#19 |
ヴィッツ ドライバー
Drives: 2006 3d 1.0 Linea Sol Join Date: Aug 2007
Another bang for Toyota/Lexus: Consumer Reports puts Lexus GX on "Do Not Buy" list due to rollover fears. It's strange how, as mentioned in the article, the other twin Totota 4Runner is not mentioned. Anyway, looks like soon enough you guys over there will be recommended to buy low-sprung sports cars only...
http://www.autoblog.com/2010/04/13/c...uy-list-due-t/ |
#20 |
Drives: Yaris 3dr Hatchback Join Date: Mar 2010
#21 |
No, this is actually a HORRIBLE idea. The reason this became a big mess to begin with (other than all the hurt people, doesn't matter to corps). Was the fact that a guy that TEACHES driving to driving instructors died while on the phone. During that conversation he told the 911 operator everything he was doing. If you turn off the ignition you will lose your power steering. Pretty much anything you guys can suggest that would work he knew how to do. So, dont turn off ur car if the throttle gets stuck. Put it in neutral coast to the side of the hwy and turn it off. |
#22 | |
Drives: 07 Yaris Sedan Aero Join Date: Oct 2006
my swift had a 1.6L with 3 spd automatic... well... RPM always stayed high. :) but god, it had alot of power for the little car.. hehe
#23 |
so if you revved it real high in N and dropped it into first you will not cause dmg? That doesn't sound right? Please explain.
#24 | |
Half a Bubble Off Plumb
Drives: 2009 Yaris Sedan Join Date: Mar 2009
#25 |
ヴィッツ ドライバー
Turn off the ignition and the steering will lock up- not wise when you're moving.
#26 |
#27 |
There is a click back that turns off the ignition and leaves power accessories on. The steering does not lock. As has been said many times, the first step is to put on the brakes. The brakes are more powerful than the engine. If you pump the brakes, you will lose vacuum assist. You won't if you put them on and keep them on. Next is to put the transmission in neutral. There's no lockout of that, and no negative to doing it. Turning off the switch really isn't the first thing to try, but will work. A Highway Patrolman who couldn't deal with that is just shameful. Tragically so in this case. Everyone ought to get taught basic emergency procedures for dealing with a stuck throttle, failed brakes and such in driver's ed.
#28 |
Drives: yw calls me douche and racist. Join Date: Aug 2007
As a professional bone head, and one who bounces off the rev limiter when entering some corners, I say its fine. I've boinged off the rev limiter for minutes at a time.
Idk what anyone says. My engine is running very healthy on all three cly. |
#29 |
#30 |
#31 |
Learn to Relax
Drives: 2007, Meteorite, LB Join Date: Dec 2008
#32 |
GRRRROOWPAPAPAPAPAPAPAPAPAPAPPAPAPAPAPAPAPAPAA.
Thats what it sounds like when u WOT in neutral. |
#33 | |
XBL: Jeemee Ghost
_________________________________________________ Nitto Axle-Back--Tanabe DF210s--UR 23mm Rear Sway Bar--Penguin Garage 10mm Hub Spacers |
| Coasting in neutral | bankrobber | Fuel Economy Forum | 9 | 03-11-2010 03:55 PM |
| Fan setting to neutral (not hot or cold) defog? | PhasedWalker | Fuel Economy Forum | 3 | 07-19-2009 01:21 PM |
| Deficit Neutral? | yaris-me | Off-topic / Other Cars / Everything else Discussions | 0 | 07-08-2009 12:08 PM |
| Shifting into neutral | otterhere | Fuel Economy Forum | 24 | 01-17-2009 02:46 PM |
| Park, rear, neutral, drvie, 3,2,1 thingy | BMGYaris | Cosmetic Modifications (Exterior/Interior) | 7 | 05-11-2007 11:06 AM |
