Old 05-06-2010, 10:58 AM   #19
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Originally Posted by hyprmiler View Post
So if I have 2 Yaris's (both sedan / auto) should I get the fluids flushed at 50k and the chain replaced at 75k?
There is NO recommended service interval for either the automatic transmission fluid or timing chain. If you do choose to replace the transmission fluid, you must be sure you get the Toyota "World Class" fluid, which is a special long life synthetic. And there are special instructions for handling it. RTFM.
Old 05-07-2010, 04:32 PM   #20
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
13,000 - Had an axle seal go, my fault, accidentally hit a dip VERY HARD, warranty covered it
40,000 - replaced tires, was a christmas gift, they would've lasted til 50,000 I believe
Cabin & engine Air filters every 6-9months (10-15k miles) Seems I change the cabin air filter more regularly than the engine filter.
At 47,000 miles, I want to change the MT fluid to a nicer synthetic... but am not in any hurry to do it. If I get bored sometime this summer I may do it (some people been doing the redline stuff and swear by it), along with the radiator fluid... probably be around 50-55k before I do that.... if I do it.
Old 05-07-2010, 11:09 PM   #21
STC
"LibertyRides!"
STC's Avatar
Good to know all these replacement times.
I sure hope I can get over 40,000 miles when it comes to tires? I have the Bridgestone Potenza factory tires. I hear they are pretty crappy...
~ Mark ~
Old 05-08-2010, 04:29 PM   #22
Yaris_Fan
Yaris_Fan's Avatar
Drives: Liftback Auto
I only have about 18k miles the Bridgestones don't seem to be showing any wear yet.
Yaris_Fan is offline   Reply With Quote
Old 05-08-2010, 09:08 PM   #23
RedStickHam
RedStickHam's Avatar
Drives: 2009 Toyota Yaris
I have had my car for 15 months and it has 10,000 miles on it. The tires are Goodyear and they seem to be holding up just fine.
RedStickHam
RedStickHam is offline   Reply With Quote
Old 03-17-2012, 10:02 AM   #24
nookandcrannycar
Tires - 70k and 140k , Battery - 138k , Brakes - Only 20 percent worn at 207,135 miles. Will hit 208k miles in the next day or two.
Old 03-17-2012, 10:28 AM   #25
Idahotom
Drives: 2008 5 sp. LB
I NEVER changed the tranny fluid (or rear end fluid) on my '88 Toyota pickup.
I bought it new, and worked it hard for 245 K with 0 problems, and it is still kicking around, now being owned by a sucession of Hispanic concrete contractors: loaded with forms and misc tools, still being worked hard! Whenever I see it I check in with it's current owner (and tell them I built the flatbed) and always ask for a progress report, and if they want to sell it back to me: still running great and no they don't want to sell!
I just mention this to show that while it is exemplary to change the fluids every 50K, it may not be the end of the world if you don't. Oh yeah, I never changed the radiator fluid either.
Idahotom is offline   Reply With Quote
Old 03-17-2012, 11:26 AM   #26
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
you should change them as soon as you can stomach it, they are total and utter crap. the one thing they do seem to do better at than my current tire is gas mileage, and not by a lot, that lack of traction and helped them there. Mine lasted about 36k miles.
Colin Chapman disciple
Old 03-17-2012, 12:03 PM   #27
Kal-El
Kal-El's Avatar
Dealer just checked my front brake pads last month @ 119,000 miles.
30% worn.
Unbelievable.
I commonly see people who have gone through 2 brake jobs by now, sadly to say that they are typically American cars. At this pace, I will be over 300K before my first brake job.
Old 03-17-2012, 12:23 PM   #28
STC
"LibertyRides!"
STC's Avatar
My tires are at 22,500 miles; psi at 42. They actually look good! I'm looking at keeping them for another 15-20 k. What tires are you using?
Cheers!
~ Mark ~
Old 03-17-2012, 12:40 PM   #29
STC
"LibertyRides!"
STC's Avatar
30% worn.
Unbelievable.
I would say that is very believable! When I had inspection with 20,000 miles, my mechanic said I have no visible signs of brake pad wear. He said, these brakes are brand new looking and should get you well over 100,000 mi before you need to change them! I guess hypermiling has its benefits
Cheers!
~ Mark ~
Old 03-17-2012, 01:02 PM   #30
broody
Drives: Yaris 3dr 2009
I work for a restaurant, we had Honda Civic hatchback (ek), Hyundai accent (2002 or so), echo and yaris for delivery, and the yaris transmissions lasts as long as on other cars, in our case 55-65 000 miles.
But the chassis is quite strong, despite the hundreds of potholes, we almost never change suspension/chassis parts (shocks, bushings, sterring components). My civic 99 (used for delivery mostly) wears faster, but it's almost 10 years older so it's normal I guess, and the transmission doesn't grind.
broody is offline   Reply With Quote
Old 03-18-2012, 10:40 AM   #31
Em_
Drives: 2007 Yaris
off topic
nice to see you around here Broody
Em_ is offline   Reply With Quote
Old 10-21-2012, 10:14 PM   #32
alpha1
Drives: 2011 yaris 1.5 Auto-sedan
30% worn.
Unbelievable.
Many factors for break wear. For the yaris, one of the most obvious is the weight of the vehicle vs. a heavy vehicle like a truck... expect the breaks to last longer on lighter vehicles....
& also the tires with less friction due to less weight will result in less wear = more miles before replacement is needed if using the same tire rubber material.
I just purchased a yaris & like seeing the length of time/mileage you obtained prior to servicing the items mentioned.
Another family car is the Pontiac Vibe = Matrix twin and it has over 70,000 miles without servicing brakes. The oem tires went 50,000 miles before replacing.
alpha1 is offline   Reply With Quote
Old 10-22-2012, 07:44 PM   #33
nookandcrannycar
My brakes were only 20% worn at around 208,000 miles. Yarisworld member trini_per4mance didn't have to get his first brake job until 400,000 miles. I replaced the OEM tires between 69-70,000 miles, the first replacement set of 4 at 140,553 miles and the second replacement set of 4 at 225,562 miles. Each set has exceeded the mileage rating (I think each set was rated at 60k, but one might have been 65k).
Old 10-22-2012, 09:46 PM   #34
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
OEM Tires - 28k and they were about bald
Battery - 31k (disclaimer: Car sat for a year while in Afghanistan. Didn't realize that the ECM pulls 500mA at all times so it killed the battery completely requiring replacement)
Pads/Rotors: 75k
Manual tranny - Most likely in the next 25k due to shifting HARD into 3rd
Clutch/Flywheel/Release Bearing - 70k and clutch/flywheel were still in really good shape even with 25k of 8/9psi of boost however the release bearing was shot
Serpentine Belt - 70k and it was chewed badly at that point
Headlamps - Changed them to GE Nighthawks at less than 5k and was one of my best investments.
Sidenote: REALLY need to check my rear brakes I am guessin. They were pulled/checked during annual state inspection in Feb 2012, but still leery at this point.
Old 10-22-2012, 09:55 PM   #35
fnkngrv
fnkngrv's Avatar
My Falken 912s (17") made if for me to only 12k miles...I was pretty pissed to say the least, but even when the wear bars were gone and they pretty much looked like racing slicks then stuck to the road and handled like flypaper. This reminds me that I really need to take a couple pics and post them up!
Old 10-23-2012, 02:04 AM   #36
nookandcrannycar
Pads/Rotors: 75k
Wow. Re Maine, just the brake part of the State Inspection puts the entire State Inspection for Texas to shame.
2007 Yaris S 5spd Sedan doing 300,000 miles in less than 2 1/2yrs. trini_per4mance General Yaris / Vitz Discussion 100 06-08-2022 09:54 PM
Best all-season tires for the Yaris? Rahxephon Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 03-17-2013 06:40 PM
Summer tires ! Franck_Qc Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 02-02-2009 09:36 PM
Why do all low profile tires have to be of high performance design? grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 05-16-2007 01:23 AM
FS: Stock tires on steelies spkrman Items for Sale by private party 9 04-12-2007 06:45 PM
