#1 |
![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
I wouldnt think about changing tranny fluid till at least 100k,in fact my last 2 cars got at least 200k on the manual trannies before i sold the cars and i never did get around to changing the tranny oil at all.
![]() ![]() ![]() Drives: Blazing Blue 08 liftback Join Date: Dec 2008
My owners manual said GL-5. Plus since I run it hard some times, seemed like a good idea. So far its working real good.
One Year One Oil-AMSOIL at www.Trulube.com TRD Exhaust, Springs and Struts. TRD SSK. NST Underdrive Crank Pulley. Amsoil Dominator 10w-30 Racing Oil, Amsoil DOT4 brake fluid, Amsoil Severe Gear 75w-90 transmission oil, Ultra Racing 23mm Sway Bar, Camber Bolts, R1 Drilled Slotted front Brakes and SS Brake cables from Micro-Image. Orange Konig Daylight 17s, Kumo MXs. Greg@TruLube.com |
#3 | |
![]() ![]() ![]() ![]() ![]() Drives: 2013 Chevy Spark 1LT 5-speed Join Date: Oct 2008
GL-5 is better suited for differentials, GL-4 is specifically designed for the softer metals in transmission and transaxles. Link below... Amsoil's Manual Transmission and Transaxle Gear Lube 75W-90 API GL-4: Specifically formulated for the most demanding manual transmission and transaxle applications |
#4 |
Blue beast
Transmission flushing
I just drain & refill my tranny with ws fluid (2.75 L) every year and plan on replacing the filter next year
#5 |
![]() Drives: 2008 Yaris Sedan (Auto) Join Date: Jan 2010
First of all thank you so much for your replies - your information was very valuable and helpful to me and I thank you all from the bottom of my heart.
Please let me have a moment to explain the whole situation. I purchased a used Yaris Sedan with 50K Kilometres and considering it is a 2008 model i would say it was driven a lot. Therefore my transmission oil was found dirty during a recent oil change. After contemplating back and forth regarding the "lifetime" oil guarantee from Toyota I thought to better be safe then sorry and decided to change my transmission fluid for good. However Toyota quoted me something around $200 for a "DRAIN & REFILL" (trust me they say they only do this method). I found a better deal thru a local "mechanic" for $85. As per my previous post he proceeded to use three one litre cans of Castrol Multi Import Vehicle ATF and claimed that it is compatible for Toyota based on the product labelling. Satisfied and happy I drove back home enjoying the smooth feel of my car without having any single clue of what was about to come. Since I dont have an owners manual I was not able to read the important information regarding proper Toyota transmission fluid. After coming back home and stumbling around this website I found out the real truth. Obviously since the repair was done by a local "mechanic" in his backyard and by cash I screwed myself big time as this son of a gun will not stand his service. Today after reading all your reviews I went to Toyota dealership and purchased genuine Toyota ATF WS one case of 12 cans for $100. Obviously the parts department guy was wondering why do i need so much instead of just 3,4 liters. I told him everything honestly as what had occurred and he suggested to me that instead of going to another local mechanic whose flushing methods may not be proper I should rather do it from them. Having no choice and learned my lesson I decided to flush my transmission from them. The total came out about $200 plus my earlier $100 for the fluids. Not to forget the earlier $85 that i had spent on the idiot. Anyways i was not able to see what exactly Toyota did since i was called back after an hour but i believe that they did carried out all the necessary repairs as were needed. There is no difference in driving and my car still runs smooth as it used to be before all this hoopla. After going thru all these experiences and learning a valuable yet painful lesson i find myself still confused regarding what to believe. Genuine vs non genuine, dealer vs local mechanic and all that. I guess it is all about common sense knowing what and who to choose for when! Again thank you so much for all your help - let my experience serve as a lesson to all of you so that god forbid you dont have to go thru this.
#6 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris sedan auto / Fit auto Join Date: Oct 2009
the A.T.F. can go as far as 100,000 miles . Makes me believe that it's a synthetic tranny fluid . Any thoughts on this ?
#7 |
![]() ![]() ![]() ![]() ![]() Drives: 2008 HB, A/T, Power W/L/M Join Date: Oct 2008
I don't know, but I'm not messing with mine!
There is a sticker right on the neck of the tranny dipstick stating no need to change the fluid. Stick to oil changes.....
Never take eyes off opponent - Bruce Lee |
#8 | |
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
Toyota WS is lifetime, no need to change it unless: it becomes discolored it becomes burnt smelling so that basically means you may end up changing it around 150,000 YMMV what makes it special is: ws stands for world standard and was developed with the hybrid synergy drive systems in mind. Toyota uses it everywhere now so there will be less mistakes moving forward, and one simple ATF fluid for all Toyotas. it is the only ATF that won't destroy toyota hybrids and electric drive systems it has a lower viscosity when cold for energy savings, and lower viscosity at operating temps...the viscosity rises when it gets really hot and then matches atf T-IV viscosity transmissions are specifically built for it. any other fluid can and will cause long term clutch failures, solenoid failures...etc... Last edited by 127.0.0.1; 01-26-2010 at 12:32 PM. |
#9 |
Drives: 2007 4 Door Yaris Join Date: Jan 2009
#10 |
take a look at this . www.amsoil.com/storefront/atl.aspx . Makes me think the WS is a synthetic . Know that the newer VIBES and MATRIX now use synthetic gear oil ( GL-5 ) for the manual tranny . Not sure about new COROLLAs and SCION XDs . Would think so since they too have the same 5 speed manual transmissin and 1.8 ltr. engine . Wonder if the manual tranny for YARIS now comes with synthetic gear oil .
Hard to get that kind of info out of TOYOTA . Bummer .
#11 |
![]() ![]() Drives: 07 Yaris Sdn, 97 4Runner Join Date: Jul 2006
Manual Yaris does indeed come with WS. I drained mine at 75k and refilled with Mobil 1 synthetic.
#12 |
manual tranny for YARIS uses gear oil , not A.T.F.. If I read what you wrote right .
#13 |
No, from what I understand, they put WS fluid in the manual tranny too. I will check with a tech today to confirm.
#14 |
#15 |
#16 |
apparently to verify the type of A.T.F. you'll need to remove the transmission dipstick and should see either W.S. or T-IV stamped just above the FULL MARK . The W.S. stands for WORLD STANDARD .
#17 |
I put AMSOIL Severe Gear 75w-90 in my MT.
#18 |
You probably should have used AMSOIL 75W-90 GL-4 Transaxle Lube...it's what I used and GL-4 is better for the transaxle than the severe gear GL-5, which is meant for differentials.
| Tags |
| atf ws, transmission fluid, transmission oil, yaris |
| enobmort42 - Photo-Scavenger Hunt! | enobmort42 | Photo-Video-Media Gallery | 9 | 03-05-2009 10:52 PM |
| CtrlAltDefeat - Photo-Scavenger Hunt | CtrlAltDefeat | Photo-Video-Media Gallery | 0 | 03-04-2009 02:14 AM |
| YAR1S - Photo Scavenger Hunt! | YAR1S | Photo-Video-Media Gallery | 4 | 03-02-2009 07:44 PM |
| Arkhangel - Photo-Scavenger Hunt | Arkhangel | Photo-Video-Media Gallery | 0 | 03-01-2009 02:03 PM |
| Transmission Fluid | caveatipse | DIY / Maintenance / Service | 2 | 09-15-2007 06:03 PM |
