#19 |
Are Hefty bags good enough to store R comps in?
#20 |
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
They might be good if you stuck the tires in the fridge. Take it from someone who used to hide in Hefty's as a kid while playing hide-n-seek with the cousin, there's no air-condition in there! LOL
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
#21 | |
Joey
So far I've got my heart set on the lightest rims I could find (MSRP about $800/set, but will keep looking for better price) + tire budget (limit $800/set). Total of $1600 sounds about right, though it could be much lower depending on chosen tires and certain retailers. My local tire guy always gives me a good deal so I'll see if he's got what I want first.
#22 | |
![]() ![]() ![]() ![]() ![]() Drives: 2015 H Production Yaris Join Date: Oct 2009
A rear bar is also not legal for stock class.
2005-2008 SCCA Solo BS National Champion 2017-2018 SCCA H Prod National Champion
#23 | |
Apexing Egg!!
you could get these if you still want RA-1's: http://www.good-win-racing.com/Mazda...t/21-0046.html $900 for wheels, tires, mounted, and balanced? win or put, street tires on them, use the rest of your budget at microimage on a rear sway bar and shocks and you are can run ST and do track days to your hearts content!
HighTach Motorsports 2007 Toyota Yaris-ARGH!! Mods: Tokico HTS, 6.6 kg F, 6.1 kg R custom springs, 23 mm RSB, 2-way TRD LSD, 15x7 +25 Team Dynamic wheels, 195/55/15 Dunlop Star Specs, Cobra Suzuka S |
#24 | |
Joey
I'll check in with my shop tomorrow when they open first, but I'll bookmark that link for now. Thanks!
Man this is confusing...
#25 |
Yes, you can run in ST.
#26 |
Joey
Sweet! Thanks for your help Jason
#27 |
Keep in mind none of the tires you were looking at are ST legal - must have a 140 or higher tread wear rating for ST.
#28 |
Joey
I guess I'll just have to use the Falkens again for the next event and just grab a sway bar and CAI way before. I can still wait a minute to get rims and tires seeing as how I need to make enough storage space for them anyway. Can I still run the sway bar and CAI in ST? I'm looking at the class rules right now, but doesn't really say anything specific about engine and suspension parts til you get to SP.
http://www.sfrscca.com/solo2/faq/auto.htm#114 I take it "common parts" also include CAI? Or is it limited to a filter-only upgrade? Is sway bar also considered common?
#29 |
Some classes limit you to options that would come from the dealer. It's confusing to me that's for sure.
#30 | |
You want to look at section 13-19, specifically for Street Touring.
#31 | |
Typically any class beyond stock you would use an aftermarket part that is better than the dealer install stuff, so it becomes a non issue.
#32 |
What?
Drives: 2007 Yaris LB Join Date: Nov 2008
Yes, heavy-duty black trash bags are more than adequate for storing tires in.
The goal is to keep them isolated from ozone, sunlight, and temperature extremes. |
#33 | |
Joey
#34 | |
ST will let you do a lot of things to make up for the lack of the stock classes sticky tires: CIA, header, cat-back, ECU, pulleys, shifter, suspension, race seats, wings. Just for comparisons sake... We took our stock class RX-8, that had won four strait BS championships and converted it to STX in 2009. The difference in prep between stock and STX was about $10k, and the car was slower in STX trim - it is no longer in STX trim. I like race tires. imho it is hard to beat the transformation that occurs when you put race tires on an otherwise "stock" car. The comfortable daily driver feels like a racecar with just a simple tire change. While an ST car reminds you on a daily basis with its poor ride quality, noisy exhaust and limited ground clearance. And in almost every case a stock class car on race tires is quicker than a no expense spared ST car. Spend more money to go slower? No thanks.
#35 | |
Apexing Egg!!
now what i would REALLY like to do is run an S2k in stock class with R-comp's. THAT would be fuuuun!
#36 |
Apexing Egg!!
Here is a chart someone else posted here for your help:
http://autocross.com/er/carmodandclassification.pdf now that you have decided on a class, picking a tire will be easy. The fastest tire last season was the R1R, but they will not last long if you use them on the street. If you are only bolting them on to race with, they would probably be your best choice. The next best would probably be the Kumho XS or Direzza Star Spec. I love my star specs, i daily drive them, autox on them, and do track days on the same tires, they are amazing pieces of rubber! ST allows you to run up to a 225 tire on a 7" (or7.5"?) rim. you can still do alot of parts, springs, shocks, (or coilovers), rear sway bar, seat, header, intake, exhaust, and i am sure there are more. Links: http://www.tirerack.com/tires/tires....t+Z1+Star+Spec http://www.tirerack.com/tires/tires....Model=Ecsta+XS http://www.tirerack.com/tires/tires....VAN+Neova+AD08 http://www.performanceplustire.com/p...490#prodAnchor
| THE BEST AUDIO SPEAKER | phenoyz77 | In Car Entertainment + Electronics (audio / video / alarm) | 58 | 01-20-2010 10:46 PM |
| FS: Waterloo, ON: 14's and r comps | thebarber | Items for Sale by private party | 7 | 01-21-2009 06:02 PM |
