Old 03-24-2010, 01:39 PM   #19
seth_man
seth_man's Avatar
Drives: 08 Liftback
the rear shocks bolt in, the fronts are inserts that fit right inside my Megan coilover front shock tubes. if you can install shock inserts then you can have konis in your yaris. if you dont already have megans or bc's over whatever other coilover will fit around the insert they you will have to do your own fab work. i do not know if the insert will fit inside the stock yaris shock tube or not.
seth_man is offline   Reply With Quote
Only in Texas - Man distracted by pelican drives Bugatti in marsh MadMax Off-topic / Other Cars / Everything else Discussions 27 11-16-2009 05:26 PM
The Man Test *MAD DOG* Off-topic / Other Cars / Everything else Discussions 17 09-03-2009 02:28 PM
MJ dead 90tsi Off-topic / Other Cars / Everything else Discussions 28 06-26-2009 02:20 PM
Fat man springs... Slick Wheels, Tires and Suspension Forum sponsored by The Tire Rack 18 04-25-2009 12:02 PM
100 Skills a Man should know Bob_VT Off-topic / Other Cars / Everything else Discussions 5 03-13-2009 10:46 PM
