Old 03-06-2010, 02:51 PM   #19
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
There's a reason the magic happens in the midrange...
That's where human's hearing is the most sensitive or attuned.
Hey Taln, can you run a graph for the IDQ 12v3 D4? I'd really like to know what a pair of those in 1 cube each sealed with 750 Watts a piece would do...
here's the frequency response, and cone displacement graphs... you'll well within the X-max, so distortion should be low. QTC of a 1cuft box per sub is .691, fairly low for a sealed setup.
Red line = 2cuft sealed (1cuft each) looks like usuable range down to 30hz.
Blue line = 10cuft sealed (to simulate what an IB setup might look like)
The IB can safely play about 5hz lower than the Sealed can, I don't know what the x-mech is on that sub, so its possible it could safely play much lower, but with added distortion.
Old 03-06-2010, 03:24 PM   #20
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Hmm...I'm wondering if...
Those L8s are usable down to 40 Hz...
...Instead of hijacking this thread, I'll PM you Taln...
― Thomas Paine
Old 09-26-2011, 10:09 PM   #21
hazed06
hazed06's Avatar
Drives: lexis is 400
Any one out there know what software was used to get those graphs? or a similar one?
hazed06 is offline   Reply With Quote
Old 09-27-2011, 10:09 PM   #22
Viperoni
Drives: 2005 Toyota Echo
WinISD online and WinISD the installable application are both good freeware apps to use.
2006 Saturn Ion Redline
Old 09-30-2011, 10:43 PM   #23
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Originally Posted by talnlnky View Post
From Sqcomp to talnlnky:" Hey Taln, can you run a graph for the IDQ 12v3 D4? I'd really like to know what a pair of those in 1 cube each sealed with 750 Watts a piece would do..."
That is my subwoofer an IDQ 12v3 D4 in a sealed box of 1 cu feet. and I can only say good things.
D.
CLA 250, 4MATIC
