Old 04-29-2010, 04:27 PM   #1
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
those aren't usually called electronic crossovers. They are normally just called passive crossovers because they don't require a power source to operate. If you call them electronic crossovers, people might think you are talking about active crossovers which are the crossovers built into your amplifier, or a stand alone powered crossover like this
Also, passives 99.9% of the time are installed in line with the speaker wire, where as active is installed in line with the signal cable(RCA's). that .1% of the time I alluded to are things called Fmods
Hope you have a free weekend, cause you have your work cut out.
Old 04-29-2010, 05:22 PM   #2
Herbicidal
Just a Herbicidal maniac.
Herbicidal's Avatar
Drives: 2008 Yaris S Sedan Flint Mica
Where did you buy the digital decibel meter? and how much did you pay for it?
From HERE. Basically $30.
I stand corrected! Thank you!
2008 Toyota Yaris (Vios) 'S' sedan, Flint Mica, dropped on TRD springs, TRD anti-sway bar. Tinted rear windows. Lenso Samurai SC02 hyper black 17" x 7" rims, wrapped in 205x40x17 Federal ss595's. Color matched eyelids. Vios badge. Body color trunk trim (was chrome). Lamin-X tint on rear tails. Custom center exit exhaust. Tanabe front strut tower brace.
Herbicidal is offline   Reply With Quote
Old 04-30-2010, 12:12 AM   #3
Herbicidal
Herbicidal's Avatar
Well I managed to squeeze in maybe two hours tonight. I worked on deadening the right wheel well (just behind the white bottle of rubbing alcohol) and just about all of the rear deck. Next will be the drivers side rear wheel well, the floor under the rear seat and up to the back of the front seats, then I think I can install the rear speakers and put the back 1/2 of the car together again so I can drive it. After that, I think I will work on one door at a time. In the upper left corner of the picture you can see some wire and connectors. To much of a pain in the ass to deaden right there, so I put the RAAMmat on the inside of the 'C' panel plastic piece instead. Should work fine. One of my neighbors kids came by for a look and said "that's cool!". Made my night.
Here's just one pic from tonights work.
Old 05-01-2010, 11:22 AM   #4
Herbicidal
Herbicidal's Avatar
Well I realized last night that I overlooked getting some kind of speaker adapter to mount my new speakers in. So after some internet searching I found Car Speaker Adapters.com I found a set for the rear 6x9's and for the fronts too. They have already shipped via USPS, so hopefully by the middle of next week I'll have them. In the meantime, I'll continue with sound deadening, so by the time they arrive I should be ready to put the back 1/2 of the car together again.
Old 05-01-2010, 12:01 PM   #5
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Herb...
Did you have that nasty metal anchor on the C-pillars like I did? You knw, in the area that you didn't want to deaden because of the clips...
― Thomas Paine
Old 05-01-2010, 02:01 PM   #6
Herbicidal
Herbicidal's Avatar
Herb...
No I didn't. You can just see one of the C pillar panels laying backside up (has a blue connector up in one corner) and there were like only 4 connectors I had to pop out. The panel on both sides came out real easy. I used a long screw driver to get next to each connector and slowly worked it out. No problem whatosever.
Old 05-01-2010, 05:39 PM   #7
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Okay...So you DON'T have the curtain airbag option? Just making sure. I know there is a metal "stud" (for lack of a better descriptor) that anchors the c-pillar in mine. Boy was it a headache to get off...
― Thomas Paine
Old 05-01-2010, 07:39 PM   #8
Herbicidal
Herbicidal's Avatar
Correct. No side air bags. Interesting that you do!
Old 05-02-2010, 12:52 AM   #9
sqcomp
Roadrunner Jr.
sqcomp's Avatar
It was an option that seemed good to have.
― Thomas Paine
Old 05-02-2010, 01:39 AM   #10
Herbicidal
Herbicidal's Avatar
Agreed! My car was already built and sitting on a different dealers lot, not an option for me.
Spent a couple of more hours on it tonight. Kind of reached a milestone, at least for me anyway. I have almost reached the start of the carpet at the base of the rear seat. I'm almost done with RAAMmat for this 'phase'. Just a few more wide strips to get to the carpet. I plan on putting some Ensolite on the wheel wells to further reduce tire noise at those points. I may put some up on the "C" pillars too since that's about ear level with rear passengers.
Here's few pics from this evenings efforts.
98% done with rear as far as RAAMmat is concerned. I'm pretty well protected from aliens reading my brain waves, as long as I'm in the trunk. Oh, at the very back you can see bare metal. At the point in the trunk, it's double-walled and putting the RAAMmat there wouldn't really accomplish much. Maybe I'll do a strip of Ensolite there instead.
Looks like a giant Jiffy Pop popcorn container!
Several places I deadend the "C" pillar panels since there was stuff in the way on the body of the car. Hey! I just noticed I'm missing a triangle piece on the left one. And the one on the right is missing a small piece too! I'll fix that tomorrow.
Hopefully I'll have some time tomorrow to place some Ensolite in there and maybe pick up some thick foam to put in the large space beneath the rear seat when it goes back in.
Old 05-02-2010, 04:05 AM   #11
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Tell me Rick isn't the $hit. I'm using his Ensolite...good stuff.
― Thomas Paine
Old 05-02-2010, 08:00 AM   #12
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Looking GOOD!
CLA 250, 4MATIC
Old 05-02-2010, 08:28 PM   #13
Herbicidal
Herbicidal's Avatar
AND he's a really nice guy to deal with!
Looking GOOD!
Thanks! Coming along, slowly but surely. I'm going to try and get in another two hours this evening.
Old 05-02-2010, 11:59 PM   #14
derickveliz2
Hey I quit writing my hours in a log... it was embarrassing
Take your time!
That's what I do.
D.
CLA 250, 4MATIC
Old 05-03-2010, 11:24 AM   #15
Herbicidal
Herbicidal's Avatar
Take your time!
That's what I do.
D.
Wow! I never even thought of keeping a log! Glad I didn't. Man, I love working with the Ensolite (peel and stick version)! Much like the RAAMmat, smaller sections work best since it sticks to everything! However, it's very easy to remove and reposition until you push it into it's permanent place. Last night I mostly completed the rear wheel wells and the floor area directly below the rear seat. Started on a section of the rear deck too. At this time, I am not going to do the trunk with Ensolite, just within the passenger compartment. No pics yet. I'm coming down with some kind of bug, so I went to bed early.
Old 05-03-2010, 11:32 AM   #16
derickveliz2
That's the same stuff I'm getting from http://raamaudio I was tired of using the 3M 77 spray on the trim panels, Rick just changed his website but still offers the same materials. Also got more CLD Tiles from sound deadener showdown
CLA 250, 4MATIC
Old 05-04-2010, 08:34 AM   #17
derickveliz2
How deep are your 6.5 speakers? how thick are the adapters? It's probably that you may end up putting a spacer to clear the magnet and the glass of your window.
CLA 250, 4MATIC
Old 05-04-2010, 11:09 AM   #18
Herbicidal
Herbicidal's Avatar
I just checked SonicElectronix and they say: Top mount depth is 3". This is measured from the bottom of the speaker magnet to the bottom of the mounting holes on the rim. The adapters are pretty slim, perhaps 1/4", maybe a little thicker. The speakers mounted in the adapters fit fine in the rear deck, no clearance issues that I can see. I bought the adapters so I could reuse the stock mounting holes in the rear deck without drilling new ones. To that end, it's a perfect fit!
Yaris Sedan Deadening and Sound system upgrade derickveliz2 In Car Entertainment + Electronics (audio / video / alarm) 2992 11-18-2021 02:14 AM
Rines 15 Yaris Sedan 2008 Marko_ec Central and South America 4 12-15-2008 03:02 PM
