Old 03-23-2010, 03:48 PM   #19
zachryboles
Chunk love Yarii
Drives: 2008 Silver 3DR Yaris Liftback
where is the wiring that your doing that to...... pics if you could anyone?
zachryboles is offline   Reply With Quote
Old 03-23-2010, 03:52 PM   #20
If you look at the first page of that thread, I have pictures of the TPWS module and the connector with the wires.
Old 03-23-2010, 04:00 PM   #21
fiia
fiia's Avatar
Drives: 09 Flint Mica Sedan
hm. I'll look into it asap. Thanks much!
btw, not that I'm too concerned, but does this void any sort of warranty for electrical parts...and if at some point down the road I DID want to use TPMS, would it be easy to re-wire?
fiia is offline   Reply With Quote
Old 03-23-2010, 04:07 PM   #22
Nothing voids the warranty, unless something fails as a direct result.
To reverse this mod, you simply disconnect the brown from the white and splice it back together. The switch method allows you go back and forth by simply flipping a switch.
Old 03-24-2010, 12:40 PM   #23
fiia
fiia's Avatar
Did the splicing today, and it works! thanks CTScott!
Old 03-24-2010, 01:02 PM   #24
sbergman27
sbergman27's Avatar
Drives: 2008 Yaris Sedan
One of these days I'll figure out the protocol for the Yaris TPWS and make a device to do so.
So... would this be something that could be done via the Scangauge II's XGauge feature? Xgauge allows you to send arbitrary queries to the ECU and display the response, scaling and/or offsetting it as appropriate. Essentially, it allows you to define arbitrary new gauges. That really would be quite slick.
-Steve
sbergman27 is offline   Reply With Quote
Old 03-24-2010, 01:08 PM   #25
-Steve
No. From what I've found with things like turning off the seatbelt chime via can message to the cluster, you need to send more than one command, and the Xgauge mode only supports sending one packet.
Tire rotation: Does TPMS recognize tire position? jcdrotos Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-17-2011 02:00 PM
tpms compatibility? bwong2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 07-11-2009 09:33 AM
TPMS Gauges - do they exist? Sodium Duck DIY / Maintenance / Service 24 03-01-2009 12:18 AM
15" TPMS friendly wheels for my '08. Ideas? auxmike Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 12-08-2008 08:01 PM
TPMS TinyGiant Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 10-22-2008 03:57 PM
