Old 09-26-2006, 05:49 PM   #19
paultyler_82
Originally Posted by IsLNdbOi
Wait, we don't have to do any cutting to do these HID retrofits?
Most people that do the Q45 retrofits just dispense with the reflector and put the projector in it's place, it's much easier, you may have to do some cutting and modification to the rear of the housing, however, and also note that you will lose hi-beam function as the Q45 projectors are single-xenon only.
Old 09-26-2006, 06:01 PM   #20
IsLNdbOi
IsLNdbOi's Avatar
I see. People at the HIDPlanet forums say that fx35/45 projectors are the smallest clear lens bixenon projectors. Are there any bi-xenon projectors that will fit through the hole in the Yaris's stock reflector, without any cutting? Or will all projectors require removing or cutting the reflector?
Old 09-26-2006, 08:27 PM   #21
paultyler_82
All projectors will require modification or removal of the reflector, as well as possible modification of the housing.
Old 09-27-2006, 01:30 PM   #22
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
... if not, that would be the smallest projector housing in history!
