Old 10-21-2011, 08:48 PM   #19
monbonlupin
Drives: Yaris Sedan 2009
No, nothing happens...
monbonlupin is offline   Reply With Quote
Old 10-21-2011, 08:55 PM   #20
Have you gone through the configuration portion of the remote starter to make sure that thinks like that activation input are properly configured? For example that input is a +/- input which means that it probably needs to be told whether the signal is a + or - signal.
Old 10-21-2011, 09:02 PM   #21
monbonlupin
There's an activation input polarity jumper that I set to (-). What do you think about my wiring ? If it is correct, I might try to solder all the heavy gauge connections because the red splice taps I used seem to be too small...
Thanks !
Old 10-21-2011, 09:06 PM   #22
Thanks !
With a quick look it seems to be OK. Before you start rewiring, test is manually, by disconnecting that input and touching that wire to a ground twice to see if it tries to start. It may be that the remote starter doesn't like the pulse length/spacing.
Old 10-21-2011, 09:09 PM   #23
monbonlupin
Ok, i'ill try that...
Thanks
Old 10-21-2011, 09:21 PM   #24
monbonlupin
I touched the input to a ground twice and NOTHING...
Old 10-21-2011, 09:37 PM   #25
Does it respond if you try to go through the programming menu?
Old 10-21-2011, 09:41 PM   #26
monbonlupin
yes
Old 10-21-2011, 09:49 PM   #27
I just found the manual for the 4003. The neutral safety input has to be grounded for it to allow starting.
Old 10-22-2011, 12:47 PM   #28
monbonlupin
Thanks, I grounded the safety switch. Nothing changed but when I wired the H1/4 WHITE/BLUE (+/-) ACTIVATION INPUT wire to the blue GD1-9 wire, the car started for a few seconds then the engine stopped. I was able to restart the car by pressing the unlock button. The car ran a few seconds and stopped again. Does that mean that the brown wire in GD1-8 is not the correct wire ?
Thank you for your help !
Old 10-22-2011, 01:32 PM   #29
pennyracer
boydstir
pennyracer's Avatar
Drives: 08 yaris liftback
Send a message via AIM to pennyracer Send a message via Yahoo to pennyracer
ctscott heres one for you i have i have viper remote start and keyless entry installed in my o8 hatchback it seems to have a small constant battery draw if i leave me car stored in my familys wharehouse when i go out of town for more than a week at a time the battery is dead compltely yes i have a full sound system but i have pulled both 100 amp fuses on the power lines to the amps but still have the battery dain problem its funny my stereo guy that helps me out told me it was the remote start doing it and i told him he was crazy but all point lead to just that i have no other non factory items installed that use power maybe you can help me ?
pennyracer is offline   Reply With Quote
Old 10-22-2011, 10:37 PM   #30
Brown is the control for the door unlock via the key switch. Blue is the unlock detection, so the blue would be the better choice.
Old 10-26-2011, 10:23 PM   #31
bad
Winterizing
bad's Avatar
Drives: 2010 Toyota Yaris Hatchback
defoggers and heated mirrors
For the heat piece, you will need to leave the knobs where you want them. The advantage there is nice and warm in the winter and nice and cool in the summer.
You can tie the rear window defogger to the aux output of the remote starter to clear the back window. Here, where we get frost and snow that can be quite handy.
For the immobilizer piece, look at your ignition switch. If it is all metal then you don't have an immobilizer. If it has about a 3 cm metal part surrounded by black plastic, then you do.
Is it possible to make the remote starter start up your heated mirrors too? and heck while we are at it what about the heated seats too?
bad is offline   Reply With Quote
Old 10-26-2011, 10:33 PM   #32
If the starter has enough outputs you can start whatever accessories you want. If it doesn't have enough you would have to use a bunch of relays driven off of the outputs that it does have.
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 01:32 PM
Remote Starter - Tail Light Problem Chrsto4 General Yaris / Vitz Discussion 4 10-31-2009 11:36 PM
Power door lock keyless entry and remote start rizaydog In Car Entertainment + Electronics (audio / video / alarm) 10 07-20-2009 04:14 PM
Viper Remote Start goku87 In Car Entertainment + Electronics (audio / video / alarm) 4 12-13-2008 05:06 AM
