Old 11-17-2009, 07:54 PM   #19
kac
kac's Avatar
Drives: 2009 Meteorite 3dr
I've got some rattle under the hood from modding the airbox and swapping the throttle body that I can fix easily and will sooner or later...
I have some rattle in the hatch that has been bothering me lately. The rear seat is out, so I can hear it nicely while I'm driving. I'm gonna have to move some stuff around back there and check it out...
Old 11-18-2009, 07:09 AM   #20
MUSKOKA800
MUSKOKA800's Avatar
Nearly 60,000 kl. on my sedan and pounding around for the past 45,000 on TRD suspension. Still no rattles, which surprizes me considering road conditions here.
Old 11-18-2009, 08:27 AM   #21
Lewis
Our off road vehicle
Lewis's Avatar
Drives: 2009 Yaris 3dr
Dasboard +1-
but only over pretty big bumps- otherwise tight for a 12,000 dollar car
but only 9K miles- the true test comes at 50K plus miles
Lewis is offline   Reply With Quote
Old 11-18-2009, 08:37 AM   #22
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
my gt spec SPAGHETTI BAR in the rear seems to be loosening up more and more lately giving me a rattle noise over bumps and such....
Old 11-20-2009, 01:12 AM   #23
Cosmonaut
The Last Baron
Cosmonaut's Avatar
Drives: 09 Polar White HB
ive got the dash-rattles when going over bumps. solution: turn music louder. :)
Sanction this outbreak, a Virus conspires. Single sparks are Spectral Fires!
| UR 19mm sway |
Cosmonaut is offline   Reply With Quote
Old 11-20-2009, 02:33 AM   #24
H3LlIoN
Drives: '09 Yarrrr hatch
driver's side rear speaker mount/trim panel.
Toyota
Moving Forward
...even when you don't want it to.
Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
H3LlIoN is offline   Reply With Quote
Old 11-20-2009, 09:06 AM   #25
fearturtle44
Drives: S Flint Mica
Luckily, no rattles yet (Yaris is over 3 years old). Now if this was a tC forum, I would have a major complaint about a hatch rattle.
fearturtle44 is offline   Reply With Quote
Old 11-20-2009, 04:06 PM   #26
UTVitz
UTVitz's Avatar
Drives: Black Vitz Liftback
Luggage cover on my hatchback rattles sometimes on warm days only it seems. I had the dash pod rattle on cool mornings, but since the dealer had to take the entire dash out to replace the a/c evap. I had the foam kit TSB installed at the same time-fixed, other than a minor trim gap from the foam pushing on it. And yes, I've noticed the same thing with the cup holder rattling if open and no cup in it.
Old 11-21-2009, 10:36 AM   #27
JBougie
JBougie's Avatar
I have 0 rattles in my 07. Road noise, yes - but I don't hold that against her. :)
JBougie is offline   Reply With Quote
Old 11-22-2009, 07:51 AM   #28
specialeducator
specialeducator's Avatar
Drives: 2008 Yaris sedan
just the rattles in my head
specialeducator is offline   Reply With Quote
Old 02-01-2010, 02:52 PM   #29
amtoro
amtoro's Avatar
Drives: 2009 3LB Metheorite
I have had a seriously annoying rattle that I have not pinpointed yet. It seems to come from the rear of the center console or under the seat; I have taken the console apart thinking it was the hand brake cable or splitter (as it sounds like a steel cable vibrating against metal)... nothing, the wires or cables in the passenger seat mechanism... nothing, the plastic covers over the jack or the body numbering plate, nothing...
I'm seriously thinking about not buying a toyota again and get rid of this one sooner than I'd have liked.
amtoro is offline   Reply With Quote
Old 02-01-2010, 03:15 PM   #30
slothman86
slothman86's Avatar
Drives: 07 Yaris Liftback
60k and no rattles. I even bent my radiator support (Yaris Amateur Rally, LOL) The only rattles are from loose objects in the boot area like metal rulers and pens.
Old 02-01-2010, 03:19 PM   #31
ROCKLAND TOYOTA
TRIM HUNTER
after getting HVAC TSB done dashboard has been nothing but rattles. im going under the notion that if you take it to a dealer and get a shitty tech then the outcome of his work is shitty....
Old 02-01-2010, 03:19 PM   #32
slothman86
slothman86's Avatar
That's pretty harsh judging Toyota on a rattle in this econo-box, Even tho this is an amazing little car... (Have you found out the seat fold flat yet?) Maybe you had a bad experience other than the rattling? It could be an acorn in the frame or something crazy like that...
Old 02-02-2010, 10:12 AM   #33
Woody_Woodchuck
Drives: 2008 Yaris LB 5M
22,000 miles and no rattles from the Yaris itself. Stuff inside it at times, yes.
I finally heard the engine noise talked about in all the reviews. With the windows up, radio off, 5th gear going up an incline at 60 mph I hear the engine!! Makes me all warm and fuzzy knowing it is still running so it doesn't bother me.
Lifetime log
Woody_Woodchuck is offline   Reply With Quote
