Old 01-25-2010, 10:45 PM   #19
That's correct for the clutch switch. For the wire, that ebay listing shows it connected to the stalk. I would check with the vendor to see if it's included.
Old 01-25-2010, 11:06 PM   #20
goku87
goku87's Avatar
Drives: Black HB
I feel like an asshole. All my answers were all in previous threads. :( I think the problem is that it's not all in one single place, as others have asked the same questions as I did.
Old 01-26-2010, 01:21 PM   #21
b_hickman11
Drives: 08 Sedan
Originally Posted by goku87 View Post
Okay, so I just need the stalk and wires for the '10? Would I run into any problems if I got one for < '08?
My 2005 Taco had the same cruise as the 2010 Yaris so you could probably go to a junk yard and get one off of any Toyota you find.
Old 01-31-2010, 01:38 PM   #22
Flippy
Drives: Yaris Sedan 2008
Some of us are DIY idiots - I can hardly change a lightbulb but would be interested in the non-dealer route -
So I could buy the parts online - then pay a mechanic to install?
How much ballpark should this cost?
Flippy is offline   Reply With Quote
Old 02-06-2010, 11:36 AM   #23
t2mike2
Drives: '10 Yaris 3 DR - Carmine Red
ive been driving my 2010 Manual hatchback without the clutch switch. Its a little bit of a pain the first few times you accidentally hit the clutch and the rpms shoot through the roof, but after you remember that you just have to hit the brake to disable cruise first then it works fine.
So you dont really NEED to have the clutch switch. I jumped mine out with a spade connector i found. Fit perfect like it was made for it.
P.S. thanks again scott for your help.
~mike~
t2mike2 is offline   Reply With Quote
Old 03-21-2010, 03:18 PM   #24
Originally Posted by G6-R View Post
and thit you buy everything you needed for a MT Yaris CruiseControle and does it work ??
regards JO
Yes, but not for your car. European Yaris ECMs don't have the cruise control function built in, so to add cruise to yours, you would need an aftermarket kit.
Old 03-24-2010, 10:35 PM   #25
YarisGoFar
Drives: '10 Yaris 3Dr LB, MT Meteorite
2010 2 Dr LB 5 Speed Cruise Control
I'm really stoked about buying my first yaris this weekend, hopefully. Literally pulling my hair out trying to find a LB 5 speed with cruise, don't have much hair to spare. I'm in South Jersey and the dealer found a few of them but the closest is literally 400+ miles away.
I need to make sure I fully understand before my purchase because after reading this, I'll forget trying to get one with cruise and do it myself.
I commute nearly 100 mi. round trip everyday to work and can't do it any longer without cruise on my 2002 Neon. Can't wait!
All I need is a 2010 Yaris 5 speed with the PQ power package, which I planned on buying anyway, then purchase a factory cruise stalk for about $80, a Clutch switch for about $30 and a couple of hours work with a careful install and viola, I have Toyota Factory Cruise Control on my 5 speed with all factory bells and switches, no pun intended?
Any documentation or how to install / mount and wire the clutch switch & stalk?
YarisGoFar is offline   Reply With Quote
Old 03-24-2010, 10:45 PM   #26
Welcome!
Start with this thread:
http://www.yarisworld.com/forums/sho...ght=cruise+faq
Old 03-24-2010, 10:55 PM   #27
YarisGoFar
Schmokin' YOU GUYS ROCK THE HOUSE!!!!!
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
