#19 |
Half a Bubble Off Plumb
Drives: 2009 Yaris Sedan Join Date: Mar 2009
I used lots of Arco Graphite in the '70s and early '80s. Thought it was good stuff.
#20 |
Learn to Relax
Drives: 2007, Meteorite, LB Join Date: Dec 2008
I talked to someone at the can recycling center and he was trying to convince me that changing the filter every 2,000 miles and changing the oil when it gets black was the way to go. I can't buy it for the simple reason that blow-by will break down the oil and also create sludge.
#21 |
Whether oil's black or not doesn't correlate very well with how contaminated it is with acids, fuel and junk or how the additives may have broken down. Black oil can be good oil that's got combustion soot in suspension. If you want to be precise about changing oil by its condition you should subscribe to an oil analysis service. Not wanting to spend the money and energy on that, I'll just change at the factory recommended intervals.
#22 | |
![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Feb 2010
Of course... all respectable oils today are detergent oils. So the "difference" between brand X and Brand Y colors is likely either imagination or a difference in the driving and conditions between the two samples. Note that I'm only addressing the color of the oil and not things like varnish, which are an entirely different situation which can very well be quite different between oils. -Steve |
#23 | |
Crazy Oil Sniffer
Drives: MM 09 Yaris 5 Dr LB "Click" Join Date: May 2009
| Why the top fuel level bar lasts so long | CTScott | General Yaris / Vitz Discussion | 41 | 12-29-2012 10:07 PM |
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 03:34 AM |
| Last Fuel Bar | andaconda | Fuel Economy Forum | 37 | 04-29-2009 02:35 PM |
| Compiled 1NZFE Used Oil Analysis | craigq | DIY / Maintenance / Service | 7 | 09-10-2007 04:27 PM |
| Free gas for any vehicle. | ketel0ne | General Yaris / Vitz Discussion | 4 | 09-19-2006 08:07 AM |
