance / Service 2 06-17-2009 10:02 PM
Intake for the 1ZZ throttle body? fuji Performance Modifications 9 06-14-2009 12:02 AM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
