Old 03-11-2010, 12:59 PM   #19
SpaceShot
SpaceShot's Avatar
Drives: 2008 Yaris 5 speed HB
It really shouldn't be any problem at all.
I regularly do 196km / day just for my commute, and have done 960km / day for a vacation trip.
Inspect tires, brakes, and top off fluids before you go. And bring some music or audio on CD or MP3. You may have a more difficult time holding up than the car will.
SpaceShot is offline   Reply With Quote
Old 03-11-2010, 01:22 PM   #20
sbergman27
sbergman27's Avatar
Drives: 2008 Yaris Sedan
Originally Posted by talnlnky View Post
You have the 1.3L engine, so if anything, your car will do even better than mine.
What engine do you have?
sbergman27 is offline   Reply With Quote
Old 03-11-2010, 01:35 PM   #21
Kal-El
Kal-El's Avatar
That's what was wondering. The 1.3 is the smallest and has to work harder.
Old 03-11-2010, 01:41 PM   #22
sbergman27
sbergman27's Avatar
I believe that the 1.0L 1KR-FE is available for the HB in some locales. (Though not, I suspect, Eugene Oregon.)
http://tinyurl.com/y8f7np4
http://tinyurl.com/yawe6nt
Old 03-11-2010, 04:12 PM   #23
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
ive done 1600-ish km straight...about 17h of driving w/ just fill-ups for gas in the yaris....no problems
300km a day is peanuts! do the 900km in one run!
+1 900kms is a one shot run if you are in good physical condition,the Yaris will cruise all day at 110-130kms per hour with no negative effects,just make sure your oil and tire pressure are up to specs.
What problems do you imagine arising on a 900km drive?
Old 03-11-2010, 04:57 PM   #24
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
1.5L, I understand you guys are thinking in terms of torque & hp and rpms.... As long as he has enough oil that should only be an issue in mpg's I'd think. The guy isn't going to be revving up to 5k is he? Does he plan on driving 90mph....errr... 130kph?
I was thinking in terms of heat... guy is in Australia, 1.3L engine should put out less heat than the 1.5L, and i'd imagine the radiators are the same size.
what are the HP/Torque ratings on the 1.3L engine anyway?
Old 03-11-2010, 06:22 PM   #25
sbergman27
sbergman27's Avatar
The cooling system has vastly more capacity than required to maintain the engine at whatever temp the thermostat's spec is. 180F, I believe. You could run along in Death Valley and see the same coolant temps as in Alaska. (After warm up, of course.)
Then engine working surfaces in the 1.3 will be seeing higher local metal to metal pressures than the 1.5. Though I would not expect the difference to be substantial. It may well kick into lower gears more, which could be significant. But I wouldn't worry much.
Regarding power and torque, take your pick:
http://tinyurl.com/y8s4cvv
http://tinyurl.com/yeh2oru
http://tinyurl.com/ybsjftc
-Steve
Old 03-12-2010, 12:36 PM   #26
RedRide
RedRide's Avatar
Even on very long trips, I suspect you will be stopping periodicly to eat and attend to other needs.
So, when you do simply check the vitals of the car.
Old 03-14-2010, 07:30 PM   #27
Tardis
Tardis's Avatar
Drives: 2007 Yaris Hatchback
Guelph Ontario to Charlotte NC 12 hours straight. Stopped south of Pittsburgh for gas averaged about 75mph on the interstates. No problems. I drive it daily 180kms round trip to work.
Tardis is offline   Reply With Quote
Old 03-14-2010, 07:33 PM   #28
sbergman27
sbergman27's Avatar
I find that keeping an empty 32 OZ Gatorade bottle in the car saves significant amounts of time. Best to keep the lid with it.
Old 03-14-2010, 07:47 PM   #29
BuildCode
BuildCode's Avatar
Drives: Black 5-Spd Sedan S
Stopping won't help the engine. Engines don't need to rest. In fact, they like to run at their normal operating temperature. Layovers hurt them more than driving for extended periods.
I'm late to this thread, but I'm going to second R2D2's +1
This is the exactly correct, enjoy the trip!
BuildCode is offline   Reply With Quote
Old 03-14-2010, 08:32 PM   #30
yarswiss
Albino truck smasher
yarswiss's Avatar
Drives: '07 Yaris LB Auto
Your car can take it, but make sure you can.
I drove for 7 hours up the coast of California, averaging 80mph and stopping twice for less than 5 minutes. The only problem I had was my shoulders and rear were throbbing from pain as the seats are quite firm. Make sure you can physically handle it most importantly. Frequent breaks and a seat cushion will help.
yarswiss is offline   Reply With Quote
Old 03-18-2010, 07:47 AM   #31
signs
Drives: toyota yaris
thank u guys! Your replies are really helpful!! Looks like I shouldn't be worried.
True, I think I'd better be up for the long drive as I have a bad tendency to get sleepy when driving too long..! More loud music & windows down I guess
signs is offline   Reply With Quote
Old 03-18-2010, 09:35 AM   #32
eht13
Drives: .
Caffeine.
eht13 is offline   Reply With Quote
Old 03-18-2010, 09:48 AM   #33
sbergman27
sbergman27's Avatar
After driving long distances on a regular basis in my Chevy Sprintwith no ill effect, I was surprised to find that the Yaris' seat gave me an ache in the right pelvic region. Removing my wallet while driving eliminated the problem entirely. The contouring of the seat was jamming the billfold into my side for hours on end.
-Steve
Old 03-18-2010, 10:54 AM   #34
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
I hope you're pulling off on the side, at least!
Old 03-18-2010, 01:14 PM   #35
41magmag41
Drives: Loaded 2007 mica silver sedan
Talking
Ditto, that is unless he ties it underneath the steering wheel then he doesn't have to pull over. LOL
41magmag41 is offline   Reply With Quote
Yaris 06 T Spirit advice needed ! nocturne_sa General Yaris / Vitz Discussion 1 01-03-2010 05:24 AM
my yaris, courier driving jdleafs Fuel Economy Forum 8 11-30-2008 09:05 PM
