Old 05-25-2010, 12:15 PM   #1
TheSilkySmooth
TheSilkySmooth's Avatar
Originally Posted by krusty View Post
The dry residue left by the water pump is not from a faulty water pump it has to do with the super long life coolant Toyota uses. It appears that the coolant can cause this condition from time to time and is considered normal.
Uh, NO!
Old 05-25-2010, 01:44 PM   #2
wooverstone8
wooverstone8's Avatar
How long does it take to have a toyota dealer fix/replace a water pump?
Old 05-26-2010, 01:21 PM   #3
Lucas13
Drives: 07 Yaris LB
I took them about 5 hours and a bunch of scratches on my engine bay by the water pump. Yesterday when I was checking the replace of the water pump to see if it was done right and to check for leaks, I noticed that there is an oil leak coming from the gear box, it might be the Input shaft seal, I was able to smell the gear oil, the left axle seal has been replaced already, at this point the relation with my Yaris is between Love and Hate
Here is a list of things going wrong
-Seats Repaired with no good results (I ended fixing it myself)
-Mid exhaust section Replaced because of the sulfur smell
-Axle seal leaking
-Water pump
-Input shaft seal just started leaking (this might be the reason of the gearbox going early)
-Suspension noises all the way
-Still “enjoying” the stinky A/C smell
I hate that all this has happened to it cuz I really like the yaris but I don’t want to keep repairing this thing over and over, specially know that my warranty is almost expired.
Lucas13 is offline   Reply With Quote
Old 05-26-2010, 01:55 PM   #4
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
-Axle seal leaking
-Water pump
WHILE that pipe was being replaced under warranty WHY didn't they do the a/c tsb???
Old 05-25-2010, 02:26 PM   #5
BLAZINBLUEVITZ
YEAH, it comes from the spot down by the headlight blinker fluid....
FYI: almost ALL of toyota's water pumps are leaking. from camry's to our yaris we see at least 4/5 a day.....
Old 07-02-2010, 06:22 PM   #6
frog13
Tw200--excellent!
Drives: 2010 yaris..absolutely red.
Headlight blinker fluid?????
frog13 is offline   Reply With Quote
Old 07-02-2010, 06:28 PM   #7
frog13
Tw200--excellent!
Salt water/salt in the air doesn't help matters any.............vinegar kills mold and or change your A/C evaperator filter.
Old 08-18-2010, 05:01 PM   #8
wooverstone8
Mine went out yesterday with only 16K miles on it. I took my Yaris to the dealership twice and they assured me that there wasn't anything wrong. They will not to able to fix until Monday...
Old 04-30-2010, 10:15 AM   #9
Aothachos
Drives: 2008 Yaris Sedan
Send a message via AIM to Aothachos Send a message via Yahoo to Aothachos
almost 55,000 miles so far on wp and i have about 30,000 miles on the NST water pump pulley no problems ;)
Aothachos is offline   Reply With Quote
Old 05-01-2010, 02:27 PM   #10
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
I don't know what colour the stock coolant was on my car as I'm the third owned but I put in some yellow (I think) coolant and mine sprayed pink as well.. what the hell?
Old 05-02-2010, 02:57 PM   #11
Hershey
huh , maybe they ran out the pinkish / redish coolant at the factory and went to nearest WAL-MART and got the green coolant since they were out of the original coolant .
Old 05-22-2010, 10:48 PM   #12
Lucas13
Drives: 07 Yaris LB
My WP just gone!!!
I was checking my spark plugs and I noticed some small splash on the hood and also at the pump, I started playing with pump and I was able to perceive some “play” at the Shaft, it’s clear that my WP is not going to get any better, my Yaris has 56k and still stock, I never thought that this was going to happen so soon! I hope the warranty take care of it.
Old 05-23-2010, 09:53 PM   #13
barebonedvitz
return of the comeback
barebonedvitz's Avatar
Drives: white '08LB..very nice,i like
wow... i'm weirded out by this... i'm at 158,xxx and i have no problems with it whatsoever... but i know i'm pretty much due for a new one though... any deals out there?
Everything will be ok in the end... if it's not ok, it's not the end.
93 Civic Si- SC/B18B1 - street beast
07 Red/BlackTop Yaris LB - died in a sandwich in 2010@168K.
08 White Yaris LB - daily beatnut...round 2!
barebonedvitz is offline   Reply With Quote
Old 05-26-2010, 08:38 AM   #14
dushanm
dushanm's Avatar
Drives: Yaris T1
howsit dudes
i recently had my car in at Toyota to check out my shock mounts etc.. i chatted to a mac from the workshop ,i asked him whats the most common fault on the yaris... guess what was the answer.. yes you got that right , the water-pump
he told me that the yaris from 2006 - 2008 had a factory fault on some of the water pumps.
dushanm is offline   Reply With Quote
Old 05-26-2010, 12:19 PM   #15
OtownYaris
OtownYaris's Avatar
Drives: Meteorite Yaris Liftback
Send a message via AIM to OtownYaris Send a message via Yahoo to OtownYaris
I had my water pump replaced @ 33K for the same exact issue. Sprayed all over the hood. Car still ran fine though and they fixed it under warranty. Funny thing is they said they never see that happen on the Yaris. Oh well.
OtownYaris is offline   Reply With Quote
Old 05-26-2010, 01:34 PM   #16
Hershey
doesn't help your trade in value either . I believe all those repairs are kept on record . So , that TOYO dealer or possibly others might be able to look those issues up and give a lesser trade . Hope you have better luck .
Old 05-26-2010, 10:55 PM   #17
Lucas13
Drives: 07 Yaris LB
Yeah you are right, that should decrease the value of the car, Today I asked for a report of the visits of the car to the dealer and they are 22 so far that's only for repairs, since I do my own service, so im pretty sure that that counts, even for the next owner It will be a "nice" surprise to find out that many repairs.
Old 05-26-2010, 11:02 PM   #18
Hershey
wonder if trading it in for a FORD ( for Fiesta ? ) , MAZDA ( for a 2 ? ) , or other competitors vehicles would show up those fixes ?
Water Pump issue, after taking in for Recall GeneralDon7 General Yaris / Vitz Discussion 34 05-27-2012 08:04 PM
Water Pump leaks and then stops CB900F2 DIY / Maintenance / Service 30 05-09-2011 09:14 AM
Hmm my water pump failed again!!!! Could it be the pulley?!?! YarisSedan Performance Modifications 64 10-05-2009 09:32 PM
