Old 03-22-2010, 08:17 PM   #19
wholenizz
wholenizz's Avatar
Drives: 07 yaris hatchy
Originally Posted by H3LlIoN View Post
If it's any consolation, it looks sweet slammed.
lol thank you! cept i can't drive it right now
wholenizz is offline   Reply With Quote
Old 03-22-2010, 10:37 PM   #20
Vb2ner
Team VAJJ
Vb2ner's Avatar
Drives: 2007 Yaris sedan Flint Mica
Yeah, the xxr's look good man! they rub though, don't they? Are they +15's?
So I honestly don't see how the spring install could be linked to that, because as I said, the angle of the axle could not have been bad enough to break it, and it obviously is not due to you not installing the suspension properly.... I would say it was probably on it's way out due to prior stress? How long have you been lowered? Faulty part perhaps? Either way, suck it up, get a new axle, and enjoy the stance:)
2007 Yaris Sedan DD, 95 VW Jetta boosted and laid out...stretch and poke FTW
Vb2ner is offline   Reply With Quote
Old 03-22-2010, 11:55 PM   #21
wholenizz
wholenizz's Avatar
they are 16's and thx.
Old 03-23-2010, 12:23 AM   #22
az_saguaro
What to Mod Next?
Drives: 2008 3Dr HB, Bayou Blue
You don't need needle bearings, you need a CV joint, cv boot and bands. But then you would need special tools to remove and replace it from the half shaft (talk about a PITA) and a special tool to clamp the band back onto the boot.
Best bet is to replace the half shaft it's easier and most likely about the same price as a single CV joint with boot, bands and grease.
az_saguaro is offline   Reply With Quote
Old 03-23-2010, 12:30 AM   #23
YarisSedan
Drives: 08 Yaris Sedan
Exact same thing happend to me when i was helping advocate install his springs and struts. Luckly i caught it in time before it came to this and was able to pop it back in place. You should be able to do the same. And possibly get away with using a very large zip tie or 2 of them to hold the boot back in place if the steel band is damaged and drive it to a shop who can put a new band on because it will require a special tool.
Putting the axle back is tricky you have to get the joint lined up. Once its lined you have to hammer it in place by doing jerking forward motion like you are using a slide hammer. You will hear a pop and in it goes. Then slide the boot over and zip it in place and your good to go good as new. Just be careful to dont get any dirt or debri in the grease when you are handling it to get it in place or it will cause the axle to fail prematurely in the future.
Any time you remove the struts you have to support the axle or it can pop out and it is a real real pain in the ass to put back with the boot intact cause you have to try to feel with your hands through the rubber and line it up. Sometimes you get lucky otherwise you have to remove the boot to do it. But since your boot has already removed itself you should be able to see what your doing.
Old 03-23-2010, 12:35 AM   #24
YarisSedan
Oh if that dosnt work what you can do is simple remove the piece hanging out from the car. The remaining piece thats stuck in the transmission you just take a pry bar and pop it out and take both pieces to a auto shop and have them put it back together for you shouldnt cost you much. They might chuckle and ask what happend but i cant forsee it costing more than 50 bucks.
Old 03-23-2010, 07:21 AM   #25
Vb2ner
Team VAJJ
Vb2ner's Avatar
I meant offset, not rim size, and -15,hehe
Old 03-23-2010, 01:47 PM   #26
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Good luck with the fix. Your Yaris looks great! Next time you're up in Portland I'd love to see it!
Old 03-23-2010, 06:33 PM   #27
wholenizz
wholenizz's Avatar
hell ya bro we should meet up =]
Get your post counts here! *read 1st post for rules* Astroman Off-topic / Other Cars / Everything else Discussions 3414 11-04-2012 09:03 AM
Progress Lowering Springs vs Tanabe DF210 lowering springs jyfro_13 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 03-24-2010 02:38 AM
FS: Progress lowering springs Cvc9216 Items for Sale by private party 0 10-23-2009 07:41 PM
2006 Toyota Yaris 5dr. LiftBack Lowering Springs yaya Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 05-14-2009 01:38 AM
Lowering Springs - Questions ~ AGAIN ~ jaspie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 01-16-2007 12:23 AM
