Old 05-05-2010, 10:38 AM   #19
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
I found it! I copy the image URL and then did a quick search! it's called:
Universal Coil Spring Control Kit
LINK
Did you find any problems with this? any noises or concerns? how does affects your
suspension? do you recommend it?
Thanks
CLA 250, 4MATIC
Old 05-05-2010, 04:07 PM   #20
33OH
Drives: '08 Yaris
They're fine for what they cost. They make your ride a little bouncier, as expected when you are adding pressure to the springs. Other than that, they work very well. No noises or concerns, I'd recommend them. (They would suck for racing though, too much bounce.)
The Tanabe springs sit very high in the front compared to the rear, and this is an easy fix.
Old 05-05-2010, 04:12 PM   #21
derickveliz2
Thanks
Derick
CLA 250, 4MATIC
Old 05-10-2010, 11:30 PM   #22
d4w1
Drives: Yaris Hatchback
Check it out online with Discount Tires. They have chart replacement for the proper size tire and wheel match up for your Yaris.
d4w1 is offline   Reply With Quote
Old 05-11-2010, 04:17 AM   #23
nazier
black shark
nazier's Avatar
Drives: black toyota yaris t3 sprit
hi there, im running 205/40/zr17, and having no problems, but if u going to load people in the back of your car then just roll the rear fenders as the standard springs make the rear fender catch the tires,
nazier is offline   Reply With Quote
Old 06-17-2010, 05:02 PM   #24
DeathBeard
DeathBeard's Avatar
Drives: 2010 Yaris S
So 15x7 30+ offset rota rb on 205/50 lowered on df springs won't rub?
DeathBeard is offline   Reply With Quote
I NEED A 15" STEEL RIM AND OEM TIRE robkay Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 12-18-2009 10:57 AM
screw more psi in the tires. thebarber Fuel Economy Forum 43 05-04-2009 04:46 PM
Need serious Tire and Rim help thomasward00 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 04-14-2007 01:29 AM
Rim sizing - what size to get for OE equivalent? jay Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 11-20-2006 03:25 PM
