Old 03-14-2013, 07:19 PM   #19
sant_ashu
Drives: toyota yaris 1.0 t3 2004
Originally Posted by hw6515 View Post
I can take pic if you need one, but is easy to find with that img in the link
http://www.yarisworld.com/forums/showthread.php?t=43903
please post a colored pic with some arrows that will be great.
you can post on the thread above.
cheers
sant_ashu is offline   Reply With Quote
Old 03-14-2013, 09:09 PM   #20
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
This is on my hit list.Will do it next, i am on 93 000 Ks Thanks for the heads up mate!
I've changed the drive belt, manual transmission fluid. This is next. :) anything else we should service or replace?
Old 03-14-2013, 09:31 PM   #21
Yarflana
Drives: 2008 Base Model
I am still trying to understand how you can tell from the way the car runs as to whether this needs changing, cleaning or what. Sounds like to me this generally will either be fine or just need cleaning, but I am just not sure how to tell it needs either from how the car runs.
Thanks,
Yarflana is offline   Reply With Quote
Old 03-14-2013, 09:49 PM   #22
Hershey
" My engine idles rough and oscillates badly when either in drive or a/c on in drive; when in neutral, it idles smoothly. I would like to know before the check engine light comes on. "
Our '08 sedan has done this since new . Replaced the P.C.V. at around 20,000 miles and no difference . Still idles rough when in gear at stops or idling . Fine when in neutral or park . The car now close to 58,000 miles .
Old 03-14-2013, 11:58 PM   #23
Yarflana
Did your PCV really need replacing at that point?
Old 03-15-2013, 11:58 AM   #24
Hershey
Thought it might help with the rough idle . No difference . Not all that expensive or difficult to replace .
Old 03-15-2013, 06:07 PM   #25
UberSilver
UberSilver's Avatar
Drives: 08Yaris2D, 88LandCruiser.
Just cleaned mine, it was a little clogged. Runs smoother now.
UberSilver is offline   Reply With Quote
Old 03-15-2013, 09:38 PM   #26
Checked mine. Have about 90500 miles on the odometer. Wasn't clogged, rattled freely. Cleaned it off anyway and put it back in.
Old 03-15-2013, 10:37 PM   #27
Yarflana
Thinking about checking mine tomorrow as well. Must be a fad.
Old 03-16-2013, 11:06 PM   #28
lol. One of the bigger things right now on YW, I guess. Since everyone was talking about theirs, and since it's such an easy thing to check and clean, I just thought, "might as well." Also wanted to see the condition of mine after 90,500 miles.
PCV valve question window_lee DIY / Maintenance / Service 31 10-22-2014 04:05 PM
Valve Noise barryware DIY / Maintenance / Service 25 02-13-2013 02:39 PM
Two different PCV valve Part#s for Yaris? auxmike DIY / Maintenance / Service 6 03-18-2011 08:55 AM
PVC valve routine? N9QGS DIY / Maintenance / Service 13 05-26-2009 07:32 PM
2007 Yaris LB - Valve Adjustments Pavel Olavich DIY / Maintenance / Service 3 03-30-2007 05:34 PM
