Old 02-04-2010, 10:14 AM   #19
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
and your kit uses the HIDs as drls? What temperatures do you offer?
Old 02-04-2010, 11:37 AM   #20
^ iirc, he has everything ranging from 3500 up to 8000.
Old 02-04-2010, 03:56 PM   #21
actually i sell 3000k to 10000k is the normal...12000k is bit more money....i can get higher temps as well as weird colours like green and red, but they're more expensive
right now i have H4 bixenons in 4300k, 5000k, 6000k, 8000k, and 10000k, iirc
Old 02-04-2010, 04:31 PM   #22
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
Don't be put-off by the relay's used for bixenon - they are super easy to install. No real wiring to do, just plug and play, other than one 12V connection to the battery.
I lost my Hi-beam indicator on the dash, but everything else is as-normal. Don't have DRL's so can't speak about that.
When I had a xenon low/halogen high piggy-back setup, the indicators were normal, but the pattern on both hi and lo sucked ass, and the hi-beams looked awful when switching from HID to halogen.
Old 02-04-2010, 05:34 PM   #23
1.5
Form>Function
1.5's Avatar
thebarber i know Im prolly becoming a pita lol but u think you could post some color samples? Id like to see your 8k, 10k, and the "red" you're talking about. thanks.
Old 02-04-2010, 07:54 PM   #24
ive never actually ordered RED, but i have it available
ill have to dig for some colour samples of the 8 and 10k, but they're the same as any other colours you'd fine online...
Old 02-05-2010, 09:25 AM   #25
1.5
Form>Function
1.5's Avatar
im a complete idiot lol i never even checked if my car had drls, I just assumed it did when everyone was talking about them lol. I dont even have them on my car, so I just need the regular bi-xenon version if its different.
Old 02-05-2010, 11:03 AM   #26
the ones i sell are all the same...they have the relay. since the hid's run directly off the battery, the relay is necessary so when there is any voltage running thru the wiring, they'll turn on and run off the battery. it really only uses 1 stock headlight plug as a switch for the hid system....
so whether you have drls or not, the system is the same. my yaris doesnt have drls, but my aveo does. both cars have the same kit
Old 02-05-2010, 06:37 PM   #27
1.5
Form>Function
1.5's Avatar
ok i see well ill deff let you know when im ready just wana see the examples of the colors. I had 8000s in my first 2 and 10000 in my last car. All 3 looked different so Im just looking for examples of yours.
Old 02-05-2010, 06:53 PM   #28
Meteorite_Marty
Drives: 2008 5-door Yaris Hatchback
I don't like the idea of losing some of the dash notification icons (the high beam icon) just because the HIDs are installed. Seems like the HIDs aren't really meant to work properly with the car's dashboard alerts. Are there any other limitations when using fog lights in this system? Does this icon disappear too? Maybe someone has got all dash icons to function with HIDs, and could advise how? Clearly, we (at least I) don't know enough about the installation, or how the HIDs electronics work with the car's default wiring, if certain things are not functioning after the install. Just my take... I really would like to learn to make it all work together and not lose any dash symbols in the process. I spent so much effort getting everything Toyota factory-standard wiring when adding my aftermarket fogs and headlight stalk, what I would want to do similar for HIDs (even though there is no factory option for HIDs on this car).
Meteorite_Marty is offline   Reply With Quote
Old 07-08-2010, 06:24 PM   #29
joeljcruz86
Little Eggy
joeljcruz86's Avatar
Drives: Toyota Yaris Liftback 3DR 2009
Send a message via AIM to joeljcruz86
I have a problem with my HID's. For the first 2 months since i've had them, they were working fine until now. They only come on when i have a normal headlight bulb plugged into the leftover/passenger side harness. I don't know why this is happening. I was thinking of using a wire with a 10k ohm 1/4watt resistor in the middle to plug into the to top hole on one end and the other to the right hole of the left over harness. This method i found on one of the forums is for to get the high beam light to show in the guage cluster. I'm hoping that this method would substitute the "normal headlight bulb" to get the HID's to be working as well.
If anybody has any solution and knows for a fact that any of the methods is not going to work, PLEASE LET ME KNOW!! THANK YOU.
joeljcruz86 is offline   Reply With Quote
Old 07-29-2010, 04:54 AM   #30
brieghne
Drives: yaris sedan 2009
i got my philips brand hid 6000k for $200 brand new if your interested lemme know ;) i say the lights look alot better than of those generic ones :D
brieghne is offline   Reply With Quote
Old 07-30-2010, 12:44 AM   #31
Meteorite_Marty
Thanks for the info. Did you figure a way to get the highbeam dash icon to work?
HID Kit ecmiyake DIY / Maintenance / Service 5 12-12-2009 05:21 PM
XenithXenon HID Conversion Kit CorSport CorSport 0 09-03-2009 05:11 PM
Xenon-Vision HID Conversion Kit - $120 Shipped/$160 Shipped for Slim Ballast phu@xenon-vision Sponsors Classifieds Area 8 03-06-2009 02:33 PM
